FAA proposes AD on Schempp-Hirth Discus 2 and Ventus 2
Old April 27th 16, 02:33 PM posted to rec.aviation.soaring
Mark628CA
Default FAA proposes AD on Schempp-Hirth Discus 2 and Ventus 2
Proposed AD addresses an issue with the airbrakes on S-H Discus 2a, 2b, 2c, 2ctx and Ventus 2a, 2b.
Doesn't look unreasonable- an inspection and possible parts upgrade to address a possible problem with airbrake retraction. Comment period is still open.
https://www.federalregister.gov/arti...alregister.gov
Old April 27th 16, 02:35 PM posted to rec.aviation.soaring
Mark628CA
Comment period ends 06/13/2016
Old April 27th 16, 06:39 PM posted to rec.aviation.soaring
I just checked my D-2 and she has 5mm overlap on her spoiler plates, minimum is 3mm. With zero overlap, air loads could force one plate under the other and thereby lock both spoilers in the full open position.........don't you just hate it when that happens?
The G-103 had something similar where wear in the spoiler stops allowed the spoiler plate to extend above the wing skin. Air loads could then shove the plate aft, leaving it on top of the wing and..............the spoilers could not be retracted! This came to light when an American Airlines Captain who was moonlighting as a ride pilot at Truckee, found himself facing the cliff with both spoilers stuck wide open! Kool-Hand-Luke, kept his speed up and did a "bird-purch" onto the cliff! He and his passenger both walked away!
JJ
Old April 27th 16, 06:48 PM posted to rec.aviation.soaring
Dave Nadler
On Wednesday, April 27, 2016 at 1:39:22 PM UTC-4, wrote:
...air loads could force one plate under the other and thereby lock
The G-103 had something similar...
Also LS-6, and I think maybe a couple others...
Old April 27th 16, 11:43 PM posted to rec.aviation.soaring
Bill T
LS-4 too I think.
Old May 7th 16, 11:37 PM posted to rec.aviation.soaring
WaltWX[_2_]
Discus 2A "WX" N53LK SN:32
Left Wing Inboard: 4mm Outboard 9mm
Right Wing Inboard:6.5mm Outboard 8mm
I'm good! Minimum is 3mm
Walt Rogers WX
Old May 8th 16, 05:05 AM posted to rec.aviation.soaring
Michael Opitz
Walt Rogers WX
Discus-2b "RO" is good too... 5-8 mm overlap everywhere.
I saw where the EASA is proposing to make it an inspection
by owner thing, at least to check the overlap. If it were to be
out of tolerance, fixing it would be another matter.
Old May 8th 16, 12:48 PM posted to rec.aviation.soaring
Eric Munk
Not just proposing. See http://ad.easa.europa.eu/ad/2016-0027R1
EASA AD 2016-0027R1 superseded the original AD 2016-0027 after only 8 days.
R1 changed this from a LAME-inspection only to allow a Pilot-Owner
inspection to comply.
Schempp-Hirth Discus Forum Scott[_9_] Soaring 0 January 19th 12 05:03 PM
Schempp-Hirth Discus Google Group Scott[_9_] Soaring 0 December 7th 11 04:02 PM
FS: Schempp-Hirth Discus A Tim Hanke Soaring 0 February 19th 06 02:16 PM
4SALE: Schempp-Hirth Ventus B Pat Russette Soaring 0 September 6th 05 03:24 AM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
