Temp and Dewpoint logger
Old April 19th 16, 10:18 PM posted to rec.aviation.soaring
Soartech
Default Temp and Dewpoint logger
This might be fun to have on a long flight. You could log air temp and dewpoint and compare with your vario trace or GPS track. It's only $39 and sends data wirelessly to a smart phone app.
http://www.mouser.com/ProductDetail/...%252bU 0RY%3d
Datasheet PDF he
http://www.mouser.com/ds/2/682/sensi...1_D-780421.pdf
Old April 20th 16, 02:55 PM posted to rec.aviation.soaring
Datasheet PDF he
You can also stick it into your glider trailer for a week and see if condensation is likely to occur inside (temperature and dew point are the same).
Herb
Cherokee 140 Oil Temp Sender Mike Spera[_2_] Owning 3 July 11th 10 04:44 AM
Cherokee 140 Oil Temp Creeping Up Mike Spera Owning 9 June 12th 09 09:02 PM
C182 Oil Temp Steve Leonard Soaring 1 October 8th 07 10:33 PM
carburator temp sensor Philippe Vessaire Home Built 0 May 14th 06 04:35 PM
Cessna 172 Oil Temp Darrel Toepfer Owning 10 June 26th 05 04:04 PM
