LXNAV V8 (S8/V80/S80) Issues?
Old September 1st 15, 11:35 AM posted to rec.aviation.soaring
Default LXNAV V8 (S8/V80/S80) Issues?
Hi all,
I wonder if anybody in this forum using the V8, V80 or S8/S80 has experienced the same problems that I have and can help me with some advice.
Last year I bought a new LX9050 and ordered the V8, but due to production delays, I got to borrow a V5 vario.
I installed the LX9050 with the V5 and set it up to use Electronic compensation and everithing was fine. The Vario worked like a charm.
During the nationals, the V8 was finaly delivered and I was looking forward to flying with the new vario, expecting superb performance.
What I experienced however is a very "unsteady" vario behaviour. I tried setting the filters / damping at different settings from 0.5 to 2.5 seconds (I also played arround with the "Smart filter" option) and although the high damping produces a more steady sound and needle movement, it also seems very slow and still shows some unexplicable "peaks" or "valleys" that seem erroneous.
I've been really fighting to get this right with no luck so far.
I will really appreciate to hear from others experiencing this behaviour and especially if they have been able to "fix" the problem.
If you have a good working V8, V80, S8 or S80, I'll also be interested in your vario filter settings in order for me to try.
Thank you very much in advance.
Best regards
Felipe
Old September 1st 15, 01:36 PM posted to rec.aviation.soaring
Richard[_9_]
On Tuesday, September 1, 2015 at 3:35:15 AM UTC-7, wrote:
Hi all,
Best regards
Felipe
Felipe,
I don't have those issues.
Call me, I have an S8
Richard
www.craggyaero.com
Old September 1st 15, 01:51 PM posted to rec.aviation.soaring
Hi Richard,
I'm based in Denmark, so I'm not sure what time difference we are talking about to where you are in order to find an apropriate time.
Anyway I'm trying to see if others have the same issue or if my unit might be defect somehow.
Old September 1st 15, 03:19 PM posted to rec.aviation.soaring
Richard[_9_]
On Tuesday, September 1, 2015 at 5:51:19 AM UTC-7, wrote:
Hi Richard,
Have you contacted LXNAV?
Uros is very responsive.
Richard.
Old September 2nd 15, 07:40 AM posted to rec.aviation.soaring
I've contacted Uros some time ago, and he explained that this new vario was more sensitive than the V5 so I should try increasing the filter settings.
I'll probably contact him again, but before I do I was wondering if there was some "Magic setting" that I had missed to try.
Uros is responsive, but quite busy also and I wan't to gather as much intel as possible before contacting him.
br.
Felipe
Old September 1st 15, 01:38 PM posted to rec.aviation.soaring
I have been flying with the S80 as a stand alone vario. It is connected to my Oudie/SeeYou and Flarm brick.
My unit is set-up with 100% electronic compensation. I have a Winter vario connected to the TE probe.
I have been flying with the S80 using the default settings/filters and it has been very good. It responds a bit faster than the Winters and seems to be less "jumpy" in turbulant conditions with horizontal gusts. My previous electronic vario was a Cambridge 302 which was very satisfactory.
Old November 4th 15, 04:51 PM posted to rec.aviation.soaring
Don Grillo
Hi Felipe,
I am considering ordering the LX9050 and V8 combo as well. Have you been able to resolve this issue and if so, what was it?
Thanks,
Don
On Tuesday, September 1, 2015 at 5:35:15 AM UTC-5, wrote:
Hi all,
Old November 5th 15, 08:18 AM posted to rec.aviation.soaring
I have used a V9 and then a V8 with my 9000 and have found none of the issues reported by the OP. With similar vario settings to those I had optimised for the V9 I prefer the V8 response to the V9.
Old November 5th 15, 08:43 PM posted to rec.aviation.soaring
Andrzej Kobus
What about pointer visibility in direct sun? It looks good indoor.
New LXNAV S8 vario Paul Remde Soaring 5 October 12th 15 04:14 PM
LXNAV V3 Issues [email protected] Soaring 20 April 14th 15 05:49 AM
LXNAV V7 and WinPilot Pro [email protected] Soaring 6 November 14th 13 03:35 PM
LXNAV Flarmview [email protected] Soaring 2 September 29th 13 01:47 AM
LXNAV V7 Paul Remde Soaring 2 November 2nd 11 12:31 AM
