https://en.wikipedia.org/wiki/Consol...B-24_Liberator
The Consolidated B-24 Liberator is an American heavy bomber, designed by Consolidated Aircraft of San Diego, California. It was known within the company as the Model 32, and some initial models were laid down as export models designated as various LB-30s, in the Land Bomber design category. At its inception, the B-24 was a modern design featuring a highly efficient shoulder-mounted, high aspect ratio Davis wing. The wing gave the Liberator a high cruise speed, long range and the ability to carry a heavy bomb load. Early RAF Liberators were the first aircraft to cross the Atlantic Ocean as a matter of routine. However, the type was difficult to fly and had poor low speed performance. It also had a lower ceiling and was less robust than the Boeing B-17 Flying Fortress. While aircrews tended to prefer the B-17, General Staff favored the B-24, and procured it for a wide variety of roles. The B-24 was used extensively in World War II. It served in every branch of the American armed forces, as well as several Allied air forces and navies, and saw use in every theater of operations. Along with the B-17, the B-24 was the mainstay of the US strategic bombing campaign in the Western European theater. Due to its range, it proved useful in bombing operations in the Pacific, including the bombing of Japan. Long range anti-submarine Liberators played an instrumental role in closing the Mid-Atlantic Gap in the Battle of the Atlantic. The C-87 transport derivative served as a longer range, higher capacity counterpart to the Douglas C-47 Skytrain. Role Heavy bomber Anti-submarine warfare Maritime patrol aircraft Manufacturer Consolidated Aircraft First flight 29 December 1939 Introduction 1941 Retired 1968 (Indian Air Force) Primary users United States Army Air Forces United States Navy Royal Air Force Royal Australian Air Force Produced 1940–45 Number built 19,256[citation needed] Unit cost $297,627 ($4.79 million in today's dollars) Variants Consolidated PB4Y-2 Privateer Consolidated C-87 Liberator Express Consolidated Liberator I Developed into Consolidated R2Y The B-24 had a shoulder mounted high aspect ratio Davis wing. This wing was highly efficient allowing a relatively high airspeed and long range. Compared to the B-17 it had a 6-foot larger wingspan, but a lower wing area. This gave the B-24 a 35% higher wing loading. The relatively thick wing held the promise of increased tankage while delivering increased lift and speed, but became unpleasant to fly when committed to heavier loadings as experienced at high altitude and in bad weather. The Davis wing was also more susceptible to ice formation than contemporary designs, distortions of the aerofoil section causing loss of lift (unpleasant experiences drawing such comments as 'The Davis wing won't hold enough ice to chill your drink'.) [9] The wing was also more susceptible to damage than the B-17's wing, making the aircraft less able to absorb battle damage. The wing carried four supercharged radial engines mounted in cowlings borrowed from the PBY Catalina (except being oval in cross-section, with oil coolers mounted on each side of the engine), turning 3-bladed variable pitch propellers. The tail plane featured two large oval vertical stabilizers mounted at the ends of a rectangular horizontal stabilizer. As early as 1942, it was recognized that the Liberator's handling and stability could be improved by the use of a single vertical fin. The single fin was tested by Ford on the single B-24ST and an experimental XB-24K, and was found to improve handling. All Liberators were produced with twin oval fins, with the exception of eight preproduction B-24N aircraft. The B-24N was intended as a major production variant featuring a single tail. Over 5000 orders for this version were placed in 1945, but were cancelled due to the end of the war. The single fin did appear in production on the PB4Y Privateer derivative.[ Specifications (B-24J) General characteristics Crew: 11 (pilot, co-pilot, navigator, bombardier, radio operator, nose turret, top turret, 2 waist gunners, ball turret, tail gunner) Length: 67 ft 8 in (20.6 m) Wingspan: 110 ft 0 in (33.5 m) Height: 18 ft 0 in (5.5 m) Wing area: 1,048 ft² (97.4 m²) Airfoil: Davis 22% / Davis 9.3% Empty weight: 36,500 lb (16,590 kg) Loaded weight: 55,000 lb (25,000 kg) Max. takeoff weight: 65,000 lb (29,500 kg) Powerplant: 4 × Pratt & Whitney R-1830-35 or -41 turbosupercharged radial engines, 1,200 hp (900 kW) each Zero-lift drag coefficient: 0.0406 Drag area: 42.54 sq ft (3.952 m2) Aspect ratio: 11.55 Performance Maximum speed: 290 mph (250 kn, 488 km/h) Cruise speed: 215 mph (187 kn, 346 km/h) Stall speed: 95 mph (83 kn, 153 km/h) Range: 2,100 mi (1,800 nautical miles (3,300 kilometres)) Ferry range: 3,700 mi (3,200 nmi (5,900 km)) Service ceiling: 28,000 ft (8,500 m) Rate of climb: 1,025 ft/min (5.2 m/s) Wing loading: 52.5 lb/ft² (256 kg/m²) Power/mass: 0.0873 hp/lb (144 W/kg) Lift-to-drag ratio: 12.9 Armament Guns: 10 × .50 caliber (12.7 mm) M2 Browning machine guns in 4 turrets and two waist positions Bombs: Short range (˜400 mi): 8,000 pounds (3,600 kg) Long range (˜800 mi): 5,000 pounds (2,300 kg) Very long range (˜1,200 mi): 2,700 pounds (1,200 kg) * |
| Consolidated R2Y Liberator Liner | Byker | Aviation Photos | 0 | June 4th 16 03:12 AM |
| Consolidated R2Y Liberator Liner | Byker | Aviation Photos | 0 | June 4th 16 03:11 AM |
| Consolidated R2Y Liberator Liner | Byker | Aviation Photos | 0 | June 4th 16 03:10 AM |
