Since I took over the production of the popular "Wingrigger" assembly aid, I have shipped over thirty units. I have just been advised by a customer that there may be a slight problem with the locking mechanism on the sliding axle.
The axle runs through a machined sleeve activated by a knob with a pointed screw end that slightly spreads the two ends of the sleeve to secure the sliding action. Apparently, the pointed end of the screw can contact the axle surface without allowing the sleeve to spread. As a result, the axle can still slide, although there is some resistance. Fortunately, the problem is easily solved by just filing the very tip of the pointed screw on the knob so that the lock sleeve will spread and secure the axle without the point touching the axle. Only 1/16 inch or so has to be removed. My apologies for this situation. If you have any questions, please contact me through the Wingrigger or MM Fabrication websites. |
| Wanted to buy Wingrigger | Greg Delp | Soaring | 0 | February 27th 13 12:44 PM |
| FAA advisory voids IFR certification for GPS's!!! | Prime | Owning | 12 | May 29th 07 02:43 AM |
| ATCSCC Advisory Message Feed - ??? | [email protected] | Piloting | 2 | May 23rd 05 08:31 PM |
| ATCSCC Advisory Questions | [email protected] | Piloting | 0 | January 8th 05 01:46 AM |
| MEDIA ADVISORY ON 767A REPORT TO CONGRESS | Otis Willie | Military Aviation | 0 | July 11th 03 10:30 PM |
