Oxygen system in ASW-27 ASG-29
Old August 11th 15, 09:58 PM posted to rec.aviation.soaring
Default Oxygen system in ASW-27 ASG-29
Recently acquired an ASG-29 (ASW-27-18)and unable to mount O2 regulator on bottle behind seat back. Not enough room with seat back in aft position. How have other 27/29 owners solved this problem? Flex high pressure line? If so, where was it purchased?
Thanks
Old August 11th 15, 11:15 PM posted to rec.aviation.soaring
John Cochrane[_3_]
Thanks
Mine fits great right on the bottle. MH system. In both a 27 and a 29. Do you have the right bottle?
John Cochrane
Old August 12th 15, 02:35 AM posted to rec.aviation.soaring
We do have the correct O2 bottle. Did not want to cut seat back.
Old August 12th 15, 12:06 AM posted to rec.aviation.soaring
JS
I just posted what you may be looking for on the Yahoo ASW27 newsgroup, including a photo.
https://groups.yahoo.com/neo/groups/ASW27owners/info
Old August 12th 15, 02:38 AM posted to rec.aviation.soaring
Mark628CA
I am a dealer for Mountain High Equipment and have installed several ASW-27 systems. Contact me at: info (at) mmfabrication )dot) com if you don't get the information you need from RAS.
The ASW-27/29 will only accept a steel cylinder of a particular size, and the regulator mounts at a 90 degree angle to the cylinder. It usually has sufficient clearance to the seatback (if the regulator is angled slightly outboard). The interference is usually the large cast aluminum handle that opens the valve on the cylinder. Either remove the retaining screw on the handle and only use it to open and close the cylinder valve before and after flight (use a string to keep it attached so you don't lose it) or make a simple one-wing handle that will not interfere with the seat back. If you need a handle and don't want to make one yourself, contact me.
Old August 12th 15, 03:31 AM posted to rec.aviation.soaring
Handle removed, but not enough clearance with seat back in aft position. Tried all orientations for regulator/bottle
Old August 12th 15, 02:51 AM posted to rec.aviation.soaring
Sean Fidler
Thanks
What is your serial number? I have 29004. It has a euro bottle size and I still have not been able to get one that fits (from all the usual suspects). I have to use a small Mountain High Bottle and fill every day. Ugg.
Sean
7T
Old August 12th 15, 03:21 AM posted to rec.aviation.soaring
Serial number 29055
Old August 12th 15, 05:44 AM posted to rec.aviation.soaring
George Haeh
Stupid Question - Is the bottle all the way
in?
There's a housing to hold the bottom of
the bottle, but the bottom tends to miss
leaving the bottle a couple inches farther
out than it should be.
Old September 1st 15, 08:43 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Thanks
Contact John Murray at Eastern Sailplane. As the former Schleicher dealer for many years he has both the experience and the O2 bottles to help you. Take a D steel cylinder, but not every D cylinder will work. John measures the cylinders and keeps the ones that work. MH has a Kevlar cylinder Which is smaller than the allotted space, which will work when wrapped with foam or vacuumed packed survival kit and is much lighter than the steel, but a bit small for western flying.
FS Twin Oxygen System NG Soaring 2 March 4th 14 01:07 AM
Wanted a portable Oxygen System chasers03 Soaring 1 May 3rd 10 04:12 PM
PW-5 Oxygen System pedalermike Soaring 3 February 14th 08 04:56 AM
Oxygen System for sale [email protected] Soaring 1 December 2nd 06 06:47 AM
mountain high oxygen system Mal.com Soaring 1 February 2nd 05 04:08 AM
