Hello
does anyone know how to use the hex editor in AirEd to edit Tbl3D tables. My main problem is, I can't figure out how the hex contents of a table are organised. Thx T. |
![]() "Tom Peel" wrote in message ... Hello does anyone know how to use the hex editor in AirEd to edit Tbl3D tables. My main problem is, I can't figure out how the hex contents of a table are organised. Thx T. AirEd produces the "organization" of the table for you in a matrix form. Click on the item om AirEd's main display, and it will display a matrix with the X-Y axis, and you just fill in a value (Z) into the matrix for each possible x-y pair. There is no need to "edit as hex". The trick is only in knowing what values to enter :-) |
Icebound wrote:
"Tom Peel" wrote in message ... Hello does anyone know how to use the hex editor in AirEd to edit Tbl3D tables. My main problem is, I can't figure out how the hex contents of a table are organised. Thx T. AirEd produces the "organization" of the table for you in a matrix form. Click on the item om AirEd's main display, and it will display a matrix with the X-Y axis, and you just fill in a value (Z) into the matrix for each possible x-y pair. There is no need to "edit as hex". The trick is only in knowing what values to enter :-) looks like I relied too much on the Online Help- it says the "NOTE:It is now possible to edit the first row and column (shown in grey). " Nothing about the other values, but hey, I tried it like you said, and you can edit the other values too! Thanks a lot T |
![]() "Tom Peel" wrote in message ... Icebound wrote: "Tom Peel" wrote in message ... Hello does anyone know how to use the hex editor in AirEd to edit Tbl3D tables. My main problem is, I can't figure out how the hex contents of a table are organised. Thx T. AirEd produces the "organization" of the table for you in a matrix form. Click on the item om AirEd's main display, and it will display a matrix with the X-Y axis, and you just fill in a value (Z) into the matrix for each possible x-y pair. There is no need to "edit as hex". The trick is only in knowing what values to enter :-) looks like I relied too much on the Online Help- it says the "NOTE:It is now possible to edit the first row and column (shown in grey). " Nothing about the other values, but hey, I tried it like you said, and you can edit the other values too! Thanks a lot T That NOTE had to do with that fact that in previous versions, the x-y values, ie: the first row and column were LOCKED...there are the fixed x-y pairs... and you could ONLY edit the rest of the values. In the recent version, you can supposedly ALSO edit the first row and column, but in fact, it is not clear how you are supposed to be able to do that. I can't. |
Machinista 2004 - call for entries | Robb Mitchell Machinista.org | Home Built | 0 | February 24th 04 02:19 PM |
Holding Pattern Entries | Dan Luke | Instrument Flight Rules | 17 | July 11th 03 05:18 AM |
