Hi all,
I just uploaded to the library at Avsim a zip file titled: fa172.zip Get it he http://library.avsim.net/esearch.php...til&DLID=58334 This package is only for use with the Flight Assistant program by Timm Linder located library at Avsim or here. http://www.linder-network.de/thelind...assistant.html This Profile is by Joseph Ranos, (Sonar5) and includes 256 Voice Commands that are all executed with a voice response. Approximately 190+ Execute a MSFS2004 Key command as well as a Voice response. (voice response may be limited if you do not have all programs according to main Flight Assistant website). Approximately 60+ have a response but do not execute a key command. These are used for Cabin Crew Calls, Jokes, and optimized with Cessna 172 Checklists to show you the possibility of what the program is capable of. (for use with Flight Assistant version 2.2 and Microsoft Flight Simulator 2004 ONLY) This package is uploaded to Avsim with the permission of Timm Linder, the author of Flight Assistant, and it may NOT be uploaded to any other site without the written permission of Joseph Ranos. What is included in the Package: 1) fa172readme.pdf This PDF file explains the use of the files, as well a stips before changing anything in the file. 2) fa172.ini This file is the BACKUP configuration file you will have when you create the fa172 folder as advised below. It acts as a backup file in case you delete the original. 3) FlightAssistant.ini This file is an identical file to the fa172.ini above. This is what you will use to replace the original .ini file that came with the program. 4) Fa172voicecommands.pdf A separate PDF File showing all of the Voice Command prompts that can be printed out for reference. These are in order of placement. Subsequent versions will be cleaned up and organized, as I wanted to get this out sooner rather than later. 5) fa172.txt a text file showing a limited amount of info. Please Read the Readme PDF before you install it. Regards, Joe Sonar5 |
Correct Link to download Profile file is he Ignore the first one.
http://library.avsim.net/esearch.php...isc&DLID=58334 Regards, Joe |
Help with MC-1 & Voice | Dave in San Diego | Naval Aviation | 5 | August 24th 03 04:13 AM |
