I am pleased to announce that with effect from today, 25 November 2003,
some new and updated IGC-approval documents take effect and will appear in full on the gliding/gnss web site shortly. These are as follows: Cambridge Aero Instruments Inc. facility at Horn Lake, Memphis, Mississippi This includes IGC-approvals for the 302 series and the legacy models 10, 20 and 25. These are new IGC-approval documents because the Horn Lake address has not appeared before in IGC-approvals. However, after they contacted us, examples of their production standard have now been tested by GFAC and we are in a position to issue IGC-approval documents in the normal way. Cambridge LLC (CAM LLC) facility at Martinsville Virginia The Martinsville address has appeared in IGC-approvals since the ENL system addition to the 302 series approval in January 2003. These are therefore modified approval documents rather than new ones. To avoid duplication The Martinsville operation has been allocated new manufacturer codes so that recorders from this facility can be distinguished from those from Horn Lake. These codes are included in the approval document but for your information a Manufacturer codes: Three-letter, CLC (short for CAM LLC). One letter, M (Martinsville) and binary files for the legacy recorders *.CLC. The web site that will shortly have the full IGC-approval documents is: http://www.fai.org/gliding/gnss/igc_approved_frs.pdf If there are any questions I will be able to answer them only until 27 November after which I will be abroad and off-line until 11 December. -- Ian Strachan Chairman IGC GNSS Flight Recorder Approval Committee (GFAC) Bentworth Hall West Bentworth Alton, Hampshire GU34 5LA ENGLAND Tel: +44 1420 564 195 Fax: +44 1420 563 140 |
