'Canopy Wire Deflector Bars' - Past experience and current thinking
Old December 6th 15, 02:37 PM posted to rec.aviation.soaring
son_of_flubber
Default 'Canopy Wire Deflector Bars' - Past experience and current thinking
I found a few mentions of Canopy Wire Deflector Bars in the RAS Archives. One said that the deflectors were mandatory in the Netherlands. What has been experience and what is current thinking? Links and search terms appreciated as I could not find much with initial google search.
Temporary electric livestock fences are a known landout hazard in my area.
Old December 6th 15, 04:19 PM posted to rec.aviation.soaring
In my 40+ years in the sport I can remember 2 accidents where a wire deflection system would have saved a life. First ship ground looped into 4 strands of barb-wire that broke the canopy, ripped the compass off the hood, then hit the pilot in the forehead and rode up and over his head. Pilot SURVIVED!
In the second accident, the ship landed short of the runway and hit the airport perimeter fence at a point where 2 posts were used to stretch the wires using very strong double wires. Pilot was DECAPITATED!
It's up to each pilot to decide, I would place wire deflectors way down my safety list below parachute, transponder, FLARM, Life insurance, etc. Single strand electric fences are probably survivable.
JJ
Old December 7th 15, 03:00 PM posted to rec.aviation.soaring
The wire deflectors are no longer mandatory in the Netherlands, due to European regulations considering them to be a hinder to free trade inside the European Union (same with yellow car headlights in France). They are rarely installed in newer gliders, and sometimes deleted from older ones. But they did save some lives in the past.
Old December 7th 15, 03:44 PM posted to rec.aviation.soaring
Our towplane (CalAir) was a cropduster in its previous life. It still
has the anti-wire features: wire cutter up the canopy plus a wire from
the top of the cockpit to the top of the rudder (to avoid having a wire
saw off the rudder). The airport owner spent a lot of time dusting
crops and has quite a few wire encounter stories. I heard of two glider-wire
encounters in the past few years here in the SE US: one in Chilhowee in 2011
and one this past fall at Blue Ridge. Both were cases of hitting power lines
in the air. One resulted in no injuries and a repairable glider, and the other
almost killed the pilot and destroyed the plane. Both were fortunate that
the wire broke without hitting the pilot (as I understand it): the Blue Ridge
pilot was injured by the nose-down impact.
Matt
Old December 7th 15, 05:56 PM posted to rec.aviation.soaring
Dan Marotta
Default 'Canopy Wire Deflector Bars' - Past experience and currentthinking
Might have helped he
AccidentoccurredMonday, February 19, 1990inCABINS, WV
Probable Cause Approval Date:09/21/1992
Aircraft:ROLLADEN-SCHNEIDER LS-6, registration:N511M
Injuries: 1 Fatal.
WITNESSES REPORTED SEEING THE GLIDER FLYING NORMALLY AT A LOW ALTITUDE
AND APPEARED AS IF IT WAS GOING TO LAND. DURING THE LANDING APPROACH,
THE GLIDER CONTACTED A POWER LINE WHICH SLICED THROUGH THE CANOPY,
FATALLY INJURING THE PILOT. THE GLIDER THEN DESCENDED TO THE TERRAIN AND
CONTACTED A BARBED WIRE FENCE PRIOR TO COMING TO REST. FLAPS WERE FOUND
IN THE FULL DOWN POSITION AND THE LANDING GEAR WAS EXTENDED. OTHER
PILOTS IN THE AREA REPORTED MODERATE TO SEVERE TURBULENCE AND STRONG
ROTOR ACTIVITY IN THE AREA OF THE ACCIDENT SITE.
The National Transportation Safety Board determines the probable
cause(s) of this accident as follows:
* THE PILOT FAILED TO DETECT AND REMAIN CLEAR OF THE POWER LINE WHICH
CROSSED THE FIELD IN WHICH HE WAS ATTEMPTING TO LAND. CONTRIBUTING
TO THE ACCIDENT WAS THE MODERATE TO SEVERE TURBULENCE IN THE AREA AT
THE TIME OF THE ACCIDENT.
Matt
Dan, 5J
Old December 8th 15, 09:57 AM posted to rec.aviation.soaring
Eric Munk
As mentioned they are no longer mandatory in The Netherlands. They were
introduced in the 1960s I believe after a string of accidents (some fatal).
Since then fields have become a lot bigger, obstacles a lot less and air
traffic a lot busier. We opted to replace all fences around the airport by
ditches, and deleted them from our fleet to improve on look-out. Also,
modern gliders seem less prone to injure pilots compared to the older ones
where the wire would go into the gap of the canopy front (compare K8 line
of fuselage/canopy to discus and you'lle see what I mean).
Old December 6th 15, 04:28 PM posted to rec.aviation.soaring
Tango Eight
Temporary electric livestock fences are a known landout hazard in my area..
You're still in VT?
A field that's used for stock, temporary or otherwise, is basically a place to crash in Northern New England. A farmer doesn't go to the trouble of getting all the rocks out and rolling a field flat to put livestock on it. The exception would be a horse farm. You don't want to land there either, if horses are about.
It's true: if you hit a wire, you're better off with a cage.
But instead of X hours and Y dollars installing a cage, I'd spend X hours on Google Earth and Y dollars on gas learning about fields and planning routes. 95% of our XC flying is with airports or known good landable areas (typically clusters of hay fields) in reach and by and large *the routes aren't random*. The only time we fly "field to field" at 3000 agl is when making an early get away for a 500K+ sort of flight, and those routes are are selected for the purpose.
Evan Ludeman / T8
Old December 6th 15, 07:46 PM posted to rec.aviation.soaring
You're still in VT?
Evan Ludeman / T8
To answer the OP's question, I fly in the NE, I have no issues flying WITHOUT a "wire deflector".
One pilot I fly with (here on RAS) always had a deflector (he's a "little taller" than I....).
"Weigh your odds"..... Sorta like any insurance, gripe when you pay it, hope you don't use it, glad you have it when needed.... mostly....
This from one that "Tango Eight" may give grief to (July 2015 off-field landing)....... LOL...... Hi, say "Hi" to the family....
[So.... T8.... you went how high without a O2 back-up?????.....nudge nudge..... wink wink....]
Old December 6th 15, 11:49 PM posted to rec.aviation.soaring
son_of_flubber
Landowners (not farmers) put electric fence corrals in prime landable hayfields. One new owner put up wires for a small vineyard in a previously used PT3 field close to the airport.
In 2013, a visiting pilot had a electric fence wire ride part way up his canopy. It was still under tension when he stopped. The wire pulled out several fiberglass stakes but was anchored by a long row of stakes.
I'm just curious about wire deflector lore.
Old December 8th 15, 02:45 PM posted to rec.aviation.soaring
gkemp
Jerry Robertson hit a fence between two railroad tie posts in a libelle, in the 1971 or 1923 Nationals in Marfa, Texas, tore his wings off and severely lacerated head and face. Next time he flew he had bars under his canopy to deflect wires.
gkemp
Why aren't bars more common at US soaring sites? JS Soaring 13 November 2nd 15 08:33 PM
UK2 WK520 DHC Chipmunk22 to G-BARS PeterMarchPhoto.jpg Joseph Testagrose Aviation Photos 1 December 22nd 14 05:27 PM
A Few shots of the UA A320 Stars and Bars Retro DV Aviation Photos 2 April 17th 11 09:13 PM
Trailer wind deflector Adam Soaring 17 April 12th 08 07:33 PM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat Home Built 6 October 15th 04 08:51 PM
