The most recent Sport Aviation has an article on make up hoses. The
author states that 'you must use 37 degree fittings' and as is typical, gives no reason why. Is there a reason for this that involves the laws of nature, vs the "laws of the FAA"? -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
author states that 'you must use 37 degree fittings' and as is typical, gives no reason why. Is there a reason for this that involves the laws of nature, vs the "laws of the FAA"? Veedube... No, the law of common sense. The fittings for hoses and tubing are 37 degrees, whereas those made for air conditioning are another value and those for plumbing are....and those for autos are....another. If you want leak-free fittings, you have to use parts which mate with the correct and matching angles. Neal |
Ernest Christley wrote:
The most recent Sport Aviation has an article on make up hoses. The author states that 'you must use 37 degree fittings' and as is typical, gives no reason why. Is there a reason for this that involves the laws of nature, vs the "laws of the FAA"? There is no FAA rule specifying the type of flared fittings you must use in your homebuilt aircraft. However, the flared fittings used in most modern aircraft are 37 degree AN/MS fittings. Also, the flared fittings used in professional race cars are typically 37 degree AN/MS fittings. There is no "magic" in the 37 degrees. It is simply an aircraft standard that has become a de facto performance standard for several non-aviation applications as well. The flared fittings under the hood of your family car are likely SAE 45 degree fittings. The flares used in your home plumbing are also 45 degrees. Someone mentioned Tony Bingelis' books. Tony specified AN/MS 37 degree flares in his books. AC 43.13-1b specifies AN/MS 37 degree flares as well. David O -- http://www.AirplaneZone.com |
On Wed, 16 Jun 2004 05:11:24 -0400, David O wrote:
Ernest Christley wrote: The most recent Sport Aviation has an article on make up hoses. The author states that 'you must use 37 degree fittings' and as is typical, gives no reason why. Is there a reason for this that involves the laws of nature, vs the "laws of the FAA"? There is no FAA rule specifying the type of flared fittings you must use in your homebuilt aircraft. However, the flared fittings used in most modern aircraft are 37 degree AN/MS fittings. Also, the flared fittings used in professional race cars are typically 37 degree AN/MS fittings. There is no "magic" in the 37 degrees. It is simply an aircraft standard that has become a de facto performance standard for several non-aviation applications as well. The flared fittings under the hood of your family car are likely SAE 45 degree fittings. The flares used in your home plumbing are also 45 degrees. Someone mentioned Tony Bingelis' books. Tony specified AN/MS 37 degree flares in his books. AC 43.13-1b specifies AN/MS 37 degree flares as well. David O -- http://www.AirplaneZone.com 45 deg flared fittings seem to work OK in non-aviation applications, if used with the fittings and tubing material that are appropriate. But the higher flare angle forces the end of the tube to stretch further when the flare is formed, putting more stress on it. So even if you could find 45 deg flared fittings, there is no guarantee that aviation tubing could take a 45 deg flare without later cracking. You would be conducting a big experiment. Yes, this is experimental aviation, but tubing is usually used in critical systems (fuel, oil, hydraulics), and this is not the place to be conducting experiments. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ e-mail: khorton02(_at_)rogers(_dot_)com |
37-degree is the most common angle used for industrial fluid power apps.
(hydraulics, high-pressure lube, etc.). However, 45, 90, and a few other oddball/metric/Japanese standards do exist... just to ruin someone's day when something breaks. Harry |
Actually, the 37deg. ftg Does put a little more pressure on the mating
surfaces.---Envision a 10 or 15 deg fitting, like forcing a long tapered pin into a long tapered hole--fits real tight.----And that's exactly what the newer line of MS hoses does---I haven't measured the angle but it looks on the order of 2 to 5 deg. This gives a very tight fit and still uses aluminum mating parts. The downside, if any, is that the mating pieces must be machined to very close tolerances, or the "plug" will bottom out in the socket before the tapers come into contact. Jerry Ernest Christley wrote: The most recent Sport Aviation has an article on make up hoses. The author states that 'you must use 37 degree fittings' and as is typical, gives no reason why. Is there a reason for this that involves the laws of nature, vs the "laws of the FAA"? -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
The 37° is the angle of the taper seal in aircraft fittings. Automotive uses
45°. So when you work on an aircraft, that is what you expect. Mixing the two could be a big problem. With that said, My Factory built Bellanca has two different style fittings as it was built with war surplus Air Corp fittings. Since they are no longer available, some of the later repairs and alterations use the current style fittings. They are both 37° but the nut threads are different. AC fittings were gray, Current are blue. -- Cy Galley - Chair, Emergency Aircraft Repair Safety Programs Editor - TC EAA Sport Pilot "Ernest Christley" wrote in message . com... The most recent Sport Aviation has an article on make up hoses. The author states that 'you must use 37 degree fittings' and as is typical, gives no reason why. Is there a reason for this that involves the laws of nature, vs the "laws of the FAA"? -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
Cy Galley wrote:
The 37° is the angle of the taper seal in aircraft fittings. Automotive uses 45°. So when you work on an aircraft, that is what you expect. Mixing the two could be a big problem. With that said, My Factory built Bellanca has two different style fittings as it was built with war surplus Air Corp fittings. Since they are no longer available, some of the later repairs and alterations use the current style fittings. They are both 37° but the nut threads are different. AC fittings were gray, Current are blue. So when you put automotive parts in an aircraft... That is not a joke, BTW. Very good answers from several people. Thank you Cy, Jerry and Kevin. But your answers all beg the question, "If the 37 flare holds better and is less likely to damage the hose...why would anyone standardize on 45?" Is the 45 easier/cheaper to make? -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber |
As almost everyone else said, it's the AN standard at 37 degrees. If you have
to flare tubing and there's not much to do, a standard 45 flare kit can be modified. We had to do that on our plane for an STC installation... needed ONE end flared. Rather than spending $100 on a tool to use once, or potentially more than that for an aircraft shop to do it, we bought a $10 Home Depot special. Chucked it up in the lathe at 37 degrees and cut a new flare taper... worked fairly well (aside from being a bit of a POS flare tool to begin with). YMMV -Cory Ernest Christley wrote: : The most recent Sport Aviation has an article on make up hoses. The : author states that 'you must use 37 degree fittings' and as is typical, : gives no reason why. Is there a reason for this that involves the laws : of nature, vs the "laws of the FAA"? : -- : http://www.ernest.isa-geek.org/ : "Ignorance is mankinds normal state, : alleviated by information and experience." : Veeduber -- ************************************************** *********************** * The prime directive of Linux: * * - learn what you don't know, * * - teach what you do. * * (Just my 20 USm$) * ************************************************** *********************** |
Straight restrictor fitting? | nauga | Home Built | 5 | April 15th 04 01:06 PM |
Need advice on Aeroquip fittings | Corky Scott | Home Built | 2 | December 12th 03 12:46 AM |
LEDs with Strobe lights | pekka1510 | Home Built | 11 | August 31st 03 11:36 PM |
37 degree flare, 1/8" stainless | Richard Riley | Home Built | 8 | August 29th 03 04:21 AM |
