Do you crab or forward slip in X wind landings
Old February 25th 17, 09:03 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Do you crab or forward slip in X wind landings
Do you crab or forward slip landing in x-winds and why? When I was taught how to fly an airplane the crab method was used when I transitioned to gliders my instructor emphasized forward slip over crab. Years later I have established my procedures, but I thought this might be a useful discussion for newer pilots.
Old February 25th 17, 09:27 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Standard UK training, at least when I learnt and I haven't heard any
different from our instructors since, is to crab with wings level on
approach and kick the glider straight just before touchdown. Another
point is that we are taught to do fully held-off landings regardless of
the size and surface of the club field on the grounds that its the only
sensible way to land out, so we should be able to do it well. I think the
two are related because this keeps the wings level while speed bleeds off
and its fairly easy to kick the glider straight as it settles. If you
also manage a neat two-pointer you can award yourself brownie points as
well as knowing that this will help to keep the glider running straight
despite any cross-wind.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old February 25th 17, 10:00 PM posted to rec.aviation.soaring
Tango Eight
org |
What two seater is being used to teach fully held off landings?
-Evan
Old February 25th 17, 11:52 PM posted to rec.aviation.soaring
crab.
might
the two are related because this keeps the wings level while speed
bleeds off and its fairly easy to kick the glider straight as it
settles. If you also manage a neat two-pointer you can award yourself
brownie points as well as knowing that this will help to keep the
glider running straight despite any cross-wind.
martin@ | Martin Gregorie gregorie. | Essex, UK org |
In my club, all of our trainers. We have a couple of ASK-21s, a Puchacz
and a G103 Twin Acro 2.
org |
Old February 26th 17, 07:19 AM posted to rec.aviation.soaring
Bruce Hoult
org |
I doubt people are doing *fully* held off landings i.e. with the glider actually stalling on. More likely it's "held off until the glider is in the same attitude it will have on the ground .. or a tiny bit more" and then allowed to settle in that attitude. As it slows, lift at that AoA becomes insufficient to support the glider, but there is never aerodynamic stall. Maximum AoA / CL is not reached. Once you touch the ground AoA can not be increased, so lift can't be, so you can't start flying again (absent a massive headwind gust) and the *objectives* of a "fully held off" landing are acheived..
Even nose-draggers like the ASK21 have a tail wheel and are landed main-and-tail or slightly tail first.
The only exception I know is the PW5. I've never seen anyone land a PW5 tail first. We had an informal challenge to do it when we first got ours. No one managed it.
Old February 26th 17, 11:47 AM posted to rec.aviation.soaring
crab.
might
of the size and surface of the club field on the grounds that its the
only sensible way to land out, so we should be able to do it well. I
think the two are related because this keeps the wings level while
speed bleeds off and its fairly easy to kick the glider straight as
it settles. If you also manage a neat two-pointer you can award
yourself brownie points as well as knowing that this will help to
keep the glider running straight despite any cross-wind.
Good description. I've never flown a PW6, but I have flown a PW5 and
suppose its also near impossible to fully hold off. Of course fully held
off landings work a treat for ASK-13s and T-21s: both have a nose skid.
In my experience my Std Libelle is the hardest glider to hold off for a
nice two-point landing, primarily because the weak airbrakes mean that if
you start raising the nose even slightly early it will balloon, but its
always a nice end to a flight when both wheels touch the floor together.
org |
Old February 25th 17, 10:01 PM posted to rec.aviation.soaring
Jonathan St. Cloud
One comment on the crab method, you must transition to forward slip before touchdown. What if when you if you go to kick out the crab, just above runway and you find out that the x-wind is too strong for a forward slip to maintain track.
org |
Old February 25th 17, 11:46 PM posted to rec.aviation.soaring
If I do the crab+held-off landing properly, I should be under 3 ft up (at
the very most: half that is better) and already sinking when I kick the
glider straight. If you're too early straightening up, of course you're
being blown sideways when you land.
AFAIK the upwind wing low technique you guys call 'forward slip' isn't
taught to UK glider pilots. I was never taught it and can't recall seeing
anybody using it on our field.
org |
Old February 27th 17, 06:47 AM
POPS POPS is offline
Member
First recorded activity by AviationBanter: Dec 2010
Yaw string and coordination in big Xwind landings is my question, with a real life experience that happened to me... I still wonder if I did the right thing 3 years ago. Could someone in the know talk about the lack of any coordination in these situations?
After returning to the field at 3500' agl, the wind had turned on final, 90 degrees to the left across the only possible place to land, on a plowed dirt strip. AWOS had the wind solid at 20 gusting to 28. I lingered as long as I could but the massive cell to the east was not moving or letting up. Nothing but rough desert landscape everywhere and altitude winding down.
Field partially disappearing in dust at 800 ft. I set speed at 70 kts, turned base into the wind, then final and into a deep forward slip, windward wing down, way down, but not quite holding my target from drifting away from me to windward. The yaw string was aligned nearly 70 degrees across the canopy which Really got me alarmed. I was calm, pretty smooth and super focused. Out of the slip and into a huge crap, no problem. Yaw string was now about 30-40 degrees out with my wings level crab at maybe 30 degrees to the left. Had control of my target now with partial spoilers. Field length maybe 500 yards long or so. I went to the deck and released rudder and flared, lowered my left wing tip a bit I think. Did a wheel landing at maybe 40, full spoilers and into breaks as the field seemed to be getting short. Wind got under my left wing and put the leeward wing down into the dirt at 15+ kts or so on the roll out. Lost the wing tip skid but held it mostly straight with my big rudder.
I heard conflicting advice and comments about coordination and this landing.
Sorry for the long post.
org |
Old February 27th 17, 09:42 AM posted to rec.aviation.soaring
Bruce Hoult
my big rudder.
landing.
crab.
might
be a useful discussion for newer pilots.-
off
org |
POPS
Why would your yaw string be 30 - 40 degrees to one side in a crab? It should be dead straight.
Vector Wind, Relative Wind calculation C 302/303 [email protected] Soaring 2 December 9th 08 07:23 PM
Crab, slips, and crossed controls Amine Piloting 190 September 27th 08 07:59 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (0/1) JR[_2_] Aviation Photos 0 August 13th 08 09:35 PM
video of cross-wind landings jbaloun Home Built 0 June 2nd 06 01:56 AM
Got some neeed help with cross-wind landings... Ekim Piloting 13 October 23rd 04 04:40 PM
