ClearNav CNv software updates available
Old October 2nd 15, 03:49 AM posted to rec.aviation.soaring
Tango Eight
Default ClearNav CNv software updates available
At the usual place... http://www.clearnav.net/main/cn-downloads.html
Users with NAV display and XC license can try out our new thermal assistant in the 3.2 beta. There's also an update for 3.1.
Please see release notes, they contain information you'll want to have.
Good Soaring and best regards,
Evan Ludeman for CNi
Old October 3rd 15, 01:36 PM posted to rec.aviation.soaring
joesimmers[_2_]
Evan, will the thermal assistant display on the main CN screen if
that is coupled to the CNV?
Or will it be necessary to purchase the new style Nav Display
for the CNV to use the assistant?
Old October 4th 15, 03:47 AM posted to rec.aviation.soaring
Tango Eight
We need to figure this out oursselves :-).
The TA was developed on NAV because that was the convenient platform. It exceeded expectations in alpha testing, we wanted to get it out in the real world as quickly as possible. We aren't finished by any stretch, this is a beta.
best,
Old October 4th 15, 04:21 PM posted to rec.aviation.soaring
Dan Marotta
Now you've got me thinking...
Is the thermal assistant transmitted via the serial port? Perhaps
XCSoar will be able to use the data for its thermal assistant (at least
if the developers think it's better than the one they provide).
I hope Max is listening...
best,
Dan, 5J
Old October 5th 15, 03:00 AM posted to rec.aviation.soaring
Tango Eight
On Sunday, October 4, 2015 at 11:21:32 AM UTC-4, Dan Marotta wrote:
Is the thermal assistant transmitted via the serial port?*
Not at this time.
best,
Old October 5th 15, 05:36 AM posted to rec.aviation.soaring
Surge
On Sunday, 4 October 2015 17:21:32 UTC+2, Dan Marotta wrote:
Is the thermal assistant transmitted via the serial port?* Perhaps
least if the developers think it's better than the one they
provide).
I hope ClearNav is listening...
The biggest problem the XCSoar developers face regarding hardware is the lack of support from the instrument manufacturers. Only a few of them publish their serial protocols and the rest either ignore requests for documentation or give you an outright "no". The developers don't have the hardware and/or time to try to reverse engineer every proprietary instrument available so if the manufacturers decide to throw up road blocks then rather stick to supported hardware or you as a customer need to put some pressure on the manufacturer to release the info.
Max has stated on the XCSoar forums that people should steer clear of the following manufacturers if they want their hardware to integrate with XCSoar:
- ClearNav
- LX Navigation
- SDI/Zander
- Westerboer
Old October 5th 15, 11:31 AM posted to rec.aviation.soaring
Tango Eight
provide).
- ClearNav
- LX Navigation
- SDI/Zander
- Westerboer
Hey Dan, how's CNv working with XCSoar on your Dell Streak?
-Evan
Old October 5th 15, 02:05 PM posted to rec.aviation.soaring
provide).
- ClearNav
- LX Navigation
- SDI/Zander
- Westerboer
If you are a manufacturer of soaring instrumentation that does computation and display, why would you voluntarily give away your proprietary information to people that produce competitive alternatives for "free"?
Maybe the availability of features one can not get on freeware is a reason to buy the products they produce.
Not everything in life has to available for free on the internet.
There certainly seems to be room for both approaches, each with benefits.
UH
Old October 5th 15, 05:13 PM posted to rec.aviation.soaring
Dan Marotta
Well... That's really too bad.
So far, I've had excellent results with my ClearNav XC vario feeding my
Dell Streak 5 running XCSoar. Shortly after I switched from a CAI-302
to the ClearNav the CNI folks made software changes such that my system
worked pretty much the same way as it had with the 302.
Dan
provide).
- ClearNav
- LX Navigation
- SDI/Zander
- Westerboer
Dan, 5J
ClearNav CNv Club Software Release Evan Ludeman[_4_] Soaring 10 June 6th 13 12:36 AM
ClearNav CNv vario software update Evan Ludeman[_4_] Soaring 5 April 17th 13 12:28 AM
ClearNav Flight Computer Software Update Available Evan Ludeman[_4_] Soaring 0 March 9th 13 01:40 AM
New ClearNav Vario (CNv) and MFD software versions released. [email protected] Soaring 0 August 3rd 12 01:14 PM
AV8OR Firmware and software updates SR300 Piloting 0 October 18th 08 03:58 AM
