I have a Logitech joystick in FS2004 and want to use the hat/POV eight-way
switch for looking around (left and right) and for elevator trim. IOW, I want to use the left three and right three positions for view, and the front/back positions for elevator trim. So far, doing that causes the view positions to stick. They are no longer momentary switches which momentarily switch the view. When the POV switch is released, the view remains switched. Is there a way to assign the front/back positions of the POV switch for elevator trim and at the same time use the left and right positions for momentary views? Work arounds are also appreciated. Thanks in advance. -- I will be pleasantly surprised if that is possible. |
Possibly turn the repeat on for the view axis and turn it off for the trim.
Or maybe the other way around.............. "John Doe" wrote in message ... I have a Logitech joystick in FS2004 and want to use the hat/POV eight-way switch for looking around (left and right) and for elevator trim. IOW, I want to use the left three and right three positions for view, and the front/back positions for elevator trim. So far, doing that causes the view positions to stick. They are no longer momentary switches which momentarily switch the view. When the POV switch is released, the view remains switched. Is there a way to assign the front/back positions of the POV switch for elevator trim and at the same time use the left and right positions for momentary views? Work arounds are also appreciated. Thanks in advance. -- I will be pleasantly surprised if that is possible. |
"JD" == "John Doe" writes:
JD I have a Logitech joystick in FS2004 and want to use the hat/POV JD eight-way switch for looking around (left and right) and for JD elevator trim. JD JD IOW, I want to use the left three and right three positions for JD view, and the front/back positions for elevator trim. JD JD So far, doing that causes the view positions to stick. They are JD no longer momentary switches which momentarily switch the view. JD When the POV switch is released, the view remains switched. JD JD Is there a way to assign the front/back positions of the POV JD switch for elevator trim and at the same time use the left and JD right positions for momentary views? JD JD Work arounds are also appreciated. JD JD Thanks in advance. Yes, check the repeat function but what I would do is also check there is no problems with the actual switches sticking by running the diagnostic software for the joystick. -- ======== Thanks..... Jarod |
"Jarod (the puppy)" wrote
"JD" == "John Doe" writes: JD I have a Logitech joystick in FS2004 and want to use the hat/POV JD eight-way switch for looking around (left and right) and for JD elevator trim. JD JD IOW, I want to use the left three and right three positions for JD view, and the front/back positions for elevator trim. JD JD So far, doing that causes the view positions to stick. They are JD no longer momentary switches which momentarily switch the view. JD When the POV switch is released, the view remains switched. JD JD Is there a way to assign the front/back positions of the POV JD switch for elevator trim and at the same time use the left and JD right positions for momentary views? JD JD Work arounds are also appreciated. JD JD Thanks in advance. Yes, check the repeat function but what I would do is also check there is no problems with the actual switches sticking by running the diagnostic software for the joystick. Thanks. I am not sure how but it is working fine now. |
technical question from The Movie | Tag | Naval Aviation | 3 | October 31st 03 04:02 PM |
