Hello,
Sme 10 years ago I wrote a program for DOS named "Polar Explorer" - designed for analyzing both theoretical and practical aspects of glider performance in any conditions. The program was advertised in the Soaring magazine for a couple of years by CuSoft Research Inc., and some 30 odd copies sold for USD 99 each. If anyone is interested in this program (see the short description below), I will consider posting it on my current company's website: www.trimill.com Sincerely, Branko Stojkovic ----------------------------- SHORT DESCRIPTION =================== Polar Explorer is designed to answer many `specific` questions about glider performance. As a result, you can use it for many different purposes. The following are a few examples of what you can do: Complement the books and articles on glider performance and soaring tactics by working out practical examples. Find out the `optimum circling technique` for any glider at any altitude and wing loading. Plan and analyze cross-country flights and final glides. Optimize configuration and wing loading in any weather conditions. Apply `generalized speed-to-fly theory` to maximize cross-country performance when using ridge lift or waves. Compare circling and cross-country performances in addition to comparing polars. Design and test speed rings and final glide computers, for any altitude and wing loading. Enter and analyze any glider polar that you come across. The glider polar library that comes with the program already contains 150 polars (see below). If you are contemplating any modifications to your sailplane (e.g. adding winglets), you can use Polar Explorer's advanced features to estimate the performance gains. Polar Explorer 2.1 ? Polar Library ========================= Sources of Polars: (J) Flight Test Evaluations of... by Richard H. Johnson published in the Soaring magazine. (D1) Flugmessungen mit 25 Segelflugzeugen by H. Laurson and H. Zacker, DFVLR Institute, Germany, (1972) (D2) Flugmessungen an 35 Segelflugzeugen und Motorseglern by H. Laurson and H. Zacker, DFVLR Institute, Germany, (1976) (D3) Flugmessungen mit Segelflugzeugen von 12 bis 13 M Spannweite by Hans Zacher, DVL, München-Riem, Germany, (1965) (D*) German Test Data (M) Flight performance measurements on twelve sailplanes by H. J. Merklein and H. Zacher, Scientific Flight Research Establishment Munich , (1964). (C) Calculated polar published by the manufacturer 1. Ahrens Delphin V2 (D3) 2. AK 1 /D KEUL (D2) 3. ASH 25 /N80WK/#4 (J) 4. ASH 26E (C) 5. ASK 13 /D 2018 (D1) 6. ASK 16 /D KEIK (D2) 7. ASK 21 /N362KS/#225 (J) 8. Astir CS /D 7290 (D2) 9. ASW 15 /D 0510 (D1) 10. ASW 15 /D 0791 (D1) 11. ASW 17 /N45JD (J) 12. ASW 17/20m /D 1110 (D2) 13. ASW 17S/21m /D 2119 (D2) 14. ASW 19 /D 4525 (D2) 15. ASW 19 /N19KL (J) 16. ASW 20 /N104WR/#17 (J) 17. ASW 20 [ 9] /N104WR/#17 (J) 18. ASW 20 [8,0] /N104WR/#17 (J) [Flaps +8 & 0 deg] 19. ASW 22/22m /N2702J/#15 (J) 20. ASW 22/24m /N2702J/#15 (J) 21. ASW 24 (D*) 22. ASW 27 (C) 23. Bergfalke II /D 1217 (M) 24. Bergfalke III /D 1737 (D1) 25. Bergfalke IV /D 1005 (D2) 26. Blanik L 13 (C) 27. Bocian /D 1578 (M) 28. Calif A 21 S /D 2176 (D2) 29. Cirrus /D 0471 (D1) 30. Cirrus /D 0471 (D2) 31. Club Libelle /D 3695 (D2) 32. D 34 b Aphrodite/D 4607 (M) 33. D 34 d (D3) 34. D 34 d /D 4607 (M) 35. D 36 V1 /D 4685 (D1) 36. D 37 Artemis /D 2278 (D2) 37. D 37 Artemis /D KEDD (D2) 38. D 38 /D 0938 (D2) 39. DG 300 /N33HB/#E47 (J) [Sealed, clean holes] 40. DG 100 /D 1076 (D2) 41. DG 100 /D 7099 (D2) 42. DG 101 G /N101TX/#E168 (J) 43. DG 200 /N200GA/#2 101 (J) 44. DG 600/15 /N70205 (J) [15m; No winglets] 45. DG 600/15W /N70205 (J) [15m; With winglets] 46. DG 600/17 /N70205 (J) [17m] 47. Discus A /N52XX/#33 (J) [sealed) 48. Discus A [W] /N52XX/#33 (J) [Ballasted] 49. Elfe S3 /HB 902 (D1) 50. Elfe S4 /D 6301 (D2) 51. Elfe S4 /D 6668 (D2) 52. FK 3 /D 0292 (D1) 53. FS 24 Phonix T /D 8385 (M) 54. FS 25 Curevo /D 8141 (D1) 55. FS 29 13.8m /D 2929 (D2) 56. FS 29 16m /D 2929 (D2) 57. FS 29 19m /D 2929 (D2) 58. FS 29 all /D 2929 (D2) 59. Glasflugel 604 /D 8085 (D2) 60. Glasflugel 604 /N57L (J) 61. Glasflugel 604 mod./N57L (J) [Corrected profile] 62. Grob 102 Club IIIb/N3981A (J ) [/#5610 Sealed] 63. Grob 103 Twin II /N427BG (J 64. Grob 103 Twin II mod. (J) [Mod. wheel fairings] 65. Grob 103C Twin III (J) [#34107] 66. Grob 109B /N300BG/#6390 (J) 67. H 101 Salto /D 2040 (D1) 68. H 201 St.Libelle/D 0082 (D1 69. H 301 Libelle /D 9412 (D1) 70. H 401 Kestrel /D 0245 (D1) 71. Hi 25 Kria (D3) 72. Hornet /D 7816 (D2) 73. J 4 Javelin /N5TF (J) 74. Jantar 1 /N46DB (J) 75. Jantar 2A /N980 (J) 76. Jantar Std. /N51AS/#880 (J) 77. Jantar Std. /SE TOI (D2) 78. Jantar Std.2 /N45AS/#863 (J) 79. Janus /D 3111 (D2) 80. Janus /N468F (J) 81. Jaskolka Z O SZD 8ter (M) [FFM /HB 604] 82. K 7 /D 1800 (M) 83. K 8 /D 1590 (M) 84. K 8 KM 48 /D KIBO (D1) 85. Ka 6 BR/S /D 8390 (M) 86. Ka 6 CR (D3) 87. Ka 6 CR /D 1810 (D1) 88. Ka 6 CR /D 1810 (D2) 89. Ka 6 CR /D 4390 (M) 90. Ka 6 E /D 3657 (D) 91. Kestrel /D 0475 (D2) 92. Kestrel 19(T59D)/D 5999 (D2 93. KORA 1 /D KORT (D2) 94. Kranich III /D 1398 (M) 95. LCF 2 /D 6446 (D2) 96. LS 1 C /D 0558 (D1) 97. LS 1 F /D 3252 (D*) 98. LS 1 F /D 3252 (D2) 99. LS 3 /N45EW (J) 100. LS 4 /D 2628 (D*) 101. LS 4 /D 2628; W/S=34.4 (D 102. LS 4 /D 6680 (D*) 103. LS 4A /N274W/#321 (J) 104. LS 4A /N430RH/#384 (J) 105. Mini Nimbus /N871T/#16 (J) [Seals installed] 106. Mistral /D 4998 (D2) 107. Mosquito /N46898 (J) 108. Mu 22 b /D 1848 (D1) 109. Mu 26 /D 0726 {1971} (D1) 110. Mu 26 /D 0726 {1972} (D1) 111. Nimbus 3/22.9 /N49JD/#19 (J) 112. Nimbus 3/24.5 /N49JD/#19 (J) 113. Nimbus 3/24.5 Mod. (J) [Profiled wing] 114. Nimbus II /D 0107 (D1) 115. Nimbus II /D 0699 (D1) 116. Nimbus II /D 2111 (D2) 117. Nimbus II Smooth /N45DJ (J) [Smoothed wings] 118. Phoebus C /D 0559 (D1) 119. Pik 20 A /OY XCR (D2) 120. Pik 20 A.I. /N100DC/#8 (J) [With ail. interconn] 121. Pik 20 B Mod. /N46JD (J) [Mod. wing leading edge] 122. Pik 20 D 78 /N19YZ (J) 123. Pik 20 No AI /N100DC/#8 (J) [No ail. interconn.] 124. Pilatus B4 PC11 /HB 1127(D2 125. RF 5 B Sperber /D KOKS (D2) 126. Sagitta /PH 319 (D1) 127. Salto 15 mod. /D 2220 (D2) 128. SB 10 /D 6085 (D2) 129. SB 8 V2 /D 6085 (D1) 130. SB 9 /D 6085 (D1) 131. Schweizer 1 26E /N33904 (J) [#634] 132. Schweizer 1 35 /N17976 (J) 133. Schweizer 1 36 /N362IT (J) 134. SF 27 A /D 6068 (D1) 135. SF 28 Tandem /D KFAJ (D2) 136. SF 30 Club Spatz /D 3697(D2 137. Skylark 3 F /RAF 146 (M) 138. Std. Cirrus /D 0483 (D1) 139. Std. Cirrus /D 3261 (D2) 140. Std. Cirrus B /N5CC (J) 141. Std. Cirrus/16m /D 3261 (D2 142. SZD 30 Pirat /D 3660 (D1) 143. SZD 55 1 /N3176T (J) 144. Vega /N3751Q/#1927 (J) 145. Ventus A /N47JD/#29 (J) 146. Ventus A/16.6 (J) [Original wing] 147. Ventus A/16.6 Mod. (J) [Profiled wing] 148. Ventus B /N139P (J) 149. Zuni /N14XZ/#14 (J) 150. Zuni [ 8.8] /N14XZ/#14 (J) [Flaps 8.8 deg]) 151. Zuni [0] /N14XZ/#14 (J) [Flaps 0 deg]) |
Branko,
Do you know if it will run correctly under the "DOS Window" of various flavours of Windows, or does it need a pure DOS environment ? John G. "Branko Stojkovic" wrote in message . .. | Hello, | | Sme 10 years ago I wrote a program for DOS named "Polar Explorer" - designed | for analyzing both theoretical and practical aspects of glider performance | in any conditions. The program was advertised in the Soaring magazine for a | couple of years by CuSoft Research Inc., and some 30 odd copies sold for USD | 99 each. | | If anyone is interested in this program (see the short description below), I | will consider posting it on my current company's website: www.trimill.com | | Sincerely, | | Branko Stojkovic | | ----------------------------- | | SHORT DESCRIPTION | =================== | Polar Explorer is designed to answer many `specific` questions about glider | performance. As a result, you can use it for many different purposes. The | following are a few examples of what you can do: | | Complement the books and articles on glider performance and soaring tactics | by working out practical examples. | | Find out the `optimum circling technique` for any glider at any altitude and | wing loading. | | Plan and analyze cross-country flights and final glides. | | Optimize configuration and wing loading in any weather conditions. | | Apply `generalized speed-to-fly theory` to maximize cross-country | performance when using ridge lift or waves. | | Compare circling and cross-country performances in addition to comparing | polars. | | Design and test speed rings and final glide computers, for any altitude and | wing loading. | | Enter and analyze any glider polar that you come across. The glider polar | library that comes with the program already contains 150 polars (see below). | | If you are contemplating any modifications to your sailplane (e.g. adding | winglets), you can use Polar Explorer's advanced features to estimate the | performance gains. | | Polar Explorer 2.1 ? Polar Library | ========================= | | Sources of Polars: | | (J) Flight Test Evaluations of... by Richard H. Johnson published in the | Soaring magazine. | | (D1) Flugmessungen mit 25 Segelflugzeugen by H. Laurson and H. Zacker, DFVLR | Institute, Germany, (1972) | | (D2) Flugmessungen an 35 Segelflugzeugen und Motorseglern by H. Laurson and | H. Zacker, DFVLR Institute, Germany, (1976) | | (D3) Flugmessungen mit Segelflugzeugen von 12 bis 13 M Spannweite by Hans | Zacher, DVL, München-Riem, Germany, (1965) | | (D*) German Test Data | | (M) Flight performance measurements on twelve sailplanes by H. J. Merklein | and H. Zacher, Scientific Flight Research Establishment Munich , (1964). | | (C) Calculated polar published by the manufacturer | | 1. Ahrens Delphin V2 (D3) | 2. AK 1 /D KEUL (D2) | 3. ASH 25 /N80WK/#4 (J) | 4. ASH 26E (C) | 5. ASK 13 /D 2018 (D1) | 6. ASK 16 /D KEIK (D2) | 7. ASK 21 /N362KS/#225 (J) | 8. Astir CS /D 7290 (D2) | 9. ASW 15 /D 0510 (D1) | 10. ASW 15 /D 0791 (D1) | 11. ASW 17 /N45JD (J) | 12. ASW 17/20m /D 1110 (D2) | 13. ASW 17S/21m /D 2119 (D2) | 14. ASW 19 /D 4525 (D2) | 15. ASW 19 /N19KL (J) | 16. ASW 20 /N104WR/#17 (J) | 17. ASW 20 [ 9] /N104WR/#17 (J) | 18. ASW 20 [8,0] /N104WR/#17 (J) [Flaps +8 & 0 deg] | 19. ASW 22/22m /N2702J/#15 (J) | 20. ASW 22/24m /N2702J/#15 (J) | 21. ASW 24 (D*) | 22. ASW 27 (C) | 23. Bergfalke II /D 1217 (M) | 24. Bergfalke III /D 1737 (D1) | 25. Bergfalke IV /D 1005 (D2) | 26. Blanik L 13 (C) | 27. Bocian /D 1578 (M) | 28. Calif A 21 S /D 2176 (D2) | 29. Cirrus /D 0471 (D1) | 30. Cirrus /D 0471 (D2) | 31. Club Libelle /D 3695 (D2) | 32. D 34 b Aphrodite/D 4607 (M) | 33. D 34 d (D3) | 34. D 34 d /D 4607 (M) | 35. D 36 V1 /D 4685 (D1) | 36. D 37 Artemis /D 2278 (D2) | 37. D 37 Artemis /D KEDD (D2) | 38. D 38 /D 0938 (D2) | 39. DG 300 /N33HB/#E47 (J) [Sealed, clean holes] | 40. DG 100 /D 1076 (D2) | 41. DG 100 /D 7099 (D2) | 42. DG 101 G /N101TX/#E168 (J) | 43. DG 200 /N200GA/#2 101 (J) | 44. DG 600/15 /N70205 (J) [15m; No winglets] | 45. DG 600/15W /N70205 (J) [15m; With winglets] | 46. DG 600/17 /N70205 (J) [17m] | 47. Discus A /N52XX/#33 (J) [sealed) | 48. Discus A [W] /N52XX/#33 (J) [Ballasted] | 49. Elfe S3 /HB 902 (D1) | 50. Elfe S4 /D 6301 (D2) | 51. Elfe S4 /D 6668 (D2) | 52. FK 3 /D 0292 (D1) | 53. FS 24 Phonix T /D 8385 (M) | 54. FS 25 Curevo /D 8141 (D1) | 55. FS 29 13.8m /D 2929 (D2) | 56. FS 29 16m /D 2929 (D2) | 57. FS 29 19m /D 2929 (D2) | 58. FS 29 all /D 2929 (D2) | 59. Glasflugel 604 /D 8085 (D2) | 60. Glasflugel 604 /N57L (J) | 61. Glasflugel 604 mod./N57L (J) [Corrected profile] | 62. Grob 102 Club IIIb/N3981A (J ) [/#5610 Sealed] | 63. Grob 103 Twin II /N427BG (J | 64. Grob 103 Twin II mod. (J) [Mod. wheel fairings] | 65. Grob 103C Twin III (J) [#34107] | 66. Grob 109B /N300BG/#6390 (J) | 67. H 101 Salto /D 2040 (D1) | 68. H 201 St.Libelle/D 0082 (D1 | 69. H 301 Libelle /D 9412 (D1) | 70. H 401 Kestrel /D 0245 (D1) | 71. Hi 25 Kria (D3) | 72. Hornet /D 7816 (D2) | 73. J 4 Javelin /N5TF (J) | 74. Jantar 1 /N46DB (J) | 75. Jantar 2A /N980 (J) | 76. Jantar Std. /N51AS/#880 (J) | 77. Jantar Std. /SE TOI (D2) | 78. Jantar Std.2 /N45AS/#863 (J) | 79. Janus /D 3111 (D2) | 80. Janus /N468F (J) | 81. Jaskolka Z O SZD 8ter (M) [FFM /HB 604] | 82. K 7 /D 1800 (M) | 83. K 8 /D 1590 (M) | 84. K 8 KM 48 /D KIBO (D1) | 85. Ka 6 BR/S /D 8390 (M) | 86. Ka 6 CR (D3) | 87. Ka 6 CR /D 1810 (D1) | 88. Ka 6 CR /D 1810 (D2) | 89. Ka 6 CR /D 4390 (M) | 90. Ka 6 E /D 3657 (D) | 91. Kestrel /D 0475 (D2) | 92. Kestrel 19(T59D)/D 5999 (D2 | 93. KORA 1 /D KORT (D2) | 94. Kranich III /D 1398 (M) | 95. LCF 2 /D 6446 (D2) | 96. LS 1 C /D 0558 (D1) | 97. LS 1 F /D 3252 (D*) | 98. LS 1 F /D 3252 (D2) | 99. LS 3 /N45EW (J) | 100. LS 4 /D 2628 (D*) | 101. LS 4 /D 2628; W/S=34.4 (D | 102. LS 4 /D 6680 (D*) | 103. LS 4A /N274W/#321 (J) | 104. LS 4A /N430RH/#384 (J) | 105. Mini Nimbus /N871T/#16 (J) [Seals installed] | 106. Mistral /D 4998 (D2) | 107. Mosquito /N46898 (J) | 108. Mu 22 b /D 1848 (D1) | 109. Mu 26 /D 0726 {1971} (D1) | 110. Mu 26 /D 0726 {1972} (D1) | 111. Nimbus 3/22.9 /N49JD/#19 (J) | 112. Nimbus 3/24.5 /N49JD/#19 (J) | 113. Nimbus 3/24.5 Mod. (J) [Profiled wing] | 114. Nimbus II /D 0107 (D1) | 115. Nimbus II /D 0699 (D1) | 116. Nimbus II /D 2111 (D2) | 117. Nimbus II Smooth /N45DJ (J) [Smoothed wings] | 118. Phoebus C /D 0559 (D1) | 119. Pik 20 A /OY XCR (D2) | 120. Pik 20 A.I. /N100DC/#8 (J) [With ail. interconn] | 121. Pik 20 B Mod. /N46JD (J) [Mod. wing leading edge] | 122. Pik 20 D 78 /N19YZ (J) | 123. Pik 20 No AI /N100DC/#8 (J) [No ail. interconn.] | 124. Pilatus B4 PC11 /HB 1127(D2 | 125. RF 5 B Sperber /D KOKS (D2) | 126. Sagitta /PH 319 (D1) | 127. Salto 15 mod. /D 2220 (D2) | 128. SB 10 /D 6085 (D2) | 129. SB 8 V2 /D 6085 (D1) | 130. SB 9 /D 6085 (D1) | 131. Schweizer 1 26E /N33904 (J) [#634] | 132. Schweizer 1 35 /N17976 (J) | 133. Schweizer 1 36 /N362IT (J) | 134. SF 27 A /D 6068 (D1) | 135. SF 28 Tandem /D KFAJ (D2) | 136. SF 30 Club Spatz /D 3697(D2 | 137. Skylark 3 F /RAF 146 (M) | 138. Std. Cirrus /D 0483 (D1) | 139. Std. Cirrus /D 3261 (D2) | 140. Std. Cirrus B /N5CC (J) | 141. Std. Cirrus/16m /D 3261 (D2 | 142. SZD 30 Pirat /D 3660 (D1) | 143. SZD 55 1 /N3176T (J) | 144. Vega /N3751Q/#1927 (J) | 145. Ventus A /N47JD/#29 (J) | 146. Ventus A/16.6 (J) [Original wing] | 147. Ventus A/16.6 Mod. (J) [Profiled wing] | 148. Ventus B /N139P (J) | 149. Zuni /N14XZ/#14 (J) | 150. Zuni [ 8.8] /N14XZ/#14 (J) [Flaps 8.8 deg]) | 151. Zuni [0] /N14XZ/#14 (J) [Flaps 0 deg]) | | |
Commercial polar routes? | General Aviation | 6 | January 28th 05 08:03 PM | |
Jon Johanson..Long delete if not interested | Jerry Springer | Home Built | 0 | December 21st 03 05:55 PM |
LX 1000 polar calibration | Vignaud Frédéric | Soaring | 0 | July 14th 03 05:14 PM |
