Flight Simulator 2004 Control Issues
Old November 22nd 03, 07:05 AM
SouthBayGuy
Default Flight Simulator 2004 Control Issues
Hello Everyone:
I was hoping that someone with more experience than I could help me with
some questions/problems that I have with MS Flight Sim 2004. I have owned
all of the FS since 4.0, and the one that has worked best for me has been
2002. A couple of weeks ago, I got 2004, and am quite happy with it as an
"upgrade," more for the "little things" (more choices in ATC, better GPS,
etc), but have had some problems that are either brand new, or seem to have
gotten worse in this version.
First, my system;
Compaq 1.6 GHz Pentium 4
512 mb RAM 433mhz bus
80gb 7200 EIDE HDD 80gb Maxtor external HDD (USB)
NVIDIA Geoforce 2MMX 64MB video (yeah yeah, I know)
Windows XP Home SP1 with all the lil "patches"
Saitek Cyborg EVO Joystick
This system can run FS2004 fairly well, good frame rate, not the best
scenery detail of course, but I use FS mostly as a recreational thing, to do
the flying that I cant afford, and am not skilled for yet, in R/L. I have
taken some flight training in the past, it's been a long time ago, but I do
know what it's like to fly a real 182, etc. With my older video card I've
found that the best thing to do is leave it at whatever the program puts at
the defaults--that gives the best performance for me.
Now, to the issues:
1. Rudder control-Both my joysticks (I also have the MS Sidewinder 2.0 that
frankly I'm disappointed with), have twist for rudder. It is VERY DIFFICULT
to taxi, to keep the plane on the taxi line and even more difficult to track
the center on take off and landing rolls. This occurs in all planes but is
worse in the Mooney Bravo. Is this just part of the flight model, .cfg file,
whatever? I don't want to invest in custom rudder controls and have the same
problem..that would be very depressing! Also once in the air, the planes
especially the light gen av aircraft, wander a bit as far as heading (the
Mooney is worst at this).
2. Auto Pilot Problem-Now THIS is the thing that is frustrating. When I'm
flying any of the lighter aircraft, really anything other than the
airliners, when the A/P is set for altitude it keeps the trim so nose high,
the airplane can't pass 80 knots or so. This is especially bad in the 172
182 and Mooney. The twins do it to an extent; it doesn't really happen in
the jets because you can set the A/P to maintain IAS. Is there ANY way to
stop the A/P from setting the trim so nose high? I've also noticed that when
flying along in A/P that periodically the plane will suddenly act like it
was hit by a gust (even with wind turned off), slip, raise and fall a bit,
then try to go back to the heading and altitude (and of course roll the
elevator trim way high! UGH!).
The Mooney for seem reason, just seems downright unflyable. Am I doing
something wrong, do I have to alter a config file or something? It just
seems, from my limited real piloting experience, that real aircraft are
about 20 times easier to control. Anyway thanks so much for taking the time
to read my post. I would appreciate any help or advice anyone could give.
Thanks!
Old November 22nd 03, 01:23 PM
glathrem
If you turn AP off and center the joystick, will it fly straight and level?
Sounds like the AP is compensating for a slightly down stick. I have the 3
axis sidewinder and it works fine, except that FS9 pushes buttons on it's
own occasionally. I do see the quick turbulence bump you have once in a
while. That Mooney Bravo is a bummer. It won't fly straight unless you
continuously switch fuel tanks. It only draws fuel from one tank at a time
and quickly becomes unbalanced enough to turn. Would be a really nice plane
except for that. My system is not much better than yours; 1.8ghz, Nvidia
64mb (geforce4), XP sp1, 512 ram...... I most of the time maintain 20FPS
with most sliders maxed out (the sliders important to me anyway).
"SouthBayGuy" wrote in message
link.net...
Hello Everyone:
have
First, my system;
do
do
at
Now, to the issues:
that
DIFFICULT
track
file,
same
high,
when
time
Thanks!
Old November 22nd 03, 02:18 PM
Lange_666th
Regarding the rudder, i also have this problem and i use a set of race
pedals in combo with a modified Cougar.
Even with the rudders sensivity set to min, it's still way to sensitive in
respons.
I don't believe real rudders will act better here.
Lange,
666th Black Brigade
http://www.666th.com
ICQ: 15439346
"glathrem" wrote in message
level?
plane
link.net...
Hello Everyone:
owned
been
an
GPS,
have
First, my system;
to
do
have
do
I've
at
Now, to the issues:
that
DIFFICULT
track
is
file,
same
(the
I'm
high,
172
in
to
when
it
bit,
time
give.
Thanks!
Old November 22nd 03, 05:52 PM
Dashi
I have the CH Pro USB pedals, work great, not overly sensitive.
On take off all single engine recip's are going to need right rudder input,
IRL and the sim.
Should have no problem keeping it on the center line, airborne, without
outside reference, it will take a bit more practice.
Dashi
"Lange_666th" wrote in message
respons.
Lange,
666th Black Brigade
ICQ: 15439346
level?
3
it's
time
plane
link.net...
Hello Everyone:
with
owned
been
an
GPS,
have
First, my system;
to
do
have
I
do
I've
puts
at
Now, to the issues:
that
DIFFICULT
track
but
is
file,
same
planes
(the
I'm
high,
172
in
to
that
when
it
bit,
just
are
time
give.
Thanks!
Old November 23rd 03, 09:43 AM
SouthBayGuy
Thanks for your reply Dashi:
Yep, I try to hold right rudder on T/O but, find myself weaving all over. I
try itty bitty movements but it does the same thing. I'll keep practicing
Regards to all
"Dashi" wrote in message
input,
IRL and the sim.
Dashi
in
respons.
Lange,
666th Black Brigade
ICQ: 15439346
level?
3
it's
a
time
plane
Nvidia
20FPS
link.net...
Hello Everyone:
with
owned
been
as
an
GPS,
to
have
First, my system;
best
thing,
to
do
have
but
I
do
I've
puts
at
Now, to the issues:
2.0
that
DIFFICULT
to
track
but
is
..cfg
file,
same
planes
(the
When
I'm
nose
high,
172
happen
in
way
to
that
when
like
it
a
bit,
doing
just
are
time
give.
Thanks!
SouthBayGuy
Thanks for your reply, Lange_666th:
That was what I was afraid of I have been thinking about getting the CH
pedals for awhile and a good yoke like that, but have been scared to spend
the money thinking what if it still acts the same? I still might get them
for myself as an xmas present because (a) I'm so hooked on FS and even
though each version has had it's frustrations, I spend a lot of time in it
and (b) I've heard from almost everyone a yoke and pedals is SO much better
than a joystick, even the best joystick.
Regards to all
respons.
Lange,
666th Black Brigade
ICQ: 15439346
level?
3
it's
time
plane
link.net...
Hello Everyone:
with
owned
been
an
GPS,
have
First, my system;
to
do
have
I
do
I've
puts
at
Now, to the issues:
that
DIFFICULT
track
but
is
file,
same
planes
(the
I'm
high,
172
in
to
that
when
it
bit,
just
are
time
give.
Thanks!
Old November 23rd 03, 12:59 PM
mdavis
CH Pedals
The Control Manager for CH pedals and yokes is great. You can enter the
adjustment section where you get small graphs that allow you to tweak the
curves to set sensitivity any way you like it by moving them around,
steepening the slopes, bowing the centers, etc. I've owned a USB Yoke LE
(no mix/prop) and a set of ProPedals for several years now and they work
beautifully.
Flight models
Many FS2002 aircraft ported over to FS9 exhibit a nose heavy attitude. Some
designers suggest setting elevator trim to compensate for this. It is often
a total remake of the .cfg and .air files to tweak one properly, which is a
big job.
Old November 24th 03, 02:02 AM
SouthBayGuy
Thanks for your reply, mdavis:
I have heard from many people I chat and email with that the CH pedals as
long as you have the current version of that control software, are very
good. As I stated in another post here, I have been thinking of getting a
yoke/pedals for some time, but have been hesitant because of some of the
issues I experience in FS; however I do understand that having a yoke and
set of pedals is quite superior to a joystick, even the best ones (I have
both a sidewinder 2.0 and a Satiek Cyborg EVO, which I think are the
probably the best 2 "mid priced" joysticks). I think I'll just use the
holiday season as my excuse to go for it!
On the flight models, that's kind of what I figured---it's something you
have to tinker with to get it like you like it. I guess the next step is to
read up on tweaking the .cfg and .air files, or maybe find a utility to help
me. Thanks for your time!
"mdavis" wrote in message
. com...
CH Pedals
beautifully.
Flight models
Some
often
a
big job.
SouthBayGuy
Thanks for your reply, glatherm:
Well no it won't fly straight and level, really. Without the A/P I am
constantly having to readjust power/trim, and still find myself climbing or
descending about 300fpm. It's either my poor skills as a sim pilot after all
these years, or none of the joysticks i've tried will calibrate exactly
correct on this computer of mine. I still tend to think it's a combination
of my lousy flying and the default flight models and whatever bugs are
present in FS9. I'm tending to believe what I do about the flight models
because I got the "Perfect Flight General Aviation Adventures" add on from
the internet the other day (because it has a citiation in it) and although
the graphics on the planes and panel's aren't up to MS, the planes handle
much better.
Thanks for the tip on the Mooney I'll try it!
Regards to all
level?
plane
link.net...
Hello Everyone:
owned
been
an
GPS,
have
First, my system;
to
do
have
do
I've
at
Now, to the issues:
that
DIFFICULT
track
is
file,
same
(the
I'm
high,
172
in
to
when
it
bit,
time
give.
Thanks!
Old November 23rd 03, 08:16 PM
Noi
On Sun, 23 Nov 2003 09:43:21 +0000, SouthBayGuy without thinking wrote:
Did you uninstall and reinstall FS9? Checked rudder trim?
or descending about 300fpm. It's either my poor skills as a sim pilot
after all these years, or none of the joysticks i've tried will calibrate
exactly correct on this computer of mine. I still tend to think it's a
combination of my lousy flying and the default flight models and whatever
bugs are present in FS9. I'm tending to believe what I do about the flight
models because I got the "Perfect Flight General Aviation Adventures" add
on from the internet the other day (because it has a citiation in it) and
although the graphics on the planes and panel's aren't up to MS, the
planes handle much better.
Regards to all
level?
3 axis sidewinder and it works fine, except that FS9 pushes buttons on
it's own occasionally. I do see the quick turbulence bump you have once
in a while. That Mooney Bravo is a bummer. It won't fly straight unless
you continuously switch fuel tanks. It only draws fuel from one tank at
a time and quickly becomes unbalanced enough to turn. Would be a really
nice
plane
link.net...
Hello Everyone:
with some questions/problems that I have with MS Flight Sim 2004. I
have
owned
been
an
GPS,
have
First, my system;
80gb 7200 EIDE HDD 80gb Maxtor external HDD (USB) NVIDIA Geoforce 2MMX
64MB video (yeah yeah, I know) Windows XP Home SP1 with all the lil
"patches" Saitek Cyborg EVO Joystick
to
do
have
I
do
I've
puts
at
Now, to the issues:
that
DIFFICULT
track
but
is
file,
same
planes especially the light gen av aircraft, wander a bit as far as
heading
(the
I'm
high,
172
in
to
that
when
it
bit,
the elevator trim way high! UGH!).
just seems, from my limited real piloting experience, that real
aircraft are about 20 times easier to control. Anyway thanks so much
for taking the
time
give.
Thanks!
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 05:14 AM
Canadian IFR/VFR Flight Plan gwengler Instrument Flight Rules 4 August 11th 04 03:55 AM
x-43 Flight Garrison Hilliard Military Aviation 0 March 26th 04 12:42 PM
FA: Flight Training Magazine 110 Issues Tony St. Clair Aviation Marketplace 0 November 23rd 03 05:00 AM
