Which Logger?
Old August 25th 03, 08:56 PM
tango4
Default Which Logger?
Aircraft - Ventus Bt, Asw 20 bl and Libelle.
Logger / Vario - Colibri and Lx160 ( now a 160s )
Opinion - 8/10
Plusses - Reasonably simple to use. Reliable, plenty memory
Minus - can't set task and/or active TP in flight via RS232 interface
without redeclaration ocurring
Volkslogger / Borgelt B50
Opinion 8/10
Minus - Memory overflows and cocks up logging
Plus - more functionality on RS232 interface.
Ian
"Kevin Neave" k wrote in
message ...
Anyone out there got any views on the pros & cons of
the Colibri vs Volkslogger?
They're about the same price / size etc.
Anyone used both & have a preference?
(I'll probably end up connecting the logger to an LX160s
vario & a PDA running the free version of Cambridge
PC-Nav)
Cheers
Old August 25th 03, 11:23 PM
Chip Fitzpatrick
I had the Colibri and the LX160 in a 19B. They work very well together.
Chip Fitzpatrick
N127KK
Old September 9th 03, 04:45 PM
Mzsoar
anyone had any experience with the EW looger. It's about half the price of the
others.
__Mike
Old September 9th 03, 05:15 PM
Tim
Tim s comments read:
(Mzsoar)s comments read:
others.
__Mike
They are OK if you operate them correctly ... as the internal battery
can run flat very quickly. The don't have any ENL recording so are not
suitable in Turbos/Self Launchers.
And I should have added - they need an external GP source so there is
a bit more wiring than say a Colibri or Volkslogger
Tim - ASW20CL "20"
Old September 10th 03, 03:12 AM
Pete Brown
others.
__Mike
I use an EW B model in my self launcher and its easy. The EW
has leads for a motor contact switch that you can hook up.
The internal battery lasts plenty long unless you set a
rediculously short data point interval.
Peter D. Brown
http://home.gci.net/~pdb/
http://groups.yahoo.com/group/akmtnsoaring/
Old September 10th 03, 11:46 AM
Tim
Tim Newport-Peace ]s comments read:
X-no-archive: yes
In article , Tim tim_spam_d
writes
others.
__Mike
Firstly, the latest model (D) can run on external power.
Although the D will run from internal power if it is turned on and
_then_ connected to external power. Just make sure you do it the
correct way round
Tim - ASW20CL "20"
Old September 9th 03, 06:38 PM
rhpf
Most other loggers include a GPS the EW does not and has to be used with a
specified GPS for ICG approved flights.
Richard
www.craggyaero.com
"Mzsoar" wrote in message
of the
others.
__Mike
Old September 10th 03, 01:04 AM
G.A. Seguin
"rhpf" wrote in message ...
Richard
www.craggyaero.com
of the
others.
__Mike
Hi,
I use a EW since 1997, B model. Battery is not a problem, one 9 volts
every
3 month/40 to 50 hours. Latest D model can take outside power with
internal battery back-up.
With Garmin 12 is half price of GPSNAV, same service.
Gilles
Silver Badge Fun (?) Mark Zivley Soaring 43 July 14th 03 07:52 PM
