I'm a novice glider pilot thinking of a Speed Astir II B. Any thoughts on this
aircraft? Thanks! David |
define "novice".. if you have any time in "high performance" gliders.. then
have fun... it's a great glider.. they did not call it "speed" for it's looks.. any consistent flying in glass birds and you should be able to handle the Speed Astir.. BT "Flyhighdave" wrote in message ... I'm a novice glider pilot thinking of a Speed Astir II B. Any thoughts on this aircraft? Thanks! David |
In my case "novice" means about 20 training flights & a few solo flights in a
Grob 103 II A. I guess I'm really just a beginner! David |
Earlier, Wallace Berry wrote:
...Wing skins form the hinge for the wing control surfaces. No mylar needed... A minor nitpick: That is the way it looks from the outside. However, structurally, the upper wing skin does not actually support the aileron. Inside the wing there are several support linkage gadgets that transfer lift loading between the aileron and the wing. I can't remember if they're four-bar links or track-and-roller arrangements. However, these gadgets are carefully arranged so that the effective hinge axis coincides with the surface of the upper wing skin. There are other sailplanes that use this sort of system; the flaps of the Slingsby T65 Vega come to mind. It is a compelling system, since as Wallace points out it needs no mylar and no internal curtain sealing. However, what I've seen of one or two Speed Astirs in service is that the control loads tend to be greater than in more conventional systems, especially as they age. Also, the flexible skin portion tends not to hold its surface finish well; I've seen cracking and bubbling in this area on both Vegas and Speed Astirs. It's also hard to achieve the kind of surface travels that it takes to make high-aspect ailerons do their job effectively. Getting off-topic, there _is_ at least one Chris Heintz powered airplane that does actually support the aileron on a flexible portion of wing skin. For more information, see: http://www.zenithair.com/kit-data/ht-aileron.html Thanks, and best regards to all Bob K. http://www.hpaircraft.com |
I would consider something else. Speed Astir II's are
not only misleading with their name, it is also one of the worst looking gliders around (bar the PW-5 of course). At 05:06 10 December 2003, Btiz wrote: define 'novice'.. if you have any time in 'high performance' gliders.. then have fun... it's a great glider.. they did not call it 'speed' for it's looks.. any consistent flying in glass birds and you should be able to handle the Speed Astir.. BT 'Flyhighdave' wrote in message ... I'm a novice glider pilot thinking of a Speed Astir II B. Any thoughts on this aircraft? Thanks! David |
I guess I'm qualified to answer this one. I own one, although it is a
II not a IIB. The difference is basically a longer fuselage to accomodate longer pilots. I have about 40hrs in mine. I'd only had a couple of short flights in a Club Libelle, a flight or three in Pilatus, and a a couple of flights in a Twin Astir before jumping in the Speed. I should preface this with the fact that mine has winglets fitted, and I have not flown it without. Take-off. Be awake when aero-tow launching. Set Flaps full negative and pull into +2 once you can feel some aileron control coming on. In the first part of ground roll , use rudder and if you can help it, little aileron to keep wings level. Once you mastered this , the rest is a piece of cake. Make sure the tow plane uses a long rope. Short ropes mean more turbuence from the tug, and prop wash will hit you early in the take-off roll. You don't want that....trust me. Flying Maybe the winglets make a big difference. i don't know. However, anyone who has flown mine lands with big smile on their face. It's a great performing glider, and I have similar climb rates to other gliders on the feild. Don't thermal too slow. About 48-52 knots is good for me. Where the name Speed disAstir came from eludes me. Landing. Landing is a dream. Follow the Flight manual and you won't go wrong. Full Flap at end of downwind, use brakes sparingly close to the ground as full flap, full brake will make for an early (and vertically fast) arrival Would I buy another? If I could find a IIB in good condition, and funds were an issue I would not hesitate. You will pay about US$10000 less than an equivalent performing glider. ................and yes, it's a bitch to rig. Cheers Mark Owain Walters wrote in message ... I would consider something else. Speed Astir II's are not only misleading with their name, it is also one of the worst looking gliders around (bar the PW-5 of course). At 05:06 10 December 2003, Btiz wrote: define 'novice'.. if you have any time in 'high performance' gliders.. then have fun... it's a great glider.. they did not call it 'speed' for it's looks.. any consistent flying in glass birds and you should be able to handle the Speed Astir.. BT 'Flyhighdave' wrote in message ... I'm a novice glider pilot thinking of a Speed Astir II B. Any thoughts on this aircraft? Thanks! David |
I must point out that using the words 'speed' and 'Astir'
in the same sentence is misuse of the english language. :-) At 22:42 10 December 2003, Mark wrote: I guess I'm qualified to answer this one. I own one, although it is a II not a IIB. The difference is basically a longer fuselage to accomodate longer pilots. I have about 40hrs in mine. I'd only had a couple of short flights in a Club Libelle, a flight or three in Pilatus, and a a couple of flights in a Twin Astir before jumping in the Speed. I should preface this with the fact that mine has winglets fitted, and I have not flown it without. Take-off. Be awake when aero-tow launching. Set Flaps full negative and pull into +2 once you can feel some aileron control coming on. In the first part of ground roll , use rudder and if you can help it, little aileron to keep wings level. Once you mastered this , the rest is a piece of cake. Make sure the tow plane uses a long rope. Short ropes mean more turbuence from the tug, and prop wash will hit you early in the take-off roll. You don't want that....trust me. Flying Maybe the winglets make a big difference. i don't know. However, anyone who has flown mine lands with big smile on their face. It's a great performing glider, and I have similar climb rates to other gliders on the feild. Don't thermal too slow. About 48-52 knots is good for me. Where the name Speed disAstir came from eludes me. Landing. Landing is a dream. Follow the Flight manual and you won't go wrong. Full Flap at end of downwind, use brakes sparingly close to the ground as full flap, full brake will make for an early (and vertically fast) arrival Would I buy another? If I could find a IIB in good condition, and funds were an issue I would not hesitate. You will pay about US$10000 less than an equivalent performing glider. ................and yes, it's a bitch to rig. Cheers Mark Owain Walters wrote in message news:... I would consider something else. Speed Astir II's are not only misleading with their name, it is also one of the worst looking gliders around (bar the PW-5 of course). At 05:06 10 December 2003, Btiz wrote: define 'novice'.. if you have any time in 'high performance' gliders.. then have fun... it's a great glider.. they did not call it 'speed' for it's looks.. any consistent flying in glass birds and you should be able to handle the Speed Astir.. BT 'Flyhighdave' wrote in message ... I'm a novice glider pilot thinking of a Speed Astir II B. Any thoughts on this aircraft? Thanks! David |
I had one for 2 years
+Flies well +clims well if no water +goes fast if loadd -weaker climb rate with water compared to others -lack of comfort,narrow fuselage -difficult takeoff on tail/crosswind -difficult to sell -difficult to work on instruments "Flyhighdave" wrote in message ... I'm a novice glider pilot thinking of a Speed Astir II B. Any thoughts on this aircraft? Thanks! David |
| Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 01:18 PM |
| Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 09:35 PM |
| Va and turbulent air penetration speed. | Doug | Owning | 69 | January 11th 04 09:35 PM |
| Problem: Ground Speed Estimate with Volkslogger and WinPilot | RamyYanetz | Soaring | 3 | August 26th 03 04:06 PM |
| New Film: The Need For Speed - Going to war on drugs | Phil Carpenter | Military Aviation | 0 | July 23rd 03 08:43 AM |
