Do winglets produce thrust?
Old November 28th 03, 07:43 PM
Bob Salvo
Default Do winglets produce thrust?
Anyone?
Bob
Old November 28th 03, 08:09 PM
Keith W
"Bob Salvo" wrote in message
Anyone?
Bob
That's against the laws of thermodynamics. If you can make a passive device
produce thrust you should rule the world with your new perpetual motion
machine! At best it reduces losses.
Keith
Old November 28th 03, 08:54 PM
Eric Greenwell
Anyone?
Bob
In my country, our gliders move forward because the wing produces
thrust, and our sailboats move over the water because the sail produces
thrust. Whether we should rule the world is causing much controversy.
Replace "SPAM" with "charter" to email me directly
Eric Greenwell
Washington State
USA
Old November 28th 03, 09:36 PM
cddb
Don't think so.
Gravity provides the thrust. Quite noticeably when fuselage
is pointed vertically. None at all when fuselage/wing is horizontal.
In article , Eric Greenwell
Anyone?
Bob
Old November 29th 03, 02:17 AM
LittleJohn
On Fri, 28 Nov 2003 21:36:17 +0000, cddb wrote:
Don't think so.
Look at it from another point of view. If all forces are balanced and
winglets are added, drag is reduced. Then velocity increases until the
thrust/drag forces are equalized. The result of increased velocity is
additional lift. The horizontal component of the lift vector is thrust,
which increases as lift increases. Ergo, winglets produce thrust. ;)
LittleJohn
Madison, AL
Old December 4th 03, 09:33 PM
Fred the Red Shirt
LittleJohn wrote in message ogy.net...
Don't think so.
Close. The horizontal component in the forward direction is thrust.
in a 90 degree bank the lift is also horizontal.
FF
Old November 28th 03, 09:40 PM
Keith W
"Eric Greenwell" wrote in message
Anyone?
Bob
device
Eric Greenwell
Washington State
USA
Yep - I was thinking of thrust as a primary force rather than that due to
'tobogganing' (ie a change of supporting force forward of the vertical).
Away I go to the sackcloth and ashes 8-).
As to whether the US should rule the world - I will duck out of that to
prevent a repetition of the reams of vehement verbiage which has already
filled the bit stream 8-))
Keith
Old November 28th 03, 10:22 PM
BTIZ
I don't think it was that "US" rules the world.. but more the line that.. he
who masters the air above us.. (glider pilots) .. rule the world..
BT
"Keith W" wrote in message
Anyone?
Bob
device
motion
Eric Greenwell
Washington State
USA
Keith
Old November 28th 03, 11:57 PM
Scott Correa
Winglets produce lift, with a vector. The vector direction
can be perpendicular to the winglet surface, fwd or aft.
That is dependant on how it is shaped and mounted.
A lift vector facing the nose (fwd) being called thrust
might be a mishmash of terms, but it happens.
I usually think of thrust as a motive force acting on the vehicle.
Winglet vectors are recovery of lost energy by reshaping flow
to our advantage. Good idea, yes, thrust...... probably not
a really good description of what is happening........
Scott.
A Level 1 AOA clarification Ramapriya Piloting 64 January 9th 05 01:19 AM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
Proposals for air breathing hypersonic craft. I Robert Clark Military Aviation 2 May 26th 04 06:42 PM
P-38 Exhaust Stephen Harding Military Aviation 10 April 19th 04 07:03 AM
