Can't buy them all, choosing between ASW19 vs LS1 vs PIK20
Old October 16th 15, 03:51 PM posted to rec.aviation.soaring
PAGA
Default Can't buy them all, choosing between ASW19 vs LS1 vs PIK20
Hi all,
After a long break from gliders, last year I moved close to an airfield and resumed flying at the local soaring club on Blanik metal 2-seaters. While this is always a lot of fun I am tempted to finally get my own one-seater and start practice longer flights, with slightly better performance than the L23, and also maybe take it on the road to fly elsewhere in the US.
Most of my previous one-seater experience was on Grob 102, both in Europe and in the US : I was looking for a used one and missed a local sale by a few weeks/days. While searching other available used ships not too far from me, within the set performances and the price range I want to commit to, I have narrowed it down to a PIK20, or a LS-1 or an ASW19, in similar conditions and within my parameters (L/D, sink rate, instruments, size, weight, type, etc... i.e. similar to the Grob) and price range (+/- a few $K).
This is the first time I am considering owning my own ship, and I am sure this forum has seen this kind of question a million times (apologies for the duplicate thread) I searched some of these threads but I need to ask a more experience crowd about my specific choice : how to decide between these 3 fine sailplanes, what should I do/ask/check with the sellers in order avoid obvious mistakes and make it easier to decide?
My main concerns are very "grounded" : how to deal with maintenance (when the manufacturer is no longer around for example), and how hard/easy is it to assemble/store them back in the trailer. Of course I am sure these ships handle differently when in the air but I am not too concerned about learning how to deal with each flying specifics/idiosyncrasy, at this point I feel most of my challenges are actually going to be when on land :-)
Thank you all for your time.
Old October 16th 15, 04:14 PM posted to rec.aviation.soaring
Hi,
the ASW19 will probably give you least concern in terms of maintenance. At least here in Europe, Schleicher provides excellent support even for the older ships. There is no type certificate holder for the PIK20 anymore. Parts for LS1-f are to some extend still available but you may have to pay the "DG-tax". For previous LS1 versions, things are more difficult.
Assembly of all three models works pretty similar, but the ASW19 has rather heavy wings (70-75kg). All have manual aileron/flaps connectors. Most 19 have a manual elevator connector which one needs to take care of.
Best,
Christoph
Old October 16th 15, 04:27 PM posted to rec.aviation.soaring
Justin Craig[_3_]
Buy a good 19!
LS1 you will need to pay the DG tax.
No need to say anything about the Pik.
Old October 16th 15, 06:17 PM posted to rec.aviation.soaring
On Friday, October 16, 2015 at 11:30:05 AM UTC-4, Justin Craig wrote:
Buy a good 19!
Good comments all, thus far.
Out of your list, I feel the 19 would be the best out of them. Good support, easy to fly (winglets can help here on the low speed side, Nixon/Murray tips seem the best) and decent performance. Similar would be the Pegase 101 (French 19).
They are all older gliders, so reasonable finish (slight crazing is almost a given, deep cracks will require an expensive refinish) is worth looking for.
A "factory" type trailer is also desirable, some "cobbled together" trailers can be a real PITA do deal with and may raise the chance to damage the glider.
Welcome back to the sport. ;-)
Old October 16th 15, 04:31 PM posted to rec.aviation.soaring
Pete[_9_]
I flew a Grob 102 for my first ship. I did love it but assembly was a pain, getting the wing pins lined up sucked!
I'm now in a DG 100 and there is a significant difference in stick feel (much lighter!). My flying buddy has an ASW 19 and we go head to head all the time.
Both of these ships are very light on the stick (compared to the Grob 102) with really no bad habits (not that the 102 has any either). I would go with the ASW 19. Heavier wings but easy assembly, amazing performance, parts are available, and everyone knows an ASW so resale shouldn't be difficult.
ASW 19's are still one of the most beautiful fuselage forms in soaring so you'll be looking good on the flightline too
Old October 16th 15, 04:21 PM posted to rec.aviation.soaring
Dan Marotta
My experience has been that gliders with manual control hookups are very
easy to rig, just don't forget to hook up the controls. I think all
that you mention have manual controls. I owned an ASW-19b and it was
very easy to rig. Most of the people here will tell you to get the
glider with the best trailer, but I think the glider is most important.
You will decide that for yourself.
Regarding condition, I would look first for cracks in the finish. I'm
not talking about the normal crazing or cracking that you see in the
finish of older gliders but those which indicate deeper damage. You
would be wise to have someone with experience in these things to help
you with the inspection. Check log book(s) for damage/repair history
but realize that not all damage or repairs will be documented. You'll
have to make a careful inspection.
My personal preference in certification is to get a glider which is
licensed as experimental. There are minor hassles with annual Program
Letters, but these are simple to write and submit. People on this forum
can provide examples. With an experimental glider you have more leeway
with inspections and modifications than with a Standard airworthiness
glider, especially if your manufacturer is no longer in business. Just
be sure that you stay within the regulations.
Good luck in your hunt and welcome back!
Dan
On 10/16/2015 8:51 AM, PAGA wrote:
Hi all,
Dan, 5J
Old October 16th 15, 05:20 PM posted to rec.aviation.soaring
JS
As you're concerned with maintenance, then to me there isn't much of a decision.
Get a 19B if possible.
Old October 16th 15, 05:38 PM posted to rec.aviation.soaring
I loved my 20 and the 19 is a 20 without flaps. You will love the 19 and it will be easier to sell than the others if you ever decide. Best of luck with whatever new ship you get!
Bruno - B4
Old October 16th 15, 08:36 PM posted to rec.aviation.soaring
jfitch
On Friday, October 16, 2015 at 7:51:58 AM UTC-7, PAGA wrote:
Hi all,
I believe the PIK20 came from the factory polyurethane finished. And so may have a better finish than an old gel coated glider. The D model has spoilers, earlier ones had high deflection flaps which are quirky but very effective.
Any of the gliders mentioned are far easier to assembly than any Grob, in my experience.
Old October 18th 15, 09:55 PM posted to rec.aviation.soaring
Blake Seese 3Y
If you can get a good buy on a PIK, they are not a bad plane. Easy to rig, tough, great flying! I bought a B model with the big flaps and love it. It is easy to fly and land and predictable in every way. My second flight in the ship yielded a 535k dry. If the trailer is in good shape, they work just fine. Not as nice as a Cobra or Komet, but sound transportation and storage. It will come down to the plane and the instruments included. You really can't go wrong with the Pik or the 19.
On Friday, October 16, 2015 at 8:51:58 AM UTC-6, PAGA wrote:
Hi all,
ASW19 Inner Tube [email protected] Soaring 1 September 21st 15 03:54 PM
New PIK20/30 group discussion site [email protected] Soaring 0 December 10th 14 06:52 PM
Choosing destinations Mxsmanic Piloting 19 August 28th 08 12:23 AM
PIK20 Winglets P. Corbett Soaring 9 March 30th 07 08:48 AM
Resource for choosing a plane? Douglas Paterson Owning 37 January 8th 06 07:05 AM
