Proposed 2017 US Competition Rules Changes
Old December 29th 16, 08:35 PM posted to rec.aviation.soaring
Default Proposed 2017 US Competition Rules Changes
The 2017 US Competition Rules Changes are available for review at the SSA web site under Contest rules and process.
Feedback to RC members is welcomed and encouraged.
Happy New Year to all.
For the RC
UH Chair
Old December 30th 16, 04:28 AM posted to rec.aviation.soaring
In multiple places the word "nominal" is used such as:
6.12.4 15-Meter Class
6.12.4.1 Nominal wingspan is 15.0 meters.
6.12.2 Multiseat Class
6.12.2.1 Nominal wingspan is 20.0 meters.
It seems to me that the more appropriate word would be "maximum". Or is it just "nominal" here because there is a more in-depth definition of the glider classes that is fully included or specifically referred to elsewhere? [such as a reference to the FAI definitions].
BTW I think the RC did a good job of simplifying a lot of the rules language.
Chris
Chris
Old December 30th 16, 02:09 PM posted to rec.aviation.soaring
Chris
Chris
Read section 6.9 with respect to measurement of wing span.
UH
Old December 30th 16, 02:43 PM posted to rec.aviation.soaring
MNLou
I don't see any mention of the CD's decision on use of Flarm, stealth etc.
Did I miss it or was this dropped from the final version?
Thanks to the RC!
Lou
Old December 30th 16, 04:38 AM posted to rec.aviation.soaring
6.6.4 Reception of aircraft tracking data from any ground source is prohibited.
I wonder if the word "aircraft" would be better if it was worded as "glider" and or "Flarm".
I ask because I thought that part of the ADSB/PCAS or similar system collected transponder information and rebroadcast it from ground stations. [I may very well be wrong on this, and would welcome any correction].
I think this rule was intended to refer to Flarm ground stations but it may be too widely written and risk confusing pilots by suggesting a standard PCAS/ADSB or transponder system may be technically violating this rule.
Chris
Old December 30th 16, 03:35 PM posted to rec.aviation.soaring
Thank you for the additions under "3.1.3 Competition Director". I doubt you guys will start lining up for the job :-) but at least it'll make it worth your while. And hopefully it will make it easier to recruit someone.
J9
USA Competition Rules Changes Proposed for 2013 John Godfrey (QT)[_2_] Soaring 26 January 25th 13 05:42 AM
USA 2013 Proposed Competition Rules Changes Available John Godfrey (QT)[_2_] Soaring 20 January 9th 13 10:17 AM
2011 USA Proposed Competition Rules Changes Posted. John Godfrey (QT)[_2_] Soaring 22 December 31st 10 02:54 PM
Proposed US Competition Rules Changes for 2010 [email protected] Soaring 1 December 17th 09 05:20 PM
2008 Proposed US Competition Rules Changes [email protected] Soaring 18 December 31st 07 07:21 PM
