I've had a kind of unnerving vibration in my RV-4 since first
flight. I looked into harmonic dampers, but they're pretty expensive, so I decided to give dynamic balancing a shot first. $200 and 1 hour later, my engine runs *much* smoother. It measured 0.3+ ips on the first run, so the guy weighed and added an AN-4 bolt, nut, and a few washers to the flywheel. Next run it was down to 0.05 ips and felt markedly different, much smoother and quieter. I ran out of time and weather at the same time, so I haven't flown it yet, but I don't see how it can't help but be smoother. It remains to be seen whether or not I'll have the pronounced shake at some power settings and speeds, but I've also cut back the baffles where metal rubbed on fiberglass and tightened things under the cowl a bit. We'll see. A little disturbing when the A&P noticed that a screw had backed out of the left harness-to-mag mount. As I was tightening it I noticed that another was missing altogether - a single screw was holding the left harness to the mag. I've replaced and tightened everything and sealed the threads, and done a thorough check of every other fastener under the cowl. I *hope* it was vibration-related and that we've fixed the problem, but you can bet I'll keep a pretty close eye on it from now on. I also had to replace the oil temp sender which failed inside the sender, again presumably (hopefully?) due to vibration. Sandy at Grand Rapids came through for me and got a new one out in what must be record time. They're very pleasant to deal with. Also took the opportunity to do a compression test (first one) while the cowl was off. Three strong cyls, #3 (the continuing problem child) was a little low, but the A&P said it *should* come up as the engine breaks in. No valve leakage that he could tell, it seemed like it was getting past the rings. Oil shows a little blow-by too. Chrome cylinders with 20 hr, so my assignment is to "run the [snot] out of it" and see if it improves in 10 or so hours. Things I love about this airplane (in addition to the usual stuff you hear about RVs): Grand Rapids Engine Monitor 4-cyl temps have really helped troubleshooting, and adjustable alarms are a comfort. AnywhereMap GPS Awesome. Freakin' awesome. 160 KIAS in the overhead pattern and a 4g break to downwind. Hehe. John Ousterhout once told me "I hope you don't start doing those 'break' entries like the rest of the RV guys." It's the only way I can slow it down. Ob.safety note: Only at home when it's not busy and the wind favors a direct entry to upwind. Taildraggers for the brain-dead. I've only got a little taildragger time, but (like the rest of my experience) spread thin over a bunch of different types. The RV-4 is by far the easiest-landing taildragger I've ever flown, and that includes other RV's. Increased confidence and proficiency probably have a lot to do with it, but that's the way it seems, anyway. Of course I still nearly had it off the runway once in a stiff crosswind. Electric Trim and Flaps. I work the heck out of the trim, as you might expect in an airplane with such a wide speed range. Lateral trim (electric or manual) is an absolute necessity in flight test as far as I'm concerned. Electric flaps are less of a struggle than manual at a fairly high-workload part of the flight (see 'break entry' above ,although manual (in a -6, anyway) aren't that big of a deal to use either. Things I'm still working on (that I'd do differently next time): The panel: The engine monitor is on a sub-panel, where it's out of my primary scan. Given that I'm trying to keep a close eye on temps, it's in a less-than-ideal spot. I wish I had room for it on the panel. Single radio, no VOR: While I love the AnywhereMap stuff, I don't trust the iPaq it's installed on. The batteries are ^(*)&. It's wired into the airplane electrical system, but still needs to charge in between flights. If it dies enroute or on an overnight I'm committed to dead reckoning. As such I plan to stick close to highways and well-defined landmarks for trips over unfamiliar territory. A second comm, while certainly not required, would be nice as well. I've got a handheld, but haven't patched it into the comm system yet. External power: Dead battery. No external power jack. Do the panel crawl. ^*&%%*&( Switches: I harp and harp and harp about human factors, and then I use identical switches throughout the switch panel (in my defense I *did* try and space them so that the differences would be obvious). I've turned the electrical system off at least once thinking I was turning off the fuel pump. Now I look. I think I'm going to rotate the FP switch so that it's side-to-side throw or put a different bat on the master switch. At least it wasn't the mags. Vacuum gyros: A dead AH and probably dying VG. What with all the solid-state (or nearly so) attitude systems out there I don't see any reason to mess with these again. Interestingly enough, the Falcon (electric) turn coordinator is holding up better than the vacuum gyros, in spite of its reputation. Done for now. Dave 'brain dump' Hyde RV-4 in flight test, EAA Tech Counselor |
"Dave Hyde" wrote in message ... I've had a kind of unnerving vibration in my RV-4 since first flight. I looked into harmonic dampers, but they're pretty expensive, so I decided to give dynamic balancing a shot first. $200 and 1 hour later, my engine runs *much* smoother. It measured 0.3+ ips on the first run, so the guy weighed and added an AN-4 bolt, nut, and a few washers to the flywheel. Next run it was down to 0.05 ips and felt markedly different, much smoother and quieter. I ran out of time and weather at the same time, so I haven't flown it yet, but I don't see how it can't help but be smoother. It remains to be seen whether or not I'll have the pronounced shake at some power settings and speeds, but I've also cut back the baffles where metal rubbed on fiberglass and tightened things under the cowl a bit. We'll see. I've had dynamic propeller balancing done on every airplane I've owned. It's absolutely the best dollars I've ever spent on maintenance. It can make 4-cylinder engines feel like 6-cylinder. I feel strongly the money spent is quickly recovered on the things that don't break because of vibration. Just do it, you'll never regret it. Bill Daniels |
Bill Daniels wrote:
I've had dynamic propeller balancing done on every airplane I've owned. It's absolutely the best dollars I've ever spent on maintenance. It can make 4-cylinder engines feel like 6-cylinder. I have a dynamic balanance done every time my prop is R&R'ed on the plane. Unfortunately, on my prop (a Hartzel 12v20) thats every 250 hours due to a recurrent AD. Vibration is not your friend. -- Frank Stutzman Bonanza N494B "Hula Girl" Hood River, OR |
"Bill Daniels" wrote in message news:AuZyc.22988$2i5.20527@attbi_s52... "Dave Hyde" wrote in message ... I've had a kind of unnerving vibration in my RV-4 since first flight. I looked into harmonic dampers, but they're pretty expensive, so I decided to give dynamic balancing a shot first. $200 and 1 hour later, my engine runs *much* smoother. It measured 0.3+ ips on the first run, so the guy weighed and added an AN-4 bolt, nut, and a few washers to the flywheel. Next run it was down to 0.05 ips and felt markedly different, much smoother and quieter. I ran out of time and weather at the same time, so I haven't flown it yet, but I don't see how it can't help but be smoother. It remains to be seen whether or not I'll have the pronounced shake at some power settings and speeds, but I've also cut back the baffles where metal rubbed on fiberglass and tightened things under the cowl a bit. We'll see. I've had dynamic propeller balancing done on every airplane I've owned. It's absolutely the best dollars I've ever spent on maintenance. It can make 4-cylinder engines feel like 6-cylinder. I feel strongly the money spent is quickly recovered on the things that don't break because of vibration. Just do it, you'll never regret it. Bill Daniels Homebuilders do this themselves with a homemade vibrator and paint. You slide a flexible wire rod up and down a scale on the device attached to your aircraft until it vibrates, then balance with paint on the lighter tip. You find the lighter tip and diminish the vibration by trial and error. Not as expensive but works. There are drawings and instructions somewhere on the net, maybe at the Mooney Mite or Culver site. |
" jls" wrote in message
... Homebuilders do this themselves with a homemade vibrator and paint. You slide a flexible wire rod up and down a scale on the device attached to your aircraft until it vibrates, then balance with paint on the lighter tip. You find the lighter tip and diminish the vibration by trial and error. Not as expensive but works. There are drawings and instructions somewhere on the net, maybe at the Mooney Mite or Culver site. I found the article at http://www.mooneymite.com/articles/f...ncingprops.htm Rich S. |
Mouser (www.mouser.com), Digi-Key (www.digikey.com) and several electronic
wholesale stores in and around St. Louis sell colored toggle bat caps. Different colors for different functions. They are about a nickel apiece. jim Dave Hyde shared these priceless pearls of wisdom: - -^*&%%*&( Switches: - I harp and harp and harp about human factors, and then I - use identical switches throughout the switch panel (in - my defense I *did* try and space them so that the differences - would be obvious). I've turned the electrical system off - at least once thinking I was turning off the fuel pump. - Now I look. I think I'm going to rotate the FP switch - so that it's side-to-side throw or put a different bat - on the master switch. At least it wasn't the mags. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir wrote...
Different colors for different functions. Color-coded switches don't cut it from a human factors standpoint. I need something that *feels* different to a gloved hand. Turning the fuel pump switch 90 deg will do it, as would a bigger bat. If I can see the color, I can see whether or not I've got the right switch, regardless of the color. Obviously, the interim workaround is to visually verify any switch before throwing it. Not a big deal in the short term. Dave 'tactical tactile' Hyde |
"nauga" wrote: I need something that *feels* different to a gloved hand. Turning the fuel pump switch 90 deg will do it, as would a bigger bat. Dave 'tactical tactile' Hyde +++++++++++++++++++++++++++++ Max tactile is..... Going 'gloveless' whether one is stroking an aircraft or a significant other. g Barnyard BOb - |
Things I'm still working on (that I'd do differently next time): While I love the AnywhereMap stuff, I don't trust the iPaq it's installed on. The batteries are ^(*)&. It's wired into the airplane electrical system, but still needs to charge in between flights. Dave 'brain dump' Hyde RV-4 in flight test, EAA Tech Counselor ++++++++++++++++++++++++++++++++++++++++++ I use a Garmin 295. But, for real details and obstruction info my Anywhere Map blows Garmin away. [My Ipaq does just fine plugged into the cigar lighter spot.] BTW.... If you want greater utility from your Ipaq, consider 'Mapopolis' software for tooling down the highway of life in your merry Oldsmobile and/or favorite RV. http://www.mapopolis.com/ Barnyard BOb - |
I've been dynamic prop balancing for 15 years.
0.3 plus a little is not a severe vibration but could be improved. Many skeptics would call it smooth to begin with. What was the IPS amplitude of the engine aft,.... or did the operator just use a single sensor? A sensor on the rear will give you an idea of crankshaft and rod balance. Lycomings usually are 0.15 to 0.18 the rear. If it was a custom balanced engine, the rear should run just as fine as the front. I'vd balanced some by placing correction weight on a Lycoming ring gear but have gotten away from that method because it statistically takes far greater weight per unit of correction. About 30% -50% more than if the correction weight is placed on the spinner bulkhead, or if the prop's static weights are adjusted. Also, the method works less well on props with extensions. I looked at the mooneymite site. Interesting. The same principle as a reed tach. Its just a pendulum adjusted to resonance. Insturment face vibration frequency will be at crankspeed, 1/2 crankspeed or some other multiple half order. The author is painting the tips, which will change the spanwise balance but not chordwise balance. I don't have the data handy anymore, but as I recall a long ago experiment, 10 square inches of painted tip needed about 11 mils of paint thickness to weigh one gram. Can't remember what paint Iused, proably Krylon. On a 76" inch prop, this means a 36 gram-inch balance correction which will be about a 0.20 IPS. Actually, one would probably have just as good luck in trial & error by adding washers under spinner screws systematically. Or if you had some way to measure engine movement, some sort of overhanging dial indicator, one can easily find the solution by plotting a 3 way polar chart. Take Care Kent Felkins Tulsa |
