Some SZD-55-1 Questions
Old December 3rd 03, 11:32 PM
WDM
Default Some SZD-55-1 Questions
I have some SZD-55 questions for folks familiar with the 55.
1) How to stop the honking sound when applying rudder in cold weather. The
noise appears to come from the mylar on the vertical and is less prevailent
in warmer weather. Though mylar appears to be in good shape and tight. This
occurs on another 55 that I am familiar with.
2) Anyone have the problem of heavy airlerons? Oringinally I thought the
problem was with the sliders in the wings. I have recently discovered
interference bewteen the fuselage and the airleron torque tube where it
exits the fuselage when the wing is mated. The torque tube is rubbing at the
lower half of the exit hole of the fuselage of the right side. Another 55 at
our field believe they have the same problem on the same side as well. The
ailerons become heavier at higher speed and greater wing loading. The
gelcoat is worn at lower radius of hole and torque tube show discoloration
from rubbing in the 7 to 4 o'clock position when viewed from side.
3) Has anyone found a place to improve fuselage venting on the 55?
Thanks in advance, WDM
Old December 4th 03, 02:00 AM
Nolaminar
There is a fix that has worked for 55 aileron drag.
An interesting design mechansim is inside the wing root. The lower skin has to
be opened for access and this device cleaned and polished. Makes a world of
difference.
GA
Old July 14th 13, 05:27 AM posted to rec.aviation.soaring
Paul B[_2_]
difference.
GA
Well I know this is ten years since the the above post, but what is this fix and how would I find more specific information?
Cheers
paul
Old July 14th 13, 05:51 PM posted to rec.aviation.soaring
difference.
GA
Cheers
paul
Paul: SZD 55 has brass bushing at wing root that needs a few drops of machine oil thru the small pinhole every 30-50 hours to minimize aileron stiffness; if that doesn't help then I would remove ailerons, clean and lube hinges, and get some lubricant on the aileron tube where it goes thru the bearing (?teflon spray?). I would do both these before cutting into the skin.
Bill Drury
Old July 14th 13, 06:28 PM posted to rec.aviation.soaring
Dan Daly[_2_]
I have serial 001 - 1990 - the first production 55 and my ailerons are still very light. I do follow the lubrication plan as Bill indicates - on page 25 of the Technical Service Manual; steps 1, 2, 4, 18 are for ailerons. I can send you a copy if you don't have it (PM me here). Picture on page 55.
Aileron locks are recommended for trailering, and the stick should be immobilized.
How many hours on your 55?
Dan
Old July 14th 13, 06:46 PM posted to rec.aviation.soaring
Dan,
Since you have SN 1 you are probably a great guy to ask this question.
How serious is the "tip dragging" problem with the 55 during the initial few seconds on tow??
Thanks
Rick Lake
Old July 14th 13, 07:44 PM posted to rec.aviation.soaring
Dan Daly[_2_]
If you have a following wind, it may drop a wing briefly (I have only released once on roll since buying in 2007 so I have only had the wing touch once in 6 years), but as soon as the tail comes up it is not a problem. POH calls for dive brakes at the beginning of the roll to improve aileron effectiveness and that works quite well (stow them when the tail comes up). It is not a problem with calm or headwinds (which are, after all, what you really should have for takeoff). Similar to our club ASW-24 - which is to say, not much of a problem. I keep ailerons neutral until the tail comes up (full elevator to get this to happen as soon as I can) so as not to stall the down wing any more than it is.
I still have aileron dams on mine, though I see pictures of others without and wonder if that's part of the wing-drop legend. Theoretically they should improve aileron effectiveness, I'm told. There are 3 55's at my club, same opinion among the pilots (and 5+ at my last club).
I fly more/worry less. Love the 55 in eastern conditions, can fill it with water if out west.
DD
Old July 15th 13, 04:25 AM posted to rec.aviation.soaring
I have been flying an SZD-55 since 2001.
I have aileron dams/fences installed all the time. The wing drop/drag problem has happened with me only when loaded with ballast water and with the wind calm or possibly a slight tail component. Yes I know the preferred direction for take off is into wind! However when positioned in a grid of other glider for an event on a hot calm day and thermal comes along just as the tug takes up slcak in front of you the pucker factor escalates.
Old July 15th 13, 03:11 PM posted to rec.aviation.soaring
... The wing drop/drag problem has happened with me only when loaded with ballast water and with the wind calm or possibly a slight tail component. Yes I know the preferred direction for take off is into wind! However when positioned in a grid of other glider for an event on a hot calm day and thermal comes along just as the tug takes up slcak in front of you the pucker factor escalates.
True on many gliders. Contests will usually keep the grid in place until the tail wind is pretty substantial.
It doesn't help that most contests have helpful but not very experienced volunteers running wings. Get them level, get them balanced, the upwind wing must be a little low, and run like heck. And thanks for being here, but let's do it right.
Now to the point. It would be lovely if some of you mechanical gurus out there could develop a droppable wing wheel. I have in mind a cuff around the leading edge, a stick and a wheel below, which keeps the wings level to about 20 mph and then automatically falls off. Or maybe a waggle of the ailerons causes it to fall off. Yes, ground crew then has to run out and pick them up. But it's a small price to pay for an end to wing drops, ground loops, and the worse things that happen on winch tows.
John Cochrane
Old July 15th 13, 04:07 PM posted to rec.aviation.soaring
Dan Marotta
Do tip wheels *have* to be droppable? My LAK-17a has what amounts to roller
blade wheels in an aerodynamic fairing glued to the underside of the wing at
the tip. It also makes moving the glider around on the grid easier since
you don't need someone to hold a wing.
I can't imagine these wheels generate too much drag, but then, I don't fly
in contests...
let's do it right.
John Cochrane
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 4 August 7th 03 05:12 AM
