That price Ian gave and trust of 42 lbs. was before the motor was completed.
The ad even says available this fall. Its on Jet Cat USA web page, and its a old ad. I have been in touch with the dealer and the price is about $3200 bucks and the Jet Cat P200 now produces 50 lbs of thrust. There are several other companys that make small Jet turbines, I have seen thrust ratings now at 150 lbs. which would be more than enough for self launch. The fin idea was thought of, but remember that some of the thrust comes from the sucking action of the motor. The exhaust is 660 C's. If you mount it like a motorglider engine it will have to high enough so you don't burn your tail feathers off, if it drops out of the belly, then self lauch could cause fob injestion. Shop around and go out to a rc field where you can see and talk to the guys who have them. Overhaul is now at 50 hrs. Thats only for inspection and maybe a bearing. No big thing. 50 hrs is alot of time....about 600 climbs of 2500 ft. Mounted on a retractable pod boom with a arm that extends might be a idea. Food for though. Tom |
Of course you could mount it on an offset mounting so that the exhaust goes
to one side of the tail. I'm sure the yaw induced would actually be quite small. Ian "TomnKeyLargo" wrote in message ... That price Ian gave and trust of 42 lbs. was before the motor was completed. The ad even says available this fall. Its on Jet Cat USA web page, and its a old ad. I have been in touch with the dealer and the price is about $3200 bucks and the Jet Cat P200 now produces 50 lbs of thrust. There are several other companys that make small Jet turbines, I have seen thrust ratings now at 150 lbs. which would be more than enough for self launch. The fin idea was thought of, but remember that some of the thrust comes from the sucking action of the motor. The exhaust is 660 C's. If you mount it like a motorglider engine it will have to high enough so you don't burn your tail feathers off, if it drops out of the belly, then self lauch could cause fob injestion. Shop around and go out to a rc field where you can see and talk to the guys who have them. Overhaul is now at 50 hrs. Thats only for inspection and maybe a bearing. No big thing. 50 hrs is alot of time....about 600 climbs of 2500 ft. Mounted on a retractable pod boom with a arm that extends might be a idea. Food for though. Tom |
Earlier, Eric Greenwell wrote:
I still think someone with a metal vee-tail glider ought to jump on this idea, and just mount the engine on a short pylon. Please send one (1) turbojet engine in a stamped, self-addressed envelope... ![]() Bob K. |
Eric Greenwell wrote in message ...
[] I still think someone with a metal vee-tail glider ought to jump on this idea, and just mount the engine on a short pylon. Fiberglass forward fuselage, metal rear fuselage and metal V-tail. Hmm. Didn't Udo Rumph show us that this formula can still lead to a very high performance glider (ref. Dick Johnson's recent tests on Udo's modified HP-18 published in Soaring)? I think Eric may be onto something... -Doug |
this idea, and just mount the engine on a short pylon. Fiberglass forward fuselage, metal rear fuselage and metal V-tail. Hmm. Didn't Udo Rumph show us that this formula can still lead to a very high performance glider (ref. Dick Johnson's recent tests on Udo's modified HP-18 published in Soaring)? I think Eric may be onto something... -Doug It would be fun the to explore a sustainer jet with the HP18. A 42 lb thrust jet should do to job, provided it has the same or better reliability for starting as a conventional engine. I would reject a self launching jet version on environmental grounds. Udo Rumpf |
![]() It might get a pit toasty for the wing runner in self-launch mode, but how about one at each wing tip? It seems most gliders these days already have some sort of interchangable tip, so make a new set with a jet built in. Fuel storage would be the main issue. If you give up the water ballast option though, there's plenty of room in the wing. Chris Slingsby wrote: I would think that mounting a couple of small jets at or just behind the wing/fuselage junction could also serve to remove some of the low speed turbulence in that area. Also, if the engine had a tight cowling around it then perhaps some water could be sprayed or drizzled onto the outside of the engine and the resulting steam would mix with the exhaust to provide some additional thrust. SWB Turbines in Neenah, WI (SWBTurbines.com)has a Mamba turbojet which puts out 11 Lbs. of thrust. It is only 3.5 inches in diameter and would fit nicely at the wing junction interface. SWB also has 45, 60 and a 100Lb thrust engine. |
Get Over $50,000 Fast and Easy, READ HOW | [email protected] | Owning | 0 | January 1st 05 04:41 PM |
TFR's Read Carefully | Ron Rosenfeld | Piloting | 2 | September 20th 04 06:12 PM |
General Zinni on Sixty Minutes | WalterM140 | Military Aviation | 428 | July 1st 04 11:16 PM |
OT - What espioange/war novels do you read? [SURVEY] | Eric Pinnell | Military Aviation | 34 | April 28th 04 06:23 PM |
12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 12th 03 11:01 PM |
