I am considering buying a second hand glider that was recently =
refinished with poly paint as opposed to gel coat. What is poly paint? What are the pros and cons of poly paint compared to gel coat? Regards Miguel |
as long as the surface below was properly prepared.. should be ok.. that is
the standard for replacing old gel coats.. sand it down.. re profile the wing.. and paint it.. BT "Miguel Lavalle" wrote in message ... I am considering buying a second hand glider that was recently = refinished with poly paint as opposed to gel coat. What is poly paint? What are the pros and cons of poly paint compared to gel coat? Regards Miguel |
I think that Miguel was asking the difference between gel coat and
poliurethane paint. Anyway I don't have enough knowledge about the matter to explain it! "BTIZ" escribió en el mensaje news:4ljnb.94824$La.83537@fed1read02... as long as the surface below was properly prepared.. should be ok.. that is the standard for replacing old gel coats.. sand it down.. re profile the wing.. and paint it.. BT "Miguel Lavalle" wrote in message ... I am considering buying a second hand glider that was recently = refinished with poly paint as opposed to gel coat. What is poly paint? What are the pros and cons of poly paint compared to gel coat? Regards Miguel |
Hi Miguel,
I used to own a Sportvega which was finished in a polyurethane paint. As I understand the explanations at the time, the polyurethane finish is softer, more elastic and cheaper to re-do. At around that time the BGA DG 500 went to some astronomical height above Aboyne, in Scotland. I was told that the extremes of temperature to which it was exposed and, possibly, the rapidity of temperature change on ascent and descent, resulted in extensive gel coat cracking; and that the polyurethane finish on my rather ancient Sportvega would not have been similarly affected. Lastly, if you do the prep work, a reasonable garage could respray the glider for you at much less expense than the usual aviation prices. Steve -----Original Message----- From: Glider Pilot Network ] Sent: Tuesday, October 28, 2003 9:46 AM To: Steve H Subject: [r.a.s] Poly paint ------------------------------------------------------------ Newsgroup: rec.aviation.soaring Subject: Poly paint Author: Jose M. Alvarez Date/Time: 09:40 28 October 2003 ------------------------------------------------------------ I think that Miguel was asking the difference between gel coat and poliurethane paint. Anyway I don't have enough knowledge about the matter to explain it! "BTIZ" escribió en el mensaje news:4ljnb.94824$La.83537@fed1read02... as long as the surface below was properly prepared.. should be ok.. that is the standard for replacing old gel coats.. sand it down.. re profile the wing.. and paint it.. BT "Miguel Lavalle" wrote in message ... I am considering buying a second hand glider that was recently = refinished with poly paint as opposed to gel coat. What is poly paint? What are the pros and cons of poly paint compared to gel coat? Regards Miguel ------------------------------------------------------------ |
pros and cons of poly paint compared to gel coat? Hi Miguel, There are two "Poly" paints used on sailplanes, Polyeurathane and Acrylic Urathane. I just repainted my Genesis 2 with Acrylic Urathane and found it very easy to work with. Preped the non-damaged areas by contouring with 60 grit, followed by 220 and then paint with 3 medium coats. Wet sandad with 600wet and 800wet, then wool buffer and liquid rubbing compound. The Genesis 2 and LAK -17 are painted with Acrylic Urathane by the manufacturer. The only down-side that I am aware of, is the softer paint (urathane) may blister more quickly, if left too long in a wet trailer JJ Sinclair |
JJ Sinclair wrote:
The Genesis 2 and LAK -17 are painted with Acrylic Urathane by the manufacturer. The only down-side that I am aware of, is the softer paint (urathane) may blister more quickly, if left too long in a wet trailer JJ Sinclair Actually the choice of paint is an option (at least on the LAK-17). Ours is painted in painted with polyurethane. For $400 more we could have had it painted in acrylic urethane, but we couldn't find anyone who would say flat out it was worth the extra money. They also give you the option of the ugly (but apparently bulletproof) epoxy paint that was standard on the earlier LAKs... Marc |
option of the ugly (but apparently bulletproof) epoxy paint that was I would stay away from the epoxy paint because it yellows very rapidly and one ends up with a ship the color of urine. BTW, I have the color of the Acrylic Urathane used on the Genesis 2. It is; Toyota 040/HP JJ Sinclair |
At 22:12 28 October 2003, Mike Borgelt wrote:
A few people around here got Ventus 2's unfinished and had them painted here with polyurethane. Mike Borgelt If it were now they would have been able to get them finished in PU by the factory. John Galloway |
On 28 Oct 2003 22:19:54 GMT, John Galloway
wrote: At 22:12 28 October 2003, Mike Borgelt wrote: A few people around here got Ventus 2's unfinished and had them painted here with polyurethane. Mike Borgelt If it were now they would have been able to get them finished in PU by the factory. John Galloway Schempp's are offering that now??? Mike |
![]() Yep! They finally are. So are Stemme and DG/LS Paul If it were now they would have been able to get them finished in PU by the factory. John Galloway Schempp's are offering that now??? Mike |
Paint Stripper? | PETER H. OUELLETTE | Home Built | 9 | November 30th 04 06:12 PM |
One coat paint for aluminum? | [email protected] | Home Built | 10 | September 17th 04 07:01 AM |
Good Paint Remover? | Marco Leon | Owning | 2 | June 22nd 04 07:58 PM |
Radar Absorbing Paint | robert arndt | Military Aviation | 2 | December 2nd 03 05:09 PM |
Choice of Paint for use over Copper foil Antennas | Charlie Precourt | Home Built | 1 | December 2nd 03 02:51 AM |
