Siemens' 110 lb world-record electric aircraft motor produce 348 hp at 2,500 RPM
Old November 14th 15, 09:38 PM posted to rec.aviation.piloting
Larry Dighera
Default Siemens' 110 lb world-record electric aircraft motor produce 348 hp at 2,500 RPM
http://www.gizmag.com/siemens-world-record-electric-motor-aircraft/37048/
Siemens' world-record electric aircraft motor punches above its weight
COLIN JEFFREY APRIL 20, 2015 7 PICTURES
Researchers working at Siemens say that they have produced an electric
aircraft engine with a claimed ...
Researchers working at Siemens say that they have produced an electric aircraft
engine with a claimed weight-to-performance ratio of 5 kW per kilogram (Photo:
Siemens)
Image Gallery (7 images)
Researchers at Siemens have created a new prototype electric motor specifically
designed for aircraft that weighs in at just 50 kg (110 lb) and is claimed to
produce about 260 kW (348 hp) at just 2,500 RPM. With a quoted power five times
greater than any comparable powerplant, the new motor promises enough grunt to
get aircraft with take-off weights of up to 1,800 kg (2 ton) off the ground.
The motor was developed with the support of the German Aviation Research
Program LuFo as a ... Siemens hopes to see further evolutionary increases to
the power output of their new electric motor ... Researchers also utilized a
range of computer simulation methods to model the motor prior to construction
.... Weighing in at just 50 kilograms (110 lb), a new prototype electric motor
specifically designed for ...
Researchers say they produced such a light but powerful motor by analyzing all
of the components of previous electric aircraft motors and incorporating
optimized improvements to these in their new prototype. Added to this, the
researchers also utilized a range of computer simulation methods to model the
motor prior to construction, before then applying the findings to produce the
lightest and strongest set of components possible.
As a result, the new aircraft electric drive system achieves a claimed
weight-to-performance ratio of 5 kW per kilogram. This ratio is an exceptional
figure – especially if compared to similarly powerful industrial electric
motors used in heavy machinery that produce less than 1 kW per kilogram, or
even to more efficient electric motors for vehicles that generate around 2 kW
per kilogram. The four electric motors in the Solar Impulse 2, by comparison,
produce just 7.5 kW (10 hp) each.
The new Siemens electric motor is also direct drive and does not require a
transmission, spinning a propeller up to speeds of around 2,500 RPM.
"This innovation will make it possible to build series hybrid-electric aircraft
with four or more seats," said Frank Anton, Head of eAircraft at Siemens
Corporate Technology, the company's central research unit. "We're convinced
that the use of hybrid-electric drives in regional airliners with 50 to 100
passengers is a real medium-term possibility."
Siemens has been involved in a range of electric motor driven vehicles,
including a collaboration with Volvo on a fast-charging motor vehicle and with
shipping company Norland for an electrically-driven passenger ferry.
This electric motor innovation, however, may be just the ticket for the
company's joint venture with the Diamond aircraft company, who they supply with
electric fan motors for their DA36 E-Star 2 motor glider. The last one
generated just 60 kW.
The motor, which was developed with the support of the German Aviation Research
Program LuFo as a project of Grob Aircraft and Siemens, is planned to start
in-flight-testing before the end of 2015. Siemens also hopes to see further
evolutionary increases to the power output in the not-too-distant future.
Source: Siemens
Old November 14th 15, 10:14 PM posted to rec.aviation.piloting
Default Siemens' 110 lb world-record electric aircraft motor produce 348hp at 2,500 RPM
Siemens)
figure - especially if compared to similarly powerful industrial electric
Source: Siemens
Electric Airplanes:
More torque
More BHP
Altitude unaffected
Quieter
No plugs
No carburetor
Sustainable
Lighter weight
No messy fluids
As researchers continue to work on creating better
batteries, the logical solution all along was always
the Auxiliary Power Unit for charging.
In an ideal world, there would be a RTG such as NASA
and Russian lighthouses have used for decades. The
Radioisotope Thermoelectric Generators can put out
whopping power from a container the size of a coffee
thermos. Fairly benign from a gamma ray exposure
standpoint, you could keep an electric airplane up
for weeks at a time.
Thanks for the post. I had it in my electric plane
database. Here is the video:
https://www.youtube.com/watch?v=owPUOI6Urg8
Old November 14th 15, 11:51 PM posted to rec.aviation.piloting
Vaughn Simon[_2_]
Well yes that will work (assuming an electric drive train with a
battery) , ...as long as that APU produces significantly MORE power than
the average that you will need at the prop hub. The reason why you
would need MORE power is to make up for the losses inherent in the
generator, motor, battery, and controller.
Sorry, that is just complete nonsense! Forgetting for a moment the
problems with carrying highly radioactive materials in an aircraft, and
forgetting that those materials are so rare and expensive that even few
spacecraft use them these days, RTGs are very inefficient devices. Most
produce, at most, a few hundred watts of electrical power, a tiny
fraction of what a full-sized aircraft would need.
Old November 15th 15, 03:02 AM posted to rec.aviation.piloting
Yes, I said "in a perfect world" (not the current one). While
it's legal to obtain a permit to work with radioactive material,
few can do it, and the FAA wouldn't even consider such. But
then, who says you have to do it in a modern country.
and
They can be obtained for a few planes, but no, you couldn't
mass produce this system. I think you may be surprised at
how easy it is to obtain an isotope on the world market.
that even few
They are still used in every deep space mission.
They are highly efficient. It's just a thermocouple system.
Most
Well yes. I wasn't suggesting attaching the motor itself to
the RTG. I'm saying- if you have a battery bank that may last
say 2 hours stand alone, then having the storage system
permanently connected to this battery charger, depending on
your draw, would be a tremendous extender. It's like having
your battery bank plugged into a wall socket at all times
to an electrical source much stronger than a trickle charger.
Your watt/amp gauge would tell you when to conserve.
And yes, 400 watts would be about max. Really the question is,
"how much electricity can I replace with the charger, as
opposed to what the motor is pulling out of the battery bank".
If you are soaring, you're using no power but it's still
charging.
Old November 15th 15, 03:24 AM posted to rec.aviation.piloting
and
that even few
Most
charging.
I believe an automobile, due to weight and tire friction, requires more power
than a plane. This is just a guess.
"According to the company, their technology would allow you to charge the battery of a Nissan Leaf in 12 minutes instead of four hours. Because that battery has a capacity of 24 kWh, a back-of-the-envelope extrapolation would give us a charging time of 42 minutes for the 85 kWh battery of a top of the line Tesla Model S."
http://www.gizmag.com/dual-carbon-fa...battery/32121/
Old November 15th 15, 04:20 AM posted to rec.aviation.piloting
Also, I forgot to mention that I'm a professional
designer and illustrator, formerly with Lockheed-
Martin. Within this electric airplane concept which
would sustain these very long ranges with an RTG,
is a series of conforming "mini-tanks" which encapsulate major
electrical components. Holding no more than 5 gallons
total, you top them off with liquid nitrogen. This
cryogenic sealed system effectively turns your electrical
system into a zero-resistance super conductor. Control
surfaces are best facilitated with servos and fly by
wire software.
This may sound a little exotic, but other people have
verified the plausibility and science behind it. A
home-build isn't out of the question. With generator,
super conduction, and fast charge NON-lithium batteries,
the range may really be how long you can sit in a seat.
Old November 15th 15, 04:33 AM posted to rec.aviation.piloting
wire software.
Here's some other guys design of the same idea, but EDFs
(electric ducted fans)are less efficient than propellers.
....superconducting machines have already achieved power densities comparable to turbine engines. To fully enable electric flight however, power densities need to improve even further, which is only possible with all-superconducting machines. We developed design concepts for revolutionary aircraft using superconducting machines for propulsion and showed that with further development in superconducting and cryocooling technologies, all within reach, superconductivity- enabled flight could be a reality...
http://www.technovelgy.com/ct/Scienc...p?NewsNum=2712
Old November 16th 15, 11:41 PM posted to rec.aviation.piloting
Just for clarification here, while it would be nice to
have an RTG (especially since it takes 100 years to run
out of charge) obviously for the ordinary man and pilot
this would be difficult. Also, adherence to rules is of
course, foremost. It is however a do-able concept that
doesn't violate the law of energy conservation.
That being said, simply replace that component with a
hydrogen fuel cell. A little different, but people are
doing it and it works for an APU charger. Combined
with quick charge batteries, you'll be fine.
Lastly I want to give an illustration. If you take a
dc light bulb, a 9 volt battery, and say... 50 feet or
more of wire and make the connection, you will either
see no light, or a faint orange glow. Then if you take
that same coil of wire and drop it into a bucket of
liquid nitrogen with the 2 ends hanging out, then connect
the bulb and battery, it will burn as bright white as
the battery touching the bulb itself. This is due to
zero resistance and super conductivity.
Now, being realistic think of an airplane today with
a long wiring harness of several wires. It will be
zip tied to the frame and run through grommets at
points to prevent sheathing penetration. What if we
take that harness and run it through an insulated
metal tubing, with leak-proof ends. Imagine an insertion
point wherein you can inject liquid nitrogen. You
have now just done the same thing as in the above
illustration.
This is just one example of my design that could be
installed in your cryogenic system to achieve super
conductivity. Should the liquid nitrogen warm over an
extended period... it will harmlessly vaporize, and
you'll recharge it as needed.
Old November 20th 15, 11:15 PM posted to rec.aviation.piloting
wire software.
Anyway...
Basic Aircraft Electrical Systems
Some very simple single engine aircraft do not have an electrical system installed. The piston engine is equiped with a Magneto ignition system, which is self powering, and the fuel tank is situated so it will gravity feed the engine. The aircraft is started by means of a flywheel and crank arrangement or by "hand-proping" the engine.
If an electric starter, lights, electric flight instruments, navigation aids or radios are desired, an electrical system becomes a necessity. In most cases, the system will be DC powered using a single distribution bus, a single battery and a single engine driven generator or alternator. Provisions, in the form of an on/off switch, will be incorporated to allow the battery to be isolated from the bus and for the generator/alternator to be isolated from the bus. An ammeter, loadmeter or warning light will also be incorporated to provide an indication of charging system failure. Electrical components will be wired to the bus-bar incorporating either circuit breakers or fuses for circuit protection. Provisions may be provided to allow an external power source such as an extra battery or a Ground Power Unit to be connected to assist with the engine start or to provide power whilst the engine is not running.
Advanced Aircraft Electrical Systems
More sophisticated electrical systems are usually multiple voltage systems using a combination of AC and DC buses to power various aircraft components.. Primary power generation is normally AC with one or more Transformer Rectifier Unit (TRU) providing conversion to DC voltage to power the DC busses. Secondary AC generation from an APU is usually provided for use on the ground when engines are not running and for airborne use in the event of component failure. Tertiary generation in the form of a hydraulic motor or a RAT may also be incorporated into the system to provide redundancy in the event of multiple failures. Essential AC and DC components are wired to specific busses and special provisions are made to provide power to these busses under almost all failure situations. In the event that all AC power generation is lost, a static Inverter is included in the system so the Essential AC bus can be powered from the aircraft batteries.
Robust system monitoring and failure warning provisions are incorporated into the electrical system and these are presented to the pilots when appropriate. Warnings may include, but are not limited to, generator malfuntion/failure, TRU failure, battery failure, bus fault/failure and circuit breaker monitoring. The manufacturer will also provide detailed electrical system isolation procedures to be utilized in the event of an electrical fire.
In compliance with applicable regulations, components such as Standby Flight Instruments and Emergency Floor Lighting have their own backup power supplies and will function even in the event of a complete electrical system failure.
Provisions are virtually always provided for connecting the aircraft electrical system to a fixed or mobile Ground Power Unit.
http://www.skybrary.aero/index.php/A...trical_Systems
Old November 21st 15, 12:03 AM posted to rec.aviation.piloting
wire software.
Anyway...
More sophisticated electrical systems are usually multiple voltage systems using a combination of AC and DC buses to power various aircraft components. Primary power generation is normally AC with one or more Transformer Rectifier Unit (TRU) providing conversion to DC voltage to power the DC busses. Secondary AC generation from an APU is usually provided for use on the ground when engines are not running and for airborne use in the event of component failure. Tertiary generation in the form of a hydraulic motor or a RAT may also be incorporated into the system to provide redundancy in the event of multiple failures. Essential AC and DC components are wired to specific busses and special provisions are made to provide power to these busses under almost all failure situations. In the event that all AC power generation is lost, a static Inverter is included in the system so the Essential AC bus can be powered from the aircraft batteries.
Conductors lose all of their electrical resistance when cooled to super-low temperatures (near absolute zero, about -273o Celsius). It must be understood that superconductivity is not merely an extrapolation of most conductors' tendency to gradually lose resistance with decreasing temperature; rather, it is a sudden, quantum leap in resistivity from finite to nothing. A superconducting material has absolutely zero electrical resistance, not just some small amount.
Superconductivity promises extraordinary capabilities for electric circuits.. If conductor resistance could be eliminated entirely, there would be no power losses or inefficiencies in electric power systems due to stray resistances. Electric motors could be made almost perfectly (100%) efficient. Components such as capacitors and inductors, whose ideal characteristics are normally spoiled by inherent wire resistances, could be made ideal in a practical sense. Already, some practical superconducting conductors, motors, and capacitors have been developed, but their use at this present time is limited due to the practical problems intrinsic to maintaining super-cold temperatures.
http://www.allaboutcircuits.com/text...rconductivity/
Looking for info on world record jet aircraft Ted Parvo Home Built 25 July 17th 12 01:23 PM
Electric motor for hang glider Legend Length Home Built 11 August 27th 09 02:14 AM
electric motor? solarsell Home Built 13 January 12th 07 12:03 AM
Boeing's Electric Taxi Motor Larry Dighera Piloting 43 December 7th 05 05:41 AM
Electric motor assisted super- or turbocharger? Max Kallio Rotorcraft 13 May 9th 05 09:09 PM
