![]() http://wiki.warthunder.com/index.php?title=MiG-15 First taking to the air in December of 1947, the Mikoyan-Gurevich MiG-15 jet fighter aircraft came as a massive shock to the west when it appeared in the skies over Korea in the early 1950s. The swept wing fighter quickly proved itself as a capable and effective combat aircraft and forged a fearsome reputation. The prototype I-310 was designed around the British Rolls Royce Nene engine which was purchased under licence from Great Britain as the RD-45. Featuring sleek swept back wings,tricycle undercarriage and the same armament as its predecessor, the MiG-9, in the form of 2 x 23mm NS-23 cannons (Later replaced by NR-23 cannons in the MiG-15Bis model) and a single 37mm N-37D cannon all mounted centrally under the nose intake. The new aircraft was designed as an interceptor with heavy armament capable of quickly taking out bomber formations and was one of the most advanced aircraft in the world at the time. Entering service between 1949-50, the MiG-15 made its operational combat debut in the Korean War, completely outclassing the first generation jet fighter aircraft of the UN forces such as the F-80 and F-84. The MiG’s excellent rate of climb, high speed performance and deadly weaponry proved superior to the early jets and was only challenged by the arrival of the North American F-86 Sabre. At the time, the Sabre was the only aircraft capable of effectively combating the MiG in aerial combat and the pair became synonymous with the conflict. From 1950, the MiG-15 was later developed into the Bis model, featuring a new engine, armament changes and minor overall improvements, however the aircraft would ultimately lead to the development of the MiG-17. The MiG-15 was also a hugely successful export aircraft, operated by countless nations such as Poland, Czechoslovakia, East Germany, China, North Korea and Vietnam to name but a few. Licence built versions of the MiG-15 also existed such as the Chinese J-2, Czech S-102/3 and Polish Lim-1. The MiG-15 is a true icon of aviation and will provide experienced pilots with an impressive top tier jet fighter when employed to its strengths, being more than a match to any other aircraft in game. Pros and cons of the plane As the MiG-15 is essentially a slightly merged MiG-15bis, it shares much of its performance issues and abilities. Pros Flaps can be deployed at high speeds Capable and useful airbrake High rate of climb Great acceleration Deadly armament capable of snap shots Cons Worse energy retention than the Sabre Poor turning circle Compression at high speeds Suffers from moderate stock syndrome Armament difficult to use (low velocities, low ammo and two different trajectories) Guns tend to spark a lot (the N-37 in particular a lot) No G-Suit, so maintaining control is difficult when turning at high speeds General characteristics Crew: 1 or 2 Length: 10.08 m (33 ft 1 in) Wingspan: 10.08 m (33 ft 1 in) Height: 3.7 m (12 ft 2 in) Wing area: 20.6 m2 (222 sq ft) Airfoil: TsAGI S-10 / TsAGI SR-3 Empty weight: 3,630 kg (8,003 lb) Gross weight: 5,000 kg (11,023 lb) Max takeoff weight: 6,105 kg (13,459 lb) Fuel capacity: 1,420 l (312.4 imp gal; 375.1 US gal) Powerplant: 1 × Klimov VK-1 centrifugal flow turbojet, 26.5 kN (6,000 lbf) thrust Performance Maximum speed: 1,059 km/h (658 mph; 572 kn) at sea level 1,033 km/h (558 kn; 642 mph) at 5,000 m (16,000 ft) 992 km/h (536 kn; 616 mph) at 10,000 m (33,000 ft) Cruising speed: 850 km/h (528 mph; 459 kn) Range: 1,240 km (771 mi; 670 nmi) Service ceiling: 15,500 m (50,853 ft) Rate of climb: 51.2 m/s (10,080 ft/min) at sea level 36.2 m/s (7,130 ft/min) at 5,000 m (16,000 ft) 21 m/s (4,100 ft/min) at 10,000 m (33,000 ft) Time to altitude: 5,000 m (16,000 ft) in 2 minutes 10,000 m (33,000 ft) in 5.2 minutes Wing loading: 240.8 kg/m2 (49.3 lb/sq ft) Thrust/weight: 0.54 (0.544 lbf/lb) Armament 2x NR-23 23 mm (0.906 in) cannon in the lower left fuselage (80 rounds per gun, 160 rounds total) 1x Nudelman N-37 37 mm (1.457 in) cannon in the lower right fuselage (40 rounds total) 2x 100 kg (220 lb) bombs, drop tanks, or unguided rockets on 2 underwing hardpoints. * |
