Flarm B and ADSB antenna placement
Old November 17th 16, 03:02 AM posted to rec.aviation.soaring
Default Flarm B and ADSB antenna placement
If the Flarm B antenna is "receive only" and same for the ADSB antenna, is there any issue mounting those two antennas next to each other, or very nearly so?
Old November 17th 16, 03:32 AM posted to rec.aviation.soaring
Dan Daly[_2_]
From the CORE manual -
5.3.8.2 ADS-B/SSR antenna (SMA connector, BLUE marking)
PowerFLARM Core ADS-B has one ADS-B/SSR receiver operating on 1090 MHz.
Ensure that the antenna cable is properly and fully screwed into the device. Never swap the FLARM and the ADS-B/SSR antennas. Use only little force when
inserting and tightening (1 Nm max).
This antenna should be placed at least 30cm/1 ft away from the FLARM antennas.
The FLARM antennas have priority over this antenna for best placement.
In addition, in 5.3.9 - GPS Antenna, at the end:
If more than one GPS antenna is present in the aircraft, it is recommended that
they are at least 30cm/1ft apart; the same holds for separation from all other
antennas connected to PowerFLARM Core.
Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location WaltWX[_2_] Soaring 9 January 20th 15 12:00 AM
FLARM antenna mounts for ASG-29 Sean F (F2) Soaring 20 September 11th 13 03:35 PM
Transponder Antenna & Battery Placement Nimbus or DUO [email protected] Soaring 13 February 25th 09 10:02 PM
FLARM antenna installation Kevin Neave Soaring 5 January 16th 07 07:53 PM
Nav Antenna Placement Jim Pensinger Home Built 7 October 4th 04 10:55 PM
