Continental 0300 Yes or NO?
Old January 15th 17, 01:56 AM posted to rec.aviation.piloting
Default Continental 0300 Yes or NO?
On Sunday, February 7, 2016 at 9:51:48 PM UTC-5, wrote:
Do you guys think it better to run 87 Oct rather than 100 LL , why and where do u find it ?
Marine gas. Marathon produces it. No lead, no ethanol.
Old July 24th 20, 04:42 AM posted to rec.aviation.piloting
Stjepan Nikolic
Wow the article started in 1998.. I hope we can get an update from the topic poster.
22 years later I own 1960 172A with O300-C and flying almost on a daily basis.. It is a world different aircraft from my flying school's C172N 4 cyl Lycoming o320.. Certainly C172N has 20hp more and flies 10kts faster, however in my opinion C172A flies "better" and is not nose-heavy as N model.
300 cubic inches is actually 5 lit (5000cc) engine, which is not small in automotive world, therefore not sure where the "small" engine is coming from..
145hp divided by 6 cylinders or 5000cc means the engine is not tuned for super performances, neither engine is running over-stressed unless you prefer flying faster. It's the old school built to last. I've heard about cases when one cylinder failed, other 5 took the aircraft to the aerodrome.
Fly regularly (this applies to all engines), make sure it has the oil as per spec, make sure cht and oil temps are in green (you can climb slower at speed higher than Vy, e.g. 80kts, thus cooling the engine more), once straight&level reduce to 2200rpm and watch how temps are going down.. Generally, look after your engine and it will last much more than TBO. Mike Busch mentioned in one of his Youtube videos he runs 250% of TBO.
Finally I don't think anything can replace the truck-like sound coming out of 6cyl o300 .. My answer to the question is obviously YES
Safe landings!
USN2 0300 TBD-1 1938.jpg Joseph Testagrose Aviation Photos 2 May 11th 15 10:46 PM
Continental 757 Glenn[_2_] Aviation Photos 0 October 3rd 09 01:45 PM
Q: can a Continental A65-8 oilsardine[_2_] Home Built 15 April 19th 09 03:38 PM
Continental 757 18R @ MCO Glen in Orlando Aviation Photos 4 November 30th 06 03:15 AM
Continental O-200 ? Stealth Pilot Home Built 48 September 23rd 06 06:32 PM
