I'm helping KS update his Powerflarm - firmware update to core and updated config files using the Config Tool from the Flarm Website. The update to the Powerflarm worked (solid green color), but the communication to the Flarmview stopped working.
I poked around and found the baudrate setting on the Flarmview is 38400 while the default setting on the config tool is 19400. Just for gits and shiggles I went into the manual settings using the config tool, updated the RJ connection to 38400, and it works. So, before I claim victory, is there anything else that needs to be done to the "default" Flarm Config to make it work with a Flarmview. I did RTFM on the Flarmview, and it is pretty vague on what the communications protocol settings need to be... P3 |
"Rainy days at a contest...."
You can look at a current (yesterday?) IGC log from the ship, it will have all the settings from the old config so you can compare to the new one. It was recently discussed here about "how to pull my old config before the update". |
On Sunday, May 17, 2015 at 12:22:19 PM UTC-4, Charlie M. (UH & 002 owner/pilot) wrote:
"Rainy days at a contest...." You can look at a current (yesterday?) IGC log from the ship, it will have all the settings from the old config so you can compare to the new one. It was recently discussed here about "how to pull my old config before the update". Yeah but... it looks like there is a new option for Communications Protocol that wasn't there before. At least that's what it looks like when you use the online Configuration Tool. I could be wrong. |
What I use:
################################################## ###################### # dataport configuration ################################################## ###################### # configure RJ-45 port for FlarmView 57 $PFLAC,S,NMEAOUT1,61 $PFLAC,S,BAUD1,5 ################################################## ###################### and set (on flarmview) data rate to 57,600 baud. It's not really necessary to set the mode -- I asked Uros about this and he says it is non-critical (so flarmview probably issues it's own mode setting command on the dataport). What *is* critical, as you have discovered is that the datarate set in flarmcfg.txt and on flarmview (in settings on flarmview) match. Have fun at Mifflin. -T8 |
Hi,
I don't recommend using the default settings. They are not ideal. I have some tips for how to set the parameters in my PowerFLARM Tips document he http://www.cumulus-soaring.com/flarm...FLARM-Tips.pdf Best Regards, Paul Remde Cumulus Soaring, Inc. ___________________________________ "Papa3" wrote in message ... I'm helping KS update his Powerflarm - firmware update to core and updated config files using the Config Tool from the Flarm Website. The update to the Powerflarm worked (solid green color), but the communication to the Flarmview stopped working. I poked around and found the baudrate setting on the Flarmview is 38400 while the default setting on the config tool is 19400. Just for gits and shiggles I went into the manual settings using the config tool, updated the RJ connection to 38400, and it works. So, before I claim victory, is there anything else that needs to be done to the "default" Flarm Config to make it work with a Flarmview. I did RTFM on the Flarmview, and it is pretty vague on what the communications protocol settings need to be... P3 |
PowerFLARM Core secondary FLARM antenna | [email protected] | Soaring | 27 | October 7th 14 01:53 PM |
For Sale - Used PowerFLARM Core v1 | Paul Remde | Soaring | 1 | May 30th 14 03:09 AM |
New FlarmView Flarm Config Menu? | [email protected] | Soaring | 0 | February 27th 14 05:06 PM |
Powerflarm Brick/Core ADSB Range | Sean F (F2) | Soaring | 3 | September 5th 13 03:10 PM |
