18m Discus
Old September 7th 03, 02:39 PM
Burt Compton
Default 18m Discus
From "Aerokurier": Discus 2c with 18m wingspan.
Schempp-Hirth is another manufacturer to be now stretching the wings in the
Standard Class. The Discus 2 is to be available in future in a combination
version with both 15m and 18m wingspan. Work is set to start on building the
first wing after the summer closedown. The maiden flight is expected to take
place in the spring of 2004.
The wing contour of the new Discus 2c has been optimised for both wingspan
versions. As a result, the separation point is located further inboard (as on
the Ventus 2), at the point where the flaperon is presently split on the Discus
2a/b. Although there is no change in layout compared with the Discus 2a/b, with
short tip extensions featuring once again, the layout of the large outboard
wing section for the 18m version resembles the Duo Discus, with swept-back
trailing edge.
Old September 8th 03, 10:52 AM
John Galloway
At 18:48 07 September 2003, Bob Kuykendall wrote:
I wonder what definition of 'optimize' they're using,
No idea - but as long as its the same one as the have
used for their other designs it will do for me:-)
John Galloway
Discus 2A Sam Giltner Soaring 1 August 31st 03 06:37 AM
Discus Wing question John Galloway Soaring 6 August 23rd 03 07:52 AM
DUO DISCUS GROUNDED AS OF 31 JULY 2003 Eric van Geetsum Soaring 20 August 18th 03 09:23 PM
Looking for used Discus CS STUART SCHWARTZ Soaring 2 August 12th 03 10:38 PM
Duo Discus Tech note Thomas Knauff Soaring 25 August 9th 03 10:10 PM
