Has any one heard of using a Champs, Cubs, Luscombs or Cessna 120/140
for tow operations for antique gliders like a franklin. I am in search of a tow plane that can fly at 50 miles per hour or less. |
![]() "mjacob" wrote in message om... Has any one heard of using a Champs, Cubs, Luscombs or Cessna 120/140 for tow operations for antique gliders like a franklin. I am in search of a tow plane that can fly at 50 miles per hour or less. You might try one of the hang glider flight parks. The Dragonflies and trikes will fly very slowly. I'm not sure of the legality of an ultralight towing a registered aircraft, but they should go as slow as you need. Tim Ward |
A neighbour club uses a Husky to tow a Grunau Baby, I think with flaps
extended. They say that's on the edge. Stefan |
I've towed a Primary with a Rallye 180T. I was flying the Rallye at an
indicated 45 knots. The Primary pilot told me that it was too slow! It turns out that the Rallye's ASI over reads at low airspeeds. The true airspeed was nearer 35 knots! With full flaps and the leading edge slats out, the Rallye was reasonably easy to control. With the extreme nose up attitude, forward visibility was non-existant. Needs to be done on a reasonably cool day to avoid overheating. |
Nearly ideal towing machines for antique gliders are Touring Motor Gliders
as Falks, Dimonas and similar. They are able to fly slow, makes less noise and uses less fuel. George "mjacob" wrote in message om... Has any one heard of using a Champs, Cubs, Luscombs or Cessna 120/140 for tow operations for antique gliders like a franklin. I am in search of a tow plane that can fly at 50 miles per hour or less. |
I have recently been doing some towing behind a J-3 cub with a 90 hp.
motor. Works great and he can fly about 40 knots. He does have a little concern about overheating but we haven't had any trouble. He said he could only climb about 1500' pulling a Ka-7 before temps got too high. My experience flying a Cessna 140 is that it wouldn't be able to fly any slower than more common towplanes. |
Look at the Vintage Sailplane Association website for info and addresses
http://www.vintagesailplane.org/ Jan Scott tows vintage gliders with his motor Falke off his grass strip. Bob Gaines has a variety of old gliders, including a 1939 Kirby Kite and a Schleicher Ka-3 which are both on skids. David Schuur is familiar with the vintage gliders at Lawrenceville, IL, including a couple of Grunau Babies. Any of these gentlemen should be able to help you. Good Luck, Neal Pfeiffer mjacob wrote: Has any one heard of using a Champs, Cubs, Luscombs or Cessna 120/140 for tow operations for antique gliders like a franklin. I am in search of a tow plane that can fly at 50 miles per hour or less. |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | December 1st 03 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
