I have been trying to figure out what is happening with my Cambridge
LNAV since in several flights "speed-to-fly" bars have never appeared, even in a long continuous glide straight at the goal indicated by the connected Cambridge GPS. Since "speed-to-fly" bars only appear in "cruise" mode possibly my LNAV is somehow always in "circling" mode - but I cannot find in my very thin LNAV manual (version 4, march 1995) what determines the choice of "cruise" vs "circling" mode so am hoping someone here has that knowledge so I can at least know how I should _expect_ it to behave. (FYI I do not believe I have the G-meter option, though can't say for sure since I was not the one who purchased the LNAV new.) |
Jack,
If you don't have a *G* switch in your L-Nav, then you must have an external switch to do it. On a flapped sailplane, it can be a micro-switch in the flap drive system to put the L-Nav in climb mode when positive flaps are commanded. In a standard class ship, the switch is usually mounted on the stick. Having said that, I no longer feel the need to switch. With GPS constantly driving your position in the L-Nav, the distance to your selected destination will always be correct. I just leave it in cruse mode with the audio off and my back-up vario (B-40) on with audio up. I get audio only when I'm going up and no distracting speed-to-fly audio, when crusing. If I feel the need to see what old Mr. MacCready thinks about my speed, I just look at the speed-to-fly needle. JJ Sinclair |
JJ,
Thanks for the info. I know there is no switch on the stick and am pretty sure there is no microswitch on the flaps, so perhaps I have a G meter after all !? I have to replace the battery anyhow so will check it out when I have the LNAV opened and will also check the back for a hold switch connection. I also see there is a calibration for the Gmeter and will check it if I do have a Gmeter since I certainly was at 1G in my long glide with no "speed-to-fly" bars appearing. Jack |
PS I can't follow your second suggestion since I have a Winter
mechanical vario with no audio - and more importantly right now it's reading a permanent 8kts up (even on the ground) so will also be looking at it when I have the panel cover removed. |
If you don't have the G-meter option, there are two other ways the LNAV
might use to let it know if you're circling or in cruise. Your glider may have a switch installed on the flap mechanism to sense selection of thermalling flaps, or it could have a manual toggle or selector switch on the panel or stick. -- bumper "Dare to be different . . . circle in sink." to reply, the last half is right to left "Jack" wrote in message link.net... I have been trying to figure out what is happening with my Cambridge LNAV since in several flights "speed-to-fly" bars have never appeared, even in a long continuous glide straight at the goal indicated by the connected Cambridge GPS. Since "speed-to-fly" bars only appear in "cruise" mode possibly my LNAV is somehow always in "circling" mode - but I cannot find in my very thin LNAV manual (version 4, march 1995) what determines the choice of "cruise" vs "circling" mode so am hoping someone here has that knowledge so I can at least know how I should _expect_ it to behave. (FYI I do not believe I have the G-meter option, though can't say for sure since I was not the one who purchased the LNAV new.) --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.521 / Virus Database: 319 - Release Date: 9/25/2003 |
"Jack" wrote in message link.net... I have been trying to figure out what is happening with my Cambridge LNAV since in several flights "speed-to-fly" bars have never appeared, even in a long continuous glide straight at the goal indicated by the connected Cambridge GPS. Regards the Climb/Cruise switch that you have been advised about: If the switch is in the "Cruise" mode the Speed to Fly bars should always be in view. If the switch is in the "Climb" mode the Speed to Fly bars should come into view when flying at a speed greater than about 60 kts. If you never see the Speed to Fly bars then you may have an electronic failure. In that case you will get to run a test as to whether Cambridge really will still do repairs. Duane |
"Duane Eisenbeiss" wrote... If you never see the Speed to Fly bars then you may have an electronic failure. In that case you will get to run a test as to whether Cambridge really will still do repairs. Which Cambridge? 8^) |
"Marc Ramsey" wrote in message m... "Duane Eisenbeiss" wrote... If you never see the Speed to Fly bars then you may have an electronic failure. In that case you will get to run a test as to whether Cambridge really will still do repairs. Which Cambridge? 8^) The L-Nav that is being discussed. |
"Marc Ramsey" wrote in message m... Which Cambridge? 8^) I think that I maybe misunderstood your question. Did you mean which CAI company? If so I do not know. That is what I meant by "running a test". CAI seems to be in a real state of flux. Duane |
Jack Glendening wrote:
I have been trying to figure out what is happening with my Cambridge LNAV since in several flights "speed-to-fly" bars have never appeared, even in a long continuous glide straight at the goal indicated by the connected Cambridge GPS. Since "speed-to-fly" bars only appear in "cruise" mode possibly my LNAV is somehow always in "circling" mode - but I cannot find in my very thin LNAV manual (version 4, march 1995) what determines the choice of "cruise" vs "circling" mode so am hoping someone here has that knowledge so I can at least know how I should _expect_ it to behave. It took quite awhile for me to sort things out in this case, since in working on it I found problems with (1) my L-NAV, (2) the L-NAV meter, (3) my GPS-HAV, (4) the pitot tubing, and (5) the triple probe - all of which needed to be addressed (and my manual Winter vario is also kaput!). I've now decided that the problem lies in the L-NAV display, since "de beeps and de boops" indicate that it switching from circling to/from cruise mode but the "speed-to-fly" bars never appear (even though I have heard both the "speed up" and "slow down" tones). And there are other problems with the display as well (missing segments on several digits), so yet another display problem would not be a surprise. My thanks to all who volunteered suggestions. |
| Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 5th 04 12:55 AM |
| Mode S to become requirement? | Bob Chilcoat | Owning | 6 | July 15th 04 12:25 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 10:25 AM |
| Mode S Transponders - Can ATC tell the difference? | Doodybutch | Owning | 2 | August 10th 03 07:21 AM |
