Hi all in US-glider land!
I am in the process of installing my brand new core and intend to use the Dsub9 connector for power. Can anyone confirm which color cable is connected to pin 7 (+) and pin 5 (-)? Why do they keep that such a secret - the manual does not give a hint? I paid good money for it and don't want to let out the magic smoke the first time I turn it on. Thanks, Uli |
On Saturday, April 23, 2016 at 5:42:59 PM UTC-4, JS wrote:
Hello Uli: Try this link. Jim http://clearnav.net/FLARM/FLARM_Connect-Final.pdf Just do a continuity check (beeps on my multimeter) on pin 7 and 5 against all the colours. I have had a number of cables (do club installs) with various colours - even from the same distributor, bought at the same time. I do it every time, just to avoid all that smoke coming out. Takes a moment. |
On my cable it is:
Yellow = ground Blue = +12v power However, I would recommend using a meter to double check your cable before applying any power. Robert On Saturday, April 23, 2016 at 3:46:43 PM UTC-5, AS wrote: Hi all in US-glider land! I am in the process of installing my brand new core and intend to use the Dsub9 connector for power. Can anyone confirm which color cable is connected to pin 7 (+) and pin 5 (-)? Why do they keep that such a secret - the manual does not give a hint? I paid good money for it and don't want to let out the magic smoke the first time I turn it on. Thanks, Uli |
On Saturday, April 23, 2016 at 4:46:43 PM UTC-4, AS wrote:
Hi all in US-glider land! I am in the process of installing my brand new core and intend to use the Dsub9 connector for power. Can anyone confirm which color cable is connected to pin 7 (+) and pin 5 (-)? Why do they keep that such a secret - the manual does not give a hint? I paid good money for it and don't want to let out the magic smoke the first time I turn it on. Thanks, Uli Thanks, guys! Metering 'yellow & blue' it is. The ClearNav link is also very helpful! Would be nice if FLARM could standardize the wiring harness and publish what is what! Just imagine selling a consumer electronics product and leave the customer guessing .... Uli |
The early PF Brick manuals had a chart
matching DB9 wire colors to pins, but Flarm discovered that suppliers silently changed them around; so removed the chart from the manual. Yep, you have to use a meter to match colors to pins. |
Not sure which manual your looking at but if you download the one he
http://flarm.com/support/manuals-documents/ It show all the pin outs (pages 11-12) and color chart for DB connector (page 13) To answer your question white = ground red = 12V power supply. Good luck, just finished my install yesterday. |
On Sunday, April 24, 2016 at 10:54:26 AM UTC-4, Karl Kunz wrote:
Not sure which manual your looking at but if you download the one he http://flarm.com/support/manuals-documents/ It show all the pin outs (pages 11-12) and color chart for DB connector (page 13) To answer your question white = ground red = 12V power supply. Good luck, just finished my install yesterday. Karl, I was looking at the manual that came with the unit and it does not show the colors. I metered the pins and you are correct, red is +12V, white is - or ground. Thanks, Uli |
On Fri, 29 Apr 2016 20:35:37 -0700, AS wrote:
On Sunday, April 24, 2016 at 10:54:26 AM UTC-4, Karl Kunz wrote: Not sure which manual your looking at but if you download the one he http://flarm.com/support/manuals-documents/ It show all the pin outs (pages 11-12) and color chart for DB connector (page 13) To answer your question white = ground red = 12V power supply. Good luck, just finished my install yesterday. Karl, I was looking at the manual that came with the unit and it does not show the colors. I metered the pins and you are correct, red is +12V, white is - or ground. Thanks, Uli The best way to handle the color-code issue, particularly if you're using the RS-232 data lines, is to take the supplied cut cable and drop it in a trash can. Get a M/F extension cable of appropriate length, and connect it to a cheap RS-232 to TTL converter with male pins. Note that pins 2, 3, and 5 are conventional usage for 9 pin RS-232, other pins are N/C for the converter. You'll have a neat little bulkhead connector that can mount on a junction box, and the RS-232 lines are converted to TTL for you. Put a little jumper from pin 8 to VCC on the converter to power it, and whatever other circuitry you want with +5 from FLARM. Then you just have to send +12 out to the FLARM on pin 7. Much nicer than trying to solder those flimsy little wires in the cut cable. -Dave |
PowerFlarm Core + Libelle 301 | Kevin Christner | Soaring | 11 | December 25th 15 04:50 PM |
PowerFlarm Core and RS232 | Tom Roth | Soaring | 3 | May 28th 15 11:09 PM |
Flarmview and Powerflarm Core Config File? | Papa3[_2_] | Soaring | 4 | May 18th 15 10:51 PM |
For Sale - Used PowerFLARM Core v1 | Paul Remde | Soaring | 1 | May 30th 14 03:09 AM |
Powerflarm Brick/Core ADSB Range | Sean F (F2) | Soaring | 3 | September 5th 13 03:10 PM |
