AA Butterfly versus CNv LCD wind calculation
Old September 16th 16, 09:23 PM posted to rec.aviation.soaring
Default AA Butterfly versus CNv LCD wind calculation
The Air Avionics Butterfly has developed an outstanding reputation as having a competitive advantage for its ability to "instantaneously" calculate wind direction.
Does the CNv (with latest 3.3.3899 or beta 3.4.4089) calculate wind as quickly as the Butterfly?
T8, what is the wind direction update rate of the CNv?
If anyone has experience using both varios at the same time, please share your opinions.
Old September 17th 16, 12:35 AM posted to rec.aviation.soaring
waremark
And how do the LX Nav varios compare? I have LX9000/V9. I am impressed by the way it shows me wind changing with height as I climb in wave etc.
Old September 17th 16, 02:13 AM posted to rec.aviation.soaring
2G
Unfortunately that tells us nothing about how accurate the real time wind calculation is. I have flown with the Butterfly vario for 2 seasons now and can say that the wind accuracy is good, but sometimes goes bonkers (off by 10 kt or more). I monitor while circling and can compare it to my track over the ground. I have also set up the Butterfly to display both true airspeed and GPS ground speed. The difference is the head/tailwind component. I can compare that to the real time wind vector for a sensibility measure.
Tom
Old September 17th 16, 03:40 AM posted to rec.aviation.soaring
Respectfully, please keep comments focused to OP. The question does not address the LX products which are outstanding IMHO.
Old September 17th 16, 10:12 PM posted to rec.aviation.soaring
I own a CNv and installed the latest software updates. I also have experience with an Air Avionics Butterfly. But I did not use both varios at the same time.
CNv wind calculations became quicker during the various releases. But in my opinion, it is still slower and less reliable compared to a well compensated Butterfly vario. You will notice the difference especially when flying straight.
The Air Avionics system has a much higher resolution of small wind changes compared to the CNv and it does not need changes in direction for wind updates. But you need to spend some time in setting up the Butterfly sensor unit until it works well. If you did so, it can be very helpful to find lines of lift. I find CNv wind speed calculations sometimes to be inconclusive (too high), but perhaps this is related to my setup.
Old September 18th 16, 12:38 AM posted to rec.aviation.soaring
Great opinions...thanks for contributing. Keep them coming.
Old September 18th 16, 03:24 PM posted to rec.aviation.soaring
JS
I've had both Air and CNv for a year or so now.
The wind display from the Air is amazingly fast. Yes, it changes a lot but so do conditions. The most incredible display of wind is while flying lines of convergence.
While the CNv wind display refreshes much faster in the latest version, the wind itself does not update. Attributed to the difference between using the inertial sensors or not.
But the CNv does an excellent job in choppy thermals.
Old September 18th 16, 10:24 PM posted to rec.aviation.soaring
Tango Eight
No.
I don't have a quantitative answer here. Mostly it depends on your flight path. CNv depends on some GPS track variation for vector wind calculation, but it doesn't take a great deal (20 degrees total track seems to do it in most cases). Given sufficient GPS track variation, the fast wind seems to update in just a few seconds ( 10). The auto wind is slower, gives a more stable number. It seems to take a few tens of seconds to update. Either mode is noticeably faster than previous generation flight computers (302, SN-10B). I haven't flown the Butterfly vario. The component head/tail wind is updated very fast (less than a second).
The only difference between "auto" and "fast" winds in CNvXC is the time constant. I see no downside to the fast wind, so I've been lobbying to make this the default. The fast wind is excellent for close in mountain flying.
best,
Evan / T8
Old September 19th 16, 02:16 AM posted to rec.aviation.soaring
No.
best,
Evan / T8
Thanks T8.
Old September 19th 16, 12:22 PM posted to rec.aviation.soaring
Dave Nadler
...CNv depends on some GPS track variation for vector wind calculation
You're saying that, unlike for example Butterfly, CNv does not use compass?
And therefore cannot do instantaneous winds?
Sounds like the same algorithm SN10 introduced two decades ago (GPS track and airspeed)?
302 wind calculation AK Soaring 21 April 3rd 10 01:27 PM
302 wind calculation 5Z Soaring 1 March 26th 10 11:56 AM
302 wind calculation Darryl Ramm Soaring 0 March 26th 10 03:04 AM
302 wind calculation AK Soaring 0 March 26th 10 02:47 AM
Vector Wind, Relative Wind calculation C 302/303 [email protected] Soaring 2 December 9th 08 07:23 PM
