Best Soaring Flight Sim?
Old September 14th 03, 10:03 PM
Eggs
Default Best Soaring Flight Sim?
Thanks to everyone for the great info regarding plans-built gliders. I'm
still doing some research, hopefully will find something soon.
In the meantime, anyone have any suggestions for a good PC flight simulator
progam for soaring? I've loaded the trial version of "Soaring Flight
Simulator" and it seems pretty impressive, but before I part with the $70
registration fee, I thought I'd ask you gurus for your opinions.
I also have Microsoft FS 2000. Would it be worth the upgrade to 2004? Is
there a way to make it a better, more realistic, soaring sim?
Questions, questions. Someday I'll have answers to share too.
Thanks!
Curt
[remove parentheses from (@) in address to reply directly]
Old September 14th 03, 10:27 PM
Bill Daniels
I haven't tried SFS but people whose opinion I value, like it a lot.
I have tried X-Plane with several of the add-in gliders. I really like the
flight dynamics model of X-Plane and feel it is very close to the actual
handling of the gliders available.
A lot depends on the input hardware you use. A good stick and pedals are
required. A throttle adapted to serve as the spoiler handle helps a lot
too.
One neat thing about X-Plane is that it there is a lot of scalability in
that the sim can grow to a near professional simulator. It is FAA approved
for those Part 61 training tasks that can be done in a simulator.
I have been asking for a USB pneumatic signal generator that can turn the
sim's virtual pitot/static/TE pressures into real ones so that real glider
instruments can be used in a home sim cockpit. I have a dream of yanking
the panel out of the glider and fitting it to a home cockpit with the sim
generating the outside views - great for snowy winter evenings. I hear one
may be in the works.
Bill Daniels
"Eggs" wrote in message
t...
simulator
Thanks!
Curt
Old September 14th 03, 10:42 PM
Vaughn
t...
simulator
It all depends on what you want the flight simulator for. If you just
want to have fun and perhaps learn a little about flight management and
procedures, or even play with different virtual glider designs, then go for
it. If learning to fly is your goal, then go spend your time and money on
real flying and forget the sim.
I recognize that there are many here that vigorously disagree, but I
have to go with my own experience, both at being a student and an
instructor.
Vaughn
Old September 15th 03, 12:36 PM
Martin Gregorie
On Sun, 14 Sep 2003 20:42:32 GMT, "Vaughn"
et...
simulator
instructor.
I'll second that. I have SFS 3 (but then my PC is too slow for SFS 4
and has no OpenGL support). I thought SFS 3 was a fine sim and even
bought pedals for it. However, I haven't touched it since being about
half way to solo for two good reasons:
- no glider simulator can give realistic all round views and won't
until there's a good VR helmet available. Looking through the
'letterbox' and flipping it round with the coolie hat is no
substitute.
- no butt feel
That said, the BGA have a demo booth that's the front half of a two
seater (G 103?) with a projection screen for forward view and the
instruments projected onto a blank instrument panel. It uses SFS4,
connected to the original stick and pedals. That means that the trim
must work too. Dunno about the air brake. I saw it in decidedly
sub-optimal lighting conditions, but it seemed to work quite well.
martin@ : Martin Gregorie
gregorie : Harlow, UK
demon :
co : Zappa fan & glider pilot
uk :
Old September 15th 03, 01:40 PM
Tim
Martin Gregorie s comments read:
The airbrakes do work although you can't lock them from the back seat.
It is a great crowd puller but has a few rough edges that need ironing
out. Firstly it could do with a minimum of 2000 lumens for bright
conditions and secondly moving the project from directly over the back
seat.
Tim - ASW20CL "20"
Old September 15th 03, 05:15 PM
Martin Gregorie
On Mon, 15 Sep 2003 12:40:14 +0100, Tim
seat.
I think the last item has been done - at least I didn't notice
anything blocking access to the back seat. I think the projector is
now further back.
I agree that more light value is necessary. Its probably OK in an
indoor setting, but outside on a sunny day, as it was, the display was
decidedly dim.
demon :
uk :
Old September 15th 03, 05:32 PM
Tim
now further back.
I didn't explain it very well ... we had the simulator the week after
you did ... but the projector is above the instructors (back seat)
head with the hot air venting straight down - an effect just like
being sat under a hair dryer. ;-)
Tim - ASW20CL "20"
Old September 15th 03, 09:18 PM
Liam Finley
Martin Gregorie wrote in message . ..
substitute.
- no butt feel
I agree, the limited field of view inherent to PC based simulators is
one of the primary reasons I regard them as little more than toys, no
matter how good their graphics and sound effects become. This
limitation may be tolerable for power sims, since power pilots rarely
look out the window anyways, but for soaring it's leaving out an
essential part of the experience. I've been playing with PC
simulators for about 20 years, and in that time there's been
approximately zero progress in this direction. I hope we don't have
to wait for neural implants in another 20 years for this to improve.
Old September 15th 03, 12:14 AM
Stewart Kissel
Try-
http://virtualsoaring.org/index.html
gliders. I'm
soon.
'Soaring Flight
Simulator' and it seems pretty impressive, but before
I part with the $70
opinions.
upgrade to 2004? Is
sim?
share too.
Thanks!
Curt
Old September 15th 03, 12:20 AM
Udo Rumpf
I highly recommend the SFS PC. It stand for Soaring Flight Simulator.
Before I was introduced to it by a well know soaring personality, I had
dismissed a PC based simulator.
This software provides the feel, visuals and technical input to be a real
adjunct to live training. In fact in Germany some clubs use this simulator
in parallel.
I have used it in contest mode many times , as well as for ridge flying.
It is a joy to fly this simulator and once or twice a week for 1 1/2 hours
each, I am able to take my mind off things and enjoy myself.
It is useful to keep sharp in the off season as well
SFS software is written by contest soaring pilots.
I have since used other soaring specific simulators and SFS is the best in
my opinion.
It is important to have the best joystick possible.
I use the MS Force Feedback 2. All the functions can be programmed on to the
stick and base.
Flap and trim 4 buttons on the base.
as well as spoilers ( throttle control)
Head switch and reset buttons,
water dump, cable release
landing gear all on the stick.
The Force feed back stick will allow you to feel when the landing gear comes
up or down.
or when the air frame start shaking ( over speeding) the sound adds an extra
dimension.
Regards
Udo
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Aerobatics 28 January 2nd 09 03:26 PM
Letter at end of flight number? Laura Piloting 1 December 17th 04 04:14 AM
x-43 Flight Garrison Hilliard Military Aviation 0 March 26th 04 01:42 PM
100 years of flight - Special coverage by The Cincinnati Enquirer Garrison Hilliard Military Aviation 1 March 14th 04 03:42 PM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 03:13 PM
