Every time I declare a task from See You running on an Oudie to my
Cambridge 302 it changes the settings in the 302 to metric. Anyone else had this problem? Thanks Dave |
I did have in a previous glider an Oudie 1 and then 2 connected to a 302 and never saw this happen. But I never used this combination of devices to declare a task so my next comments may be rather dumb questions.
Have you checked the Oudie is not set to metric? I have to assume not but had to be asked. I also assume your 302 has been upgraded for the GPS issue (http://aviation.derosaweb.net/cambridge) - but this might not have anything to do with your issue. Two generic ideas. 1) Use the http://naviter.com web site's forum to ask the question. 2) Contact Cambridge to see if they know anything. Sorry to not be more helpful. Good luck |
| Thread Tools | |
| Display Modes | |
| Oudie to Cambridge | HGXC[_2_] | Soaring | 19 | May 4th 16 09:35 AM |
| Oudie 2 to Cambridge 302 | [email protected] | Soaring | 1 | April 19th 16 06:09 AM |
| WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario | ufmechanic | Soaring | 0 | March 24th 09 06:31 PM |
| Cambridge 302 & PDA -- Value of adding Cambridge 303? | V1 | Soaring | 5 | July 31st 07 04:51 AM |
| Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 | Nathan Whelchel | Soaring | 4 | July 6th 04 12:22 AM |
