Our club's G-103 Acro needs a new brake master cylinder.
We can probably get one from Grob in Ohio within several weeks, but we would like to get one sooner. Does anyone, anywhere, have a master cylinder they would sell us? Then, we would pay overnight freight to our club's location in North Carolina, USA. Please contact me at: Thanks, Ray Lovinggood Carrboro, North Carolina, USA |
Ray,
Could your master cylinder be rebuilt? If corrosion is the problem, a possible fix might be to have a machine shop bore it out and then epoxy a brass sleeve in the bore . . . no more corrosion problems. This is a common fix for antique car and other auto restoration projects. -- bumper "Dare to be different . . . circle in sink." to reply, the last half is right to left "Ray Lovinggood" wrote in message ... Our club's G-103 Acro needs a new brake master cylinder. We can probably get one from Grob in Ohio within several weeks, but we would like to get one sooner. Does anyone, anywhere, have a master cylinder they would sell us? Then, we would pay overnight freight to our club's location in North Carolina, USA. Please contact me at: Thanks, Ray Lovinggood Carrboro, North Carolina, USA --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.521 / Virus Database: 319 - Release Date: 9/23/2003 |
but is it a valid repair for an aircraft? is the Grob flown under a Standard airworthiness certificate or an Experimental? it does make a difference.. I can see the accident report now, Grob on Commercial passenger carrying scenic glider ride, lands long and goes off the end of runway.. brake fails to stop the glider before hitting airport fence. Fencing injures passenger's face in front seat. Discovered improper repair to brake master cylinder. Lawsuit follows..... you get the picture. BT |
Ray,
I have found it very difficult to bleed the G-103 master cylinder. The old *hold pressure with the dive brake lever and open the bleeder valve* has NEVER worked for me. The only thing I have found that works is to *pressure bleed*, form the wheel bleeder valve, up through the master cylinder. Hope this helps, JJ Sinclair |
With our Grob G109B motorglider the wheel brake master cylinders are an item
supplied by Tost at www.tost.de . We have been able to buy replacement seal kits and replacement master cylinders from Tost easily. No hassle. The Tost people may have their catalogue on-line for perusal. Possibly the master cylinder for the Grob G103 is also available from Tost. There are a few variants. My faint recollection is that the G103 has a side lever actuation rather than a top lever actuation, but my memory could be imperfect. The master cylinder in the G109B is the same as used in the hydraulic disc braked mainwheel installations in our Janus B (which we converted to hydraulic disc brake from drum brakes using a kit from Tost), Janus C (which came so equipped from manufacture), etc. Tost also can supply a five page document headed "Disc brake systems - Maintenance" and subtitled "Service and maintenance of disc brake systems with master brake cylinder of type 3,4 6 and 7". This document assists with info on bleeding. I think they would be happy to email it to you if you ask nicely. They sent me a copy when we were installing the Tost kit for hydrauilic braked main wheel system into our Puchacz. (Best thing we've done with our Puchacz maintenance and operations wise was getting rid of the Polish mainwheeel and wheel brake.) I agree with JJ Sinclair that bleeding these systems can be a bugger. Whereas by contrast with our Piper Pawnee it is easy as pie, so to speak. With a Tost master cylinder in the system, you have to have the brake lever as far towards brakes off as it can be. Hope this helps. Roger Druce (Australia) "JJ Sinclair" wrote in message ... Ray, I have found it very difficult to bleed the G-103 master cylinder. The old *hold pressure with the dive brake lever and open the bleeder valve* has NEVER worked for me. The only thing I have found that works is to *pressure bleed*, form the wheel bleeder valve, up through the master cylinder. Hope this helps, JJ Sinclair |
Compression loss on cylinder when rings line up Truth of fiction? | test it | Home Built | 10 | May 11th 04 08:11 PM |
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 08:40 PM |
#5 cylinder not firing | David R. | Owning | 13 | February 27th 04 12:41 PM |
Start Anywhere Cylinder (SSA rules proposal) | Mark Navarre | Soaring | 15 | September 25th 03 01:13 PM |
'Hot' cylinder after overhaul? | Tony Cox | Owning | 8 | August 10th 03 07:25 PM |
