High tow vs. low tow for rough tows (long)
Old December 4th 03, 09:57 PM
Mark James Boyd
Default High tow vs. low tow for rough tows (long)
While towing for Hollister, I noticed their instructor
really liked to practice slack line.
So for my flight review in Avenal yesterday, we did a bunch
of slack line corrections. We did them during one tow,
but broke the rope. 150' of rope ($12), two schweizer rings ($20),
one tost ring ($35), a carabiner (sp?), two half-wiffle balls,
and a short section of "weak link" then back-released from
the 2-33. It plumeted swiftly into a thankfully barren
plowed field below.
A few tows later, we mentioned to the tug pilot we were gonna
try slack line again. He wised up and took off the weak
link assembly ($68) leaving just wiffle and a $10 schweizer
ring.
After a dozen more slack rope practice tries, we broke
that rope. The ring and 10' of rope back released and
plumetted into another (thank god) barren field.
I'm sure some tractor pulling a tiller will grind some metal
at some point and we may get them back.
I thought about slack line. The real problem isn't
too much pulling, it's the "snappiness" with which the
slack line comes out.
It strikes me that on low tow, as slack line pulls out,
it allows a lot softer recovery. When slack comes out,
the tail of the towplane is pulled low, giving some
dampening. Next the towplane slows a little from the
drag, also good. On high tow, neither of these is true.
Sure, sure, I've read very careful use of spoilers and
yawing the sailplane away from the slack are tried and true
methods. However, even using these, there is still some point
there is so much slack you are going to break the
rope no matter what. A friend mentioned during his
first flight to try to get in wave, he with the experienced
instructor broke three ropes before succeeding.
My question is to those who have towed through rotor.
Have any of you tried low tow and high tow and would
care to tell us if you've found a difference in the
number of rope breaks?
How about the idea of towing low and to the left of the
tug? Ignore for the moment that it would annoy the tug
driver to do this on purpose (except maybe if torque
and p-factor now meant he could just leave the rudders
to flop about). Also ignore for the moment it is
drag inefficient. Would this reduce the possibility
of slack line and/or improve recovery chances even more?
How about other dangers? If the rope breaks on low
tow how would you feel about having it
fly over/around top of the wing/elevator/rudder?
Anyone have this happen?
I'm especially interested in the experiences of wave
pilots and those towing through super heavy thermals...
but armchair analysis is also invited :-]
Old December 5th 03, 12:08 AM
Mark James Boyd
Andreas Maurer wrote:
Is it possible that you are using the wrong ropes/weak links?
Bye
Andreas
The first rope broke at a splice, not at the "weak link."
When it did break, it came as a bit of a surprise (at
least to me), but was caused by the wrong technique
for slack recovery.
The second rope break happened with what may have been a
2000# strength rope. This one happened more or less
expectedly. We did a lot quite a few slack line recoveries,
correctly, and with progressively more slack. In this
case the rope either broke at the last few feet, or
became unwoven from the ring. In either case, this is
what the tow pilot said is the common break point for
a uniform rope. The tow pilot said it felt like we were
intentionally trying to break the rope, which is not so
far from truth.
I would be surprised if the average gliderport has ever
seen a rope break under "normal" conditions.
If so this would likely indicate rope/weak link
problems. Our procedures that day certainly
were not "normal," but certainly convinced me that
yes, the rope can be broken with poor slack technique or
simply too much slack. The gliderports that
use wave (including Minden) are apparently familiar
with the latter...
I've flown through rotor and soared wave (in a Katana),
but never under tow (self-launch). It's hard for
me to imagine towing through rotor WITHOUT getting
a rope break...
Old December 5th 03, 02:12 PM
Brian Case
Hi have been doing quite a few Slack rope demos recently, Mostly in
Blaniks and 2-33's or 2-32's. Also done a few in my HP16T. I have put
huge amounts of slack in the rope, so much so that I have had the rope
back release on both the HP and the 2-32. I have had the 2-32 wingtip
abeam the towplanes tail when the rope finally back released, If it
had not I was planing on recovering. I have yet to break a tow rope.
Typically the rope we use is 200ft hollowbraid Poly rope with no
weaklink. I have used adapters (sometimes called a weaklink to convert
a Schweizer ring to Tost or vi versa.)
My technique for recovering from slack rope is to move way off to the
side of the tow plane (About the Upper left or right corner of were we
box the wake) If going right this puts the left wing tip of the glider
just about behind the right wing tip of the towplane. You can pull up
slightly to help take the slack out but this usually is not necessary.
By moving out the side like this when the Rope goes tight it Yaws the
tail of the towplane and if using a nose hook on the glider will yaw
the glider as well. This yawing of both the glider and towplane
almost eliminates any tendancy for the rope to snap and break.
Brian C.
CFIIG/ASEL
Old December 5th 03, 12:29 AM
BTIZ
We don't spend that kind of money on our weak link... yes.. the rings are
$10-12. the weak link in the rope is cheap..
if you are breaking the actual tow rope because the weak link was removed
(violation of US FAR?) you really don't have a knack for slack line
recoveries..
We use closer to or more than 200ft of rope.. trying to teach on a 150ft
rope gets real "interesting".
When our actual rope breaks (not the weak link) on slack line training.. it
was about due to be replaced anyway. Normally the weak link at the glider
end breaks and the instructor is able to save the ring.
BT
"Mark James Boyd" wrote in message
news:3fcfbbf3$1@darkstar...
plowed field below.
ring.
Old December 5th 03, 12:40 AM
Mark James Boyd
In article rjQzb.7929$yf.258@fed1read01,
The end of our rope is a schweizer ring. The weak link assembly
is a weaker 3 foot rope with a tost at one end and a schweizer at
the other. A (strong) carbiner connects one end of the weak link
assembly to the end of the rope (schweizer).
We quickly and easily flip the assembly
depending on tost vs. schweizer tow.
recoveries..
Hmm... 91.309(a)(3) seems to say the weak link is only required
if the rest of the rope isn't between 80% and 200% of max cert
glider weight. As far as having a knack...that's why we train, eh?
We use between 200-300 ft. I guess 240ft is most common. I do
not envy anyone towing on a 150ft rope.
This was the case for us as well...a weak point broke the first
time. The second time we assume it broke near the glider
end because that is where most wear occurs in the rope (hookup,
wiffle ball rubbing, etc). But the second time was was not
because the rope was weak, just that that point was the weakEST
part of the rope.
We had a great discussion about doing slack line practice over
unpopulated areas in case the rope breaks with enough left
to drag back and back release.
Old December 5th 03, 04:02 AM
BTIZ
we just swap out the weak link rope... a simple eye splice on the end of the
"rope" and the end of the link with the appropriate ring on the other end.
don't involve a carbineer...
and if the rope breaks.. you don't loose a $30 tost link AND a $12
Schweitzer link if it back releases..
we have had some rope breaks and the glider brings back his end..
or if the weak link breaks with slack line training.. try to save the ring..
BT
news:3fcfe229$1@darkstar...
recoveries..
it
part of the rope.
Old December 5th 03, 01:02 AM
Janusz Kesik
Użytkownik BTIZ w wiadomości do grup
dyskusyjnych napisał:rjQzb.7929$yf.258@fed1read01...
150ft
I agree: "interesting"... 150ft is a rope used in first flights here
(Poland), the longest. The only situations when we use longer ropes is
the triple tow (30, 50 and 75 metres). I'd rather say, that using the
short rope would make the tow easier. When towing for a typical
thermalling, the 30m (90ft?) rope is just OK, and I often flew with 20m
rope, especially in the mountains - in most cases the tow was easier and
more comfortable to me. Also gaining height (in order to shorten the tow)
by a towplane with glider behind is much, really much easier and less
stressing when using a short 20-30m rope.
When practising the "wave tow" and in real flights throught the rotors,
the 15-20m long rope is used.
The last advice I could give for Mark is: enter the propwash and stay
here. This should make keeping the rope spanned easier.
Regards,
Janusz Kesik
visit
www.leszno.pl - home of the www.css-leszno.it.pl
Old December 5th 03, 07:07 PM
303pilot
I've heard europeans say this before but I just don't understand. With 200'
of rope I'm roughly 2 seconds behind the tow plane. That's 2 seconds to
construct a response to whatever I see happen to the tow plane. How does
shortening the interval make things easier?
The only case I can think of is if the rope is short enough that the tow
plane and glider experience things at the same time. I guess that's what
you get w/15 meter ropes? Please help me understand why anyone would ever
intentionally get (and stay!!!) only one wingspan (or less with slack) away
from the tow plane.
Brent
(who mostly gets towed through benign 3 knotters, but has experienced 13
knotters and Minden wave/rotor)
"Janusz Kesik" wrote in message
150ft
Regards,
Janusz Kesik
visit
Old December 5th 03, 09:07 PM
Janusz Kesik
I guess that's what
ever
away
from the tow plane.
Yes that is the purpose of using such short ropes, but also makes
thermalling in towed flight easier. It also makes keeping glider in the
right position when towet through the turbulent air with lots of 'ups and
downs'. Usually the 50m rope is used at the beginning of the training
prosess, and after getting the licence all the tows are done using 30m
and shorter ropes. Some time ago someone described his own experience
which happened many years ago (in '60s or '70s) at Leszno when came there
as a visitor, took a Pirat for some flying and outlanded. Then he was
towed out of a short field by an Yak-12 which's pilot incredibly
shortened the rope in order to shorten the ground roll as the forest
seemed co be too close to get over it with a 'normal' rope. )
Regards,
Janusz Kesik
visit
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
(PIREP, long) Cherokee 180 from Bay Area to Bishop, CA Dave Jacobowitz Piloting 15 June 24th 04 12:11 AM
Flight test update - long nauga Home Built 1 June 5th 04 03:09 AM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS MT. DIABLO HIGH SCHOOL PHOTOS Home Built 1 October 13th 03 03:35 AM
Copyright Š2004-2025 AviationBanter.
