Ventus C vs B
Old September 9th 03, 06:21 PM
tango4
Default Ventus C vs B
Apart from the very sweet looking 17.6 m tips and tail ballast what are the
other differences between the Ventus B and the Ventus C.
Does the C have the same long cockpit as the B ?
I believe the C handles a lot better.
Ian
Old September 9th 03, 07:00 PM
Marc Ramsey
"tango4" wrote...
The C has a different root fairing which improves performance and handling
at slow speeds. The trailing edge divebrakes are replaced by conventional
spoilers, which makes it a lot easier to properly seal the flaps.
There are actually C/A and C/B variants. The C/B has the same cockpit as
the B, whereas the C/A has the shorter, narrower cockpit of the A. CMs and
CTs use the C/B fuselage.
Having owned a B and flown a C a few times, I'd say that, at best, the C
handles slightly better than the B. The C is a bit more stable in the roll
axis (particularly at thermalling speeds), and requires less control force
in roll. Ptich and yaw stability are pretty much the same. The C is
probably easier to land for the uninitiated, but can't match the Bs
outstanding short field landing capability.
Marc
Old September 10th 03, 01:08 AM
Mike Borgelt
On Tue, 9 Sep 2003 11:00:25 -0700, "Marc Ramsey"
Marc
I own a C model with A fuselage and have flown several A and B models.
The C model has 3 degrees of dihedral and vs 2 degrees on the A and B
and is more stable in roll at thermalling speeds particularly with the
17.6 meter tips.
The full span flaperons on the C generate much less adverse yaw than
the ailerons on the B greatly reducing workload in turbulent air.
The top surface drives for the flaperons on the C model dramatically
reduce friction and improve linearity in the aileron control circuit
compared to the half baked Schempp excuse for an attempt at the
Glasflugel skew bar drive in the A and B model. With careful
maintenance that friction can be controlled. Winglets on the A or B
(15m) seem to improve aileron handling dramatically. The last A model
I flew had them and was quite pleasant compared to the other A and B
models I've flown.
Mike Borgelt
Old September 10th 03, 03:29 AM
Jim Phoenix
You answered the question I posed to Todd. I wish my N3 had the top surface
drives.
"Mike Borgelt" wrote in message
roll
force
Marc
17.6 meter tips.
models I've flown.
Mike Borgelt
Old September 9th 03, 08:53 PM
Stewart Kissel
C.
Marc covered the primary differences, having recently
shopped for a Ventii, there appears to be a significant
price difference between the two(B's and C's). Many
B's have had tail tanks added, and some have also ended
up with the 17.6 tips. Google RAS for some lengthy
B threads, and Al's site has a parallel thread on the
subject as well.
Ian
Self-Riggers and disassembly of wings Stewart Kissel Soaring 11 August 19th 03 02:56 PM
VENTUS 3 in Poland but no LS 10 Michael Soaring 9 July 26th 03 01:54 AM
Is anyone still interested in CuSoft "Polar Explorer" program for PC? Branko Stojkovic Soaring 1 July 26th 03 01:06 AM
L-nav Settings Ventus 2ct-18 Oliver Peters Soaring 4 July 18th 03 04:14 AM
