Looking for headrest assy for ASW-20
Gene (714) 330 1598 |
On 7/27/2016 9:37 PM, GeneReinecke wrote:
Looking for headrest assy for ASW-20 Gene (714) 330 1598 If a generic headrest will do, Google the term "recumbent bicycle headrest" The riding position of recumbent bikes is similar to some sailplanes. Here is one manufacturer of a very light yet functional bicycle headrest: http://www.ademhr.com/index.html |
On Wednesday, July 27, 2016 at 8:37:09 PM UTC-5, GeneReinecke wrote:
Looking for headrest assy for ASW-20 Gene (714) 330 1598 You can order an 80's Mercedes SL headrest on ebay. the posts fit perfectly between the shoulder belt brackets. I did that until I made my own with aluminum and a travel pillow. Jordan |
Whether you make or buy, give some thought to safety. I believe it was A.J. Smith who escaped a skull injury in a bad landing with wet wings on the last day at the Worlds in '72 in Yugoslavia. The Nimbus II headrest had one or two steel brackets buried beneath the padding and when his head hit the headrest, they emerged.
I removed a bracket on the factory metal frame of my LS-3 headrest. I believe it was there to mount a mike but I thought it could be a crash hazard.. My ASW 24 came over without a seatback/headrest (in order to get me in the cockpit) but I wanted something under my head in case of a hard flat impact.. I was advised not to use soft, bouncy foam padding because that would tend to cause a sharp rebound if my head hit it, with possible neck injury. I couldn't use the impact absorbing foam available at the time because it got very hard when cold, and unlike the same stuff in a seat pad, my body heat would not keep the headrest warm. My head doesn't actually touch the headrest unless I look straight up. I finally settled on a packing foam that had some impact-absorbing properties. Whatever you use, think beyond cosmetics and the comfort of occasionally resting your head on it. Using an automotive headrest might make sense, depending on how it is constructed. Chip Bearden ASW 24 "JB" |
Discus B Headrest | Kurt[_3_] | Soaring | 4 | November 24th 15 02:23 AM |
Junior Glider Headrest | Mike Schumann | Soaring | 5 | August 7th 11 08:10 PM |
Ka-6 Headrest | vontresc | Soaring | 1 | May 15th 08 10:28 PM |
Grob headrest | nmskies | Soaring | 3 | May 18th 06 04:56 AM |
