Engineering geniuses out there
Old October 8th 03, 07:48 AM
Scott
Default Engineering geniuses out there
I know someone has an answer. I need to find out if I'm drawing power when
my master switch is off. Something is quirky and I want to be able to hook
something up in the batteries position to find out if anything is drawing
little bits of power. Any one know of a simple instrument?
__________________________________________________ ________________ scott
ICQ#: 34312461 Current ICQ status: + More ways to contact me
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.524 / Virus Database: 321 - Release Date: 10/6/2003
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Old October 8th 03, 04:33 AM
Tim Ward
"Scott" wrote in message
Yes. An ampmeter in series with the battery with the master switch off
should show zero current.
Try the larger ranges (10 Amps, for example) first, so you don't pop the
fuses in your meter.
Tim Ward
Old October 8th 03, 08:52 AM
Scott
thank you
"Tim Ward" wrote in message
when
hook
drawing
Tim Ward
Old October 8th 03, 08:23 AM
John Morgan
thank you
Just to be sure there's no confusion, you will need to remove one lead from
the battery, doesn't matter which one. Then set the multimeter on its
highest amp range and hook one meter lead to the battery terminal and the
other to the wire you removed. With master off the meter should read zero.
Switch to the lower current ranges and the reading should still be zero.
Don't have an ammeter (some cheaper multimeters don't), no problem. Just
hook a resistor (a car tail lamp bulb will do) between the battery terminal
and the wire you removed from that terminal. Set the meter to read DC
voltage and hook one lead to the battery terminal and the other to the wire
(this would be in parallel with the resister or bulb). There should be no
voltage drop across the resister and thus the meter should read zero volts.
If you get the desired zero reading, then the battery voltage is dropping
for another, perhaps more likely, reason. Sealed lead acid batteries of the
type normally used in gliders, have a life expectancy of no more than 5
years. They lose capacity as they age. If your battery isn't holding a
charge, then perhaps it's time to replace the battery?
bumper - ZZ
"Dare to be different . . . circle in sink."
to reply, the last half is right to left
Version: 6.0.521 / Virus Database: 319 - Release Date: 9/25/2003
Old October 8th 03, 06:47 PM
Steve B
Absolutely correct...
A simple test also is to as John mentioned remove one battery cable
terminal from the battery... take a voltmeter set to 12 v and attach
one lead to the battery terminal and one lead to the cable. If it
reads 12v then you have a current draw... start removing fuses or
breakers until the meter no longer reads 12 v and you will have the
source of the draw.
By the way... I am sure that you know how electrons work. I have
discovered that they run on smoke... when you break them all the smoke
comes out.
They don't call me Stevie Zappo for nothing.
"John Morgan" wrote in message ...
thank you
bumper - ZZ
Old October 8th 03, 08:46 PM
John Scott
A simple test to determine if it is a faulty battery, is simply to
disconnect one lead from the battery for a period of time, say a week, and
see if the charge leaks off. If so, they the battery has developed a
reduced internal resistance and needs to be replaced.
John Scott
Old October 8th 03, 09:31 PM
Michael
This isn't going to work for a slow leak (anything less than about 50
ma) because at low current, the resistance of a tail light is nearly
zero.
The typical glider battery is about 6 Ah, which means a 50 ma leak
will drain the battery flat in about a week.
There are all kinds of problems that cause slow leaks. A friend of
mine once discovered about a 20 ma leak in his installation where the
leakage was through the battery box grommet.
Michael
Please do not send email replies to this posting. They are checked
only sporadically, and are filtered heavily by Hotmail. If you need
to email me, the correct address is crw69dog and the domain name is
this old airplane dot com, but remove the numbers and format the
address in the usual way.
Old October 9th 03, 03:48 PM
Bob Greenblatt
in article , Scott at
wrote on 10/8/03 1:48 AM:
Do you happen to have a Microair transponder? It draws about 50ma when it's
OFF.
Bob & Lynne Greenblatt
Bob-lynneATcomcast.net--fix this before replying
Fine example of Tarver Engineering release for service running with scissors Military Aviation 79 March 3rd 04 02:48 PM
Fine example of Tarver Engineering release for service B2431 Military Aviation 1 February 29th 04 08:38 AM
PS Engineering Report Jeff Owning 44 December 8th 03 12:24 AM
PS Engineering Hankal Owning 0 December 5th 03 01:25 AM
