Canopy Ejection and Canopy Lanyard
Old April 11th 16, 10:36 PM posted to rec.aviation.soaring
Casey[_2_]
Default Canopy Ejection and Canopy Lanyard
Does anyone un-secure their canopy lanyard prior to take off? Just wondering if the lanyard would break during a canopy ejection or if the lanyard would cause the canopy to whirl about and pop the pilot in the head. Mine and others I've seen have a clip on at least one end.
Old April 12th 16, 01:24 AM posted to rec.aviation.soaring
It will break. Believe me.
Old April 12th 16, 12:57 PM posted to rec.aviation.soaring
Casey[_2_]
My first inclination is that it will break, but then I look at the development of the Roeger Hook. How many gliders were manufactured with front hinged canopies prior to the Roeger Hook? Then I think of how slow a glider may be traveling in a flat spin or whatever. There are not that many bail outs and it just takes one pilot to get hit in the head.
I think its a valid question, as well as valid to the sequence to a bail out. Does everyone use a static line on their chute in case of hit unconscious before clearing glider? And is the sequence to unbuckle then jettison canopy or vice versa? The stories I've read about those bailing out is jettison canopy first. I have heard to put hands over head and push on canopy, but from what I've read, this is to ensure suction release of canopy and not really for head protection. In training or any other articles, does anyone iterate to push up on canopy and protect head?
Old April 12th 16, 02:29 PM posted to rec.aviation.soaring
Tip I learned from Roy Cundiff. Cross your arms when lifting the canopy so as not to get hit in the face like he did.
Canopy first, then belts.
UH
Old April 12th 16, 03:27 PM posted to rec.aviation.soaring
Casey[_2_]
Why not belts first then canopy. If canopy hits pilot in the head and knocks unconscious then may have chance to fall out of glider and static line pull chute handle. Do glider pilots use static line on chute or is this an aerobatic thing?
Old April 12th 16, 03:54 PM posted to rec.aviation.soaring
Matt Herron Jr.
If you release belts first, you may be thrown or pinned by rotation in such a way that the canopy levers can't be reached. You may also be blown through the canopy without release! I don't use a static line as I want the ability to decide if I am clear of wreckage before I pull.
Matt
HP-14 Canopy [email protected] Soaring 0 July 4th 11 05:00 PM
Ka6 cr canopy mod. Rob Shepherd Soaring 0 October 13th 10 05:13 PM
LS-1C canopy mod Brad Soaring 4 September 14th 05 04:14 PM
Canopy Yosimite Sam Home Built 4 November 21st 04 12:35 AM
K8 Canopy Jack Wyman Soaring 0 June 9th 04 08:36 PM
