Plasma Ropes ----- Help
Old September 30th 03, 09:29 AM
Dave Martin
Default Plasma Ropes ----- Help
To any club using plasma ropes in place of steel.
Having read the benefits of this type of rope, several
UK clubs are interested in its use. One major obstacle
to this, is cutting it during a launch, in the event
of an emergency
So far the best methods appear to be an axe an anvil
type cutter.
Any slight imperfections on scissor, guillotine and
even the axe methods of cutting mean the rope does
not get completely cut through. Even though the equipment
cuts steel succesfully.
Various methods such as hot wire and laser beams have
been suggested, but with the way members treat club
equipment I suspect the life of such things would be
minimal.
What emergency cutting methods for plasma rope do those
who use it employ?
Thanks in anticipation
Dave Martin
Old September 30th 03, 09:54 AM
Sf760
I understand that Skylaunch have developed a guillotine that cuts it very
nicely.
Old September 30th 03, 02:10 PM
Bill Daniels
"Dave Martin" wrote in message
minimal.
Dave Martin
Why should a hot blade be fragile? The winch engine starting battery has a
lot of power to heat a robust blade very quickly. You only need to get the
blade to Spectra's 265F melting point - far below the blades melting point.
I would just mount the blade in a strong frame near the path of the rope and
push the rope against the stationary hot blade with a rubber block. If well
built, it should last nearly forever.
Bill Daniels
Old September 30th 03, 06:03 PM
tango4
Surely a scissor type gulliotine would be more effective
Ian
of an emergency
type cutter.
minimal.
who use it employ?
Dave Martin
Old September 30th 03, 08:05 PM
Sf760
Tried that, with a shiny new freshly sharpened scissor type guillotine, and it
didn't cut it, this stuff has very fine fibres which just bent around the
corners. even using heat-shrink sleeving to simulate a plastic coating, we got
the same results, you simply could not be sure of cutting the rope.
Old September 30th 03, 10:08 PM
Bob Johnson
Dave --
Just thinking out loud here, always dangerous: nail guns, either
percussive, powered with shotgun shell or the like, or pneumatic with
air cylinder. Sorry, no blueprints available. Replace nail with blade
would be good.
Wondering about guillotines in general, I know it's always good to have
one, but has anyone in earshot actually used one? If so, what were the
circumstances, line running or still, weak link or no, spring, gravity
or muscle powered, radios or how did you know and like that.
Bob Johnson
of an emergency
type cutter.
minimal.
who use it employ?
Dave Martin
Old September 30th 03, 11:23 PM
W.J. \(Bill\) Dean \(U.K.\).
There was a fatal accident in the U.K. when the glider being launched got
the launching wire over a wing. The guillotine was fired by the winch
driver, but failed to cut the wire (which was of course being pulled out by
the glider). It is not certain that cutting the wire would have saved the
pilot, but he had little chance with it uncut.
As a consequence of this accident we are very aware in the U.K. of the
necessity for a reliable method of cutting the cable. The guillotine was
re-designed, and they are now regularly serviced and tested in accordance
with a laid-down schedule.
So the answers to your question are; yes, the winch driver could see the
problem, the guillotine failed to cut the wire.
W.J. (Bill) Dean (U.K.).
Remove "ic" to reply.
"Bob Johnson" wrote in message
snip
Bob Johnson
Plasma Reduces Jet Noise (Turbines?) sanman Home Built 1 June 27th 04 12:45 AM
Plasma Reduces Jet Noise (Turbines?) sanman Rotorcraft 1 June 27th 04 12:45 AM
Using Plasma Rope For Winch Tows Craig Freeman Soaring 56 August 24th 03 10:55 PM
Winching: Steel vs. Plasma Bob Johnson Soaring 10 August 12th 03 05:41 PM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 01:37 AM
