Zander 941
Old May 27th 15, 04:56 PM posted to rec.aviation.soaring
John Sullivan
Default Zander 941
Hi, I have a Zander GP 941, one of the few in the US. It's recording
current flight dates to of occured in 1996.
"Where a FR has already lost the date facility, the solution is to return
the FR for modification to the manufacturer or his agent. The fault is
because the GPS receiver no longer registers the correct GPS date
Epoch, reverting to dates in 1 the first Epoch which started on 6
January 1980 when the US GPS system first went on line after its
development phase.
A GPS date Epoch consists of 1024 weeks (19 years and 36 weeks)
before the next Epoch starts. Where this fault exists the date recorded
is typically 1024 weeks too early, and in some FRs other faults may
also be present. We are now in the second GPS date Epoch. This
started in August 1999 and will change to the third Epoch in April
2019. If the GPS receiver or FR firmware recognizes that it is in the
second date Epoch, the correct date will appear on the IGC file."
Has anyone else been able to overcome this by simply charging the
unit or does the battery have to be replaced. if so who can do it since
Zander has shut down. I love this recorder and the Zander ZS1.
Someone should create a next gen with nice big moving map display.
John Sullivan - UFO
Old May 27th 15, 05:58 PM posted to rec.aviation.soaring
Tim Newport-Peace[_2_]
Default Zander 941
development phase.
John Sullivan - UFO
Have you tried cantacting Franz Pöschl at
http://www.sdi-variometer.de/user/kontakt.html
Old May 28th 15, 12:29 AM posted to rec.aviation.soaring
Peter von Tresckow
Default Zander 941
development phase.
John Sullivan - UFO
The same thing is happening it model20/25s as well as volkslogger schism is
a bug in the Garmin gps25 embedded in these devices. Probably your best bet
would be to invest in a nano or similar.
Peter owner of a functional model25 and a bricked volkslogger
Old May 29th 15, 12:44 PM posted to rec.aviation.soaring
David Kinsell[_2_]
Default Zander 941
return
development phase.
recorded is typically 1024 weeks too early, and in some FRs other
faults may also be present. We are now in the second GPS date Epoch.
This started in August 1999 and will change to the third Epoch in
April 2019. If the GPS receiver or FR firmware recognizes that it is
in the second date Epoch, the correct date will appear on the IGC
file."
Has anyone else been able to overcome this by simply charging the unit
John Sullivan - UFO
is a bug in the Garmin gps25 embedded in these devices. Probably your
best bet would be to invest in a nano or similar.
More charging won't fix the units, even a new battery wouldn't be
adequate since the units think they're in the previous epoch and need to
be reset.
The gps25 just wasn't adequately engineered to have such a long lifetime,
and the FR vendors could have done a better job of supporting the thing
in the application.
I always wince when people spend as much fixing up the old units as a new
unit with far superior specs would cost. Time to move on.
Dave
Old May 29th 15, 01:12 PM posted to rec.aviation.soaring
krasw
Default Zander 941
Dave
Except variometer part in Zander SR940/GP941 system is still one of the best, and moving on might easily mean stepping down.
Old May 29th 15, 01:31 PM posted to rec.aviation.soaring
David Kinsell[_2_]
Default Zander 941
new unit with far superior specs would cost. Time to move on.
Dave
That's fine. It's like the Cambridge 302, which I currently have, many
people like its variometer. If my logger goes out, I'll buy a Nano and
leave the 302 in place. Nano is tiny, it's not like it's a panel space
issue. I'll let the 302 gps still drive my moving map, which is a Nook
with TopHat.
I've been accused in the past of "hating all 302's", which was a stupid
comment (even for R.A.S.). Making rational decisions about obsolescent
hardware isn't anything to be ashamed of.
Dave
zander zs1 to oudie alexandre annoi Soaring 2 June 19th 14 11:26 AM
Zander SR940 ver. 9900 No Name Soaring 0 October 26th 07 01:53 AM
Zander SR800 problem Ian Soaring 0 December 27th 06 05:48 PM
Zander 820 [email protected] Soaring 1 June 11th 05 07:44 PM
New Zander SDI jsullivan Soaring 1 February 17th 04 06:57 PM
