SPOT GEN3 vs. GEN1?
Old December 27th 16, 05:27 AM posted to rec.aviation.soaring
Tim Taylor
Default SPOT GEN3 vs. GEN1?
My trusty SPOT gen1 has developed a bad on/off switch. The GEN1 was very good and almost never missed a data point. Any reviews of the gen3 vs the origional?
TT
Old December 27th 16, 02:01 PM posted to rec.aviation.soaring
It's a poor man's InReach?
'Nuff said.
Old December 27th 16, 02:40 PM posted to rec.aviation.soaring
TT
I hope it's better than the Gen2(s) that I had; they would eat up brand new lithium batteries in a matter of hours. Spot had a recall on a certain range of serial numbers known to do that, but mine was outside of the serial number range, so they would not honor it. I switched to InReach and have had no problems. It's pricier, but you can take it offline in the winter and recoup some of that expense.
CG
Old December 27th 16, 03:49 PM posted to rec.aviation.soaring
Had a gen 1 and went to a gen 2. . had tracking issues with both.
Just want with Inreach after several glowing reviews from some people that responded to info request.
Have not used it yet, but really like the increased tracking interval, the fact it uses a different satellite system, that sounds more robust for this application, and the fact it keeps sending the message until it gets a verification from the satellite that it was received.
On Cumulus soaring there is a good break down on the different plans you can get so you can set up tracking as you would like. Not just the standard 10 min, but more frequent. Was called the Aviation plan, now called the Enterprise plans.
Hope this helps.
Kevin
92
Old December 27th 16, 04:32 PM posted to rec.aviation.soaring
jfitch
TT
An alternative that you rarely see discussed is the Yellow Bird. British company, targeted more towards yachts (where is it much more popular). Not inReach or Garmin, different plans, but uses the same technology and has the same features as inReach. The main advantage of this device is the battery life is FAR longer than inReach. inReach is fine if you charge it every other flight or so. the battery life if transmitting every 10 minutes is something less than 24 hours, if transmitting every 4 hours it will go about 4 days. The Yellow Bird will go 3 weeks transmitting every 15 minutes. I don't have one but several yachtsmen I know do.
Just throwing it out there in case you are looking for something different.
Old December 28th 16, 03:34 PM posted to rec.aviation.soaring
Frank Whiteley
TT
Old December 27th 16, 04:41 PM posted to rec.aviation.soaring
Dave Nadler
My two cents: I had problems with spot. Got an inreach and have been delighted; only problem is on-switch is not well-enough protected/recessed to prevent battery run-down if carelessly tossed in a bag of random junk.
See ya, Dave
Old December 27th 16, 04:51 PM posted to rec.aviation.soaring
Tony[_5_]
I had a gen 2 which crapped out and I've been more than happy with my gen 3.
The gen 3 has even survived multiple trips on a friend's high altitude balloon project where it was the only tracking device that survived. It did quite working above ~50,000ft but came.back on during descent and allowed them to find their experiment.
Old December 27th 16, 05:35 PM posted to rec.aviation.soaring
JS
See ya, Dave
Like others I dropped SPOT for InReach and am happy with it.
Don't see battery life as a problem: Lasts more than a week of average soaring days and is rechargeable with a micro USB cable.
Dave, there was a bug in one version that caused InReach to start up too easily. Try updating it (currently v1.4.9.8229) and see if that helps.
Old December 27th 16, 05:37 PM posted to rec.aviation.soaring
JS
See ya, Dave
Typo: latest version is 1.4.9.8299
Spot Gen3? Tim Taylor Soaring 25 September 16th 13 12:33 AM
Spot vs Spot Connect guy Soaring 9 January 25th 12 03:48 PM
Spot deal, today only, buy service get a free Spot Tim Taylor Soaring 3 December 1st 08 10:30 PM
SPOT GPS jeplane Soaring 17 February 5th 08 05:23 AM
SPOT D.Rizzato Piloting 0 February 5th 08 12:42 AM
