X-no-archive: yes
In article , Pat Russell writes Which distance calculation algorithm is used by FAI in the homologation of gliding world records? -Pat Either the FAI sphere or the WGS84 ellipsoid. But where the distance is critical, the WGS84 ellipsoid is used. There is a script for calculating WGS84 distances at: http://www.fai.org/distance_calculation/ For more info read the Sporting Code (General section). Para 7.3.1.1, states: "For FAI distance calculations, the earth model used may either be the WGS84 ellipsoid or a sphere of radius 6371 km exactly. For accurate measurement and calculation of distance, Air Sport Commissions shall choose which model is to be used in their area of activity. The WGS84 ellipsoid is very close to the real shape of the earth, the FAI sphere is an approximation." Sporting code Section 3 (Gliding) Para 4.4.1 says: "For the purpose of the calculation of FAI geodesic distances, the WGS84 earth model shall be used. See also Annex C, Appendix 2. When calculation of the exact distance is not critical, less accurate methods may be used. See Annex C , para 1.6b." Best regards, Tim Newport-Peace "Indecision is the Key to Flexibility." |
Thanks for looking up the rules for me, Tim.
However, I am still confused about which method the FAI would actually use in a World Record claim. The rules say that we (or they) must make a determination of when "accurate measurement" is required: "For accurate measurement and calculation of distance, Air Sport Commissions shall choose which model is to be used in their area of activity." Assuming that a World Record requires "accurate measurement," the rule quoted above seems to state that the method to be used, in the case of gliding, would be the method mandated by SC3. The SC3 rule is: "For the purpose of the calculation of FAI geodesic distances, the WGS84 earth model shall be used." Given all of the above, it seems that FAI must use the ellipsoid (and no other method) to calculate distance for the homologation of world gliding records. I am suspicious that they don't actually do this. Does anyone know for sure? And can anyone give me an example of a "non-critical" distance measurement? |
