Discus CS grounded in France
Old September 9th 03, 12:01 AM
Marc Till
Default Discus CS grounded in France
French aviation authorities (DGAC) have just grounded the Discus CS,
because of an in-flight wing failure :
http://195.68.62.11/GSAC/ad_cns.nsf/...iques?OpenView
Apparently, it is not the case in Germany (nothing on the Schempp-Hirth
or LBA websites)
Has anyone got more news ?
Cheers
Marc TILL
Orsay, France
http://perso.club-internet.fr/mtill/
http://www.planeur-chartres.org/
Old September 9th 03, 04:29 PM
Chris OCallaghan
Per the French Airworthiness Directive, "separation of the wing during
normal operating conditions, possibly the result of a manufacturing
defect."
Marc Till ] wrote in message ...
or LBA websites)
Cheers
Marc TILL
Orsay, France
Old September 10th 03, 07:17 AM
CH
it looks a bit suspicious that the latest incidents
concerned gliders out of Schemp Hirth's Chechia
licence fabrication only.
CH
----- Original Message -----
Newsgroups: rec.aviation.soaring
Sent: Wednesday, September 10, 2003 12:29 AM
Subject: Discus CS grounded in France
defect."
Old September 11th 03, 05:34 PM
Chris OCallaghan
My "suspicion" is that quality control broke down at the Chechia
factory. The quesiton on my mind is, "For how long and to what
degree?" Two gliders from the same factory breaking up in flight in a
single season deserves an explantion from the factory. Since we bet
our lives on these products, that's the least Schempp-Hirth can do.
Even a "We're looking into it" would be appreciated.
"CH" wrote in message ...
CH
defect."
Old September 11th 03, 06:17 PM
JJ Sinclair
Got this second hand info. The scenario goes something like this
Workers A, B & C don't spread enough glue (cabacil) onto the wing just before
the mating process.
Inspector D, didn't feel it was necessary to have a look, saying, "you guys
have been doing this long enough to know what your doing"
Pilot E, has a rude awakening. He may have just completed a loop when things
started shedding from his sailplane.
JJ Sinclair
Old September 9th 03, 10:43 PM
Guy Byars
I better check the spar splices in the 1-20 wing again! With a red line of
75mph, you can't be too careful.
Same happens as with a wooden glider.......
SF.
Old September 9th 03, 11:16 PM
Jim Vincent
JJ knows that...after all, wood and fiberglass are both composite aircraft;-)
Jim Vincent
CFIG
N483SZ
Old September 10th 03, 06:04 AM
tango4
Ahhh, now that is a completely different question. The material will last a
long, long time but if they haven't put any in the structure then all bets
are off!
Ian
"JJ Sinclair" wrote in message
Ian wrote a lifespan of 50000 ( yes
fifty
thousand ) hours with a high
level of safety" so your 1000 hour Nimbus is hardly out of the running in
period!
But what if they didn't use enough glue?
JJ Sinclair
Old September 10th 03, 04:40 PM
Ray Lovinggood
Eric,
Concrete and steel bonded together consitute a 'composite'
structure. Steel girders used for bridges have steel
studs welded on top flanges of the girders. The concrete
deck is poured and bonds to the girders with the help
of the numerous studs. The Portland cement in the
concrete is the glue which makes the bonding possible.
So, in a way, the concrete and the steel are 'glued'
to each other. Calculating the strength of the structure
takes the 'composite' structure into account.
Ray Lovinggood
Carrboro, North Carolina, USA
At 02:42 10 September 2003, Eric Greenwell wrote:
says...
Not really. Wood is a material used 'as is', while
composite aircraft
mix at least two materials together; e.g., epoxy and
fiberglass.
Gluing or bolting materials together doesn't qualify
as 'composite'.
You probably knew that...
!Replace DECIMAL.POINT in my e-mail address with just
a . to reply
directly
Eric Greenwell
Richland, WA (USA)
18m Discus Burt Compton Soaring 2 September 8th 03 11:52 AM
Discus Wing question John Galloway Soaring 6 August 23rd 03 08:52 AM
DUO DISCUS GROUNDED AS OF 31 JULY 2003 Eric van Geetsum Soaring 20 August 18th 03 10:23 PM
Duo Discus Tech note Thomas Knauff Soaring 25 August 9th 03 11:10 PM
"France downplays jet swap with Russia" Mike Military Aviation 8 July 21st 03 06:46 AM
