Are there any motorgliders that can be logged as complex time?
Old December 21st 15, 07:46 PM posted to rec.aviation.soaring
Chris Snyder
Default Are there any motorgliders that can be logged as complex time?
Power pilots need 10 hours of complex time to earn a commercial rating...could it be done in a motorglider?
Retractable landing gear: CHECK
Controllable pitch prop: CHECK
Flaps: CHECK
Old December 21st 15, 07:55 PM posted to rec.aviation.soaring
Greg Delp
Flaps: CHECK
It's 10 hours required in an airplane not a glider. Uncheck
61.129(a) (3) (ii)
Old December 22nd 15, 07:48 PM posted to rec.aviation.soaring
PGS
Flaps: CHECK
61.129(a) (3) (ii)
It would appear that a motor glider is indeed an airplane by the definitions.
Sec. 1.1 -- General definitions.
Airplane means an engine-driven fixed-wing aircraft heavier than air, that is supported in flight by the dynamic reaction of the air against its wings.
Aircraft means a device that is used or intended to be used for flight in the air.
Old December 22nd 15, 08:00 PM posted to rec.aviation.soaring
Darryl Ramm
Flaps: CHECK
61.129(a) (3) (ii)
What nonsense. A motorglider is registered as type glider, not an airplane.
Old December 22nd 15, 08:15 PM posted to rec.aviation.soaring
PGS
Flaps: CHECK
61.129(a) (3) (ii)
Yes, the FARs are full of "nonsense", what's your point? 61.129 does not say "type", it says airplane. The definition of airplane, according to the FARs is as mentioned above.
Old December 22nd 15, 08:20 PM posted to rec.aviation.soaring
Dan Marotta
Let us know how this works out for you.
Flaps: CHECK
61.129(a) (3) (ii)
Dan, 5J
Old December 21st 15, 07:58 PM posted to rec.aviation.soaring
Darryl Ramm
Flaps: CHECK
Glider CHECK
Airplane NOT CHECK
Old December 21st 15, 09:31 PM posted to rec.aviation.soaring
Chris Snyder
Flaps: CHECK
Glider CHECK
Airplane NOT CHECK
I suppose that makes sense. I just got the notion after helping a friend with the motor brake on his Grob 103. It sounded pretty "complex" to operate while in-flight
Old December 23rd 15, 01:58 AM posted to rec.aviation.soaring
Mark628CA
To expand on Darryl's accurate observations, there are two terms unfortunately often confused and mistakenly used interchangeably by some who have not analyzed the FARs correctly.
There are AIRPLANES and there are AIRCRAFT. These two words look like they should mean the same thing, but they do not. Balloons, gliders, hang gliders, ultralights, hang gliders and a host of other things are AIRCRAFT.
Boeing 787s, Beech Bonanzas, Cirrus 22s, Gulfstream 650s, Cessna Citations and all the other similar flying machines are AIRPLANES.
You cannot get an AIRPLANE rating in an AIRCRAFT.
Although there is a particularly confusing exception involving a turbojet powered two-seat glider (Aircraft) being stuffed into an Airplane category.
I have a Private Pilot Certificate (Glider), but I also have a turbojet rating in Bob Carlton's BonusJet glider (www.desertaerospace.com). Right now, I think I am the only pilot in the world with a turbojet type rating, but no power certificate. I have the certificate in my pocket, but the FAA is still scratching its collective head trying to figure out how this is possible.
It's simple. We read their regulations better than they wrote them.
Old December 23rd 15, 03:01 AM posted to rec.aviation.soaring
SoaringXCellence
When I took my DPE training at the FAA, one of the instructors was fond of saying "it doesn't have to be fair, it doesn't have to make sense, it doesn't have to be right, But it's the regulation"
FLARM data format for contacts logged in IGC files [email protected] Soaring 3 August 11th 15 12:13 AM
Another hour logged Crash Lander[_2_] Piloting 18 March 14th 07 12:47 AM
Simulator for Complex time Steven Barnes Piloting 3 June 10th 06 06:56 PM
Mil Comms Logged in Florida, Friday 9 Apr 2004 AllanStern Military Aviation 0 April 10th 04 07:33 AM
NPR Woman with most logged flight hours vincent p. norris Piloting 6 January 25th 04 08:28 PM
