Question of the Day
Old September 9th 03, 03:14 AM
M B
Default Question of the Day
Since mass is a constant factor on both sides of the equation, it cancels out. Therefore there should theoretically be negligible difference in the pullup altitude gained between the ballasted and unballasted cases.True except for two things:The ballasted glider has more induced dragwhile at the same airspeed as the unballasted oneThe ballasted glider also has a higher stall speedSo the unballasted glider will go higherMark Boyd
Old September 9th 03, 04:20 AM
Scott Correa
Mark.
What about the L/D polar being skewed to the right to the benefit of the
higher
wing loaded vehicle. At VNE the heavier a/p is cleaner and will glide
farther.
If both a/p's pull up together, the cleaner a/p runs out of energy last. It
looks to me like
heavier climbs further.....
Scott
"M B" wrote in message
Boyd
Old September 9th 03, 02:03 PM
Kevin Neave
Indeed you are correct that at high speed the ballasted
Glider 'bleeds' height (not energy) more slowly. That's
why we fly with ballast when we're cruising across
country, flying at higher speeds for longer periods
However if we look at that nice man Mr Johnson's test
flight of the Discus we find that carrying 183lbs of
ballast reduces the sink rate at 100kts from 3.3 m/s
to 2.24m/s.
If we pull up into a 45deg climb our velocity will
reduce at about .7g, i.e about 7m/s/s
So... if we're slowing from 100kts (50 m/s) to 40kts
(20 m/s)this will take about 30/7 seconds (i.e about
4)
Even if our ballasted glider could maintain it's sinkrate
advantage for the whole period we'd gain less than
5 metres.
At 12:36 09 September 2003, Scott Correa wrote:
Shouting is unbecoming a gentleman..................
Somehow I don't think you understood what I said.
Every test I have seen published shows the max L/D
point moving to the right (ie occuring at a higher
speed)
with an increase in wing loading. The sink rate curves
do the same thing. So again I ask, doesn't the heavier
airplane bleed energy more slowly..................
This has nothing to do with starting the engine......
Oh Yeah I also forgot to mention that although you
cannot
create energy, you can add it to the glider by flying
in air
going up faster than you are sinking thru it......................
Last time I looked at total energy systems, it read
airspeed
(kinetic energy) and barometric pressure (potential
energy)
Scott
'szd41a' wrote in message
YOU CANNOT CREATE ENERGY UNLESS YOU FIRE YOUR ENGINE!!!!!!!
'Scott Correa' a écrit dans le message de
Mark.
higher
and will glide
farther.
out of energy last.
It
looks to me like
Scott
'M B' wrote in message
the equation, it
be negligible
difference
and unballasted
has more induced
oneThe ballasted
glider
will go
higherMark
Boyd
Old September 9th 03, 05:59 PM
M B
The heavier glider will get more altitude.But not very much...If the ballasted glider stalls at exactly 100 knots,it cannot gain any altitude, while the unballastedglider will gain some altitude. Thereforethere is at least one case where the unballastedglider will outclimb the ballasted one.The proposed equations I have seen do not account for this case and must therefore be insufficient.
Old September 10th 03, 01:46 AM
Jim Vincent
Yeah, I was wrong, the mass does cancel out.
My mommy and daddy.
Jim Vincent
CFIG
N483SZ
Old September 9th 03, 10:15 PM
Jim Vincent
It will gain more height with ballast. The
kinetic energy is defined as 1/2*m*v squared.
The potential energy is m*g*h,
So for example, if a gldier weighs twice as much, it will
gain twice the height, or at least I think so!
Again, take out the constants. Both aircraft have the same velocity at the
beginning, 100Kts. Assume, for the sake of argument, that they have the same
velocity at the end, say 30 kts (I know the heavier one will stall first, but
in a vertical pull up, the wing loading is zero, so the stall speed would be
very close).
SO at the beginning, the delta in kinetic energy for two ships travelling the
same speed is only proportional to the mass. Since the heavier one weighs more,
it has more kinetic energy. At the end of the pull up, when all the kinetic
is converted to potential, take out the constants again (g), and the only
remaining variable is h. h is proportionally more for the heavier ship. And,
as I said before, this is not accounting for drag.
P.S. I f'in hate calcusus. R dR d theta double dot!
Jim Vincent
CFIG
N483SZ
Old September 9th 03, 11:59 PM
mm
"Jim Vincent" wrote in message
same
but
be
very close).
more,
kinetic
And,
Jim Vincent
CFIG
N483SZ
Wrong again. If you can't do the math right, at least stop doing it in
public.
"The only remaining variable is" not h, it is mh. mh is "proportionally
more for the heavier ship"; h is the same.
Old September 10th 03, 01:27 AM
Jim Vincent
public.
Yo' daddy
Jim Vincent
CFIG
N483SZ
Old September 9th 03, 11:41 PM
Jim Vincent
cancels out.
You need to compare one equation to the other. The masses are different. Yes,
for one glider, the masses cancel out, but not when comparing two different
masses, cetarus parabus.
Jim Vincent
CFIG
N483SZ
Old September 10th 03, 12:28 AM
mm
cancels out.
Yes,
different
Jim Vincent
CFIG
N483SZ
You don't know what you are talking about.
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 01:26 AM
Special Flight Setup Question (COF) Dudley Henriques Simulators 4 October 11th 03 12:14 AM
T Tail question Paul Austin Military Aviation 7 September 23rd 03 06:05 PM
